Topic: -E command line option (Read 3188 times) previous topic - next topic
I found this topic (and I know most of you won´t like it):
http://www.hydrogenaudio.org/forums/index....mp;#entry103155
The linked post explains what --super-secret... stands for. One of these options is -E, which is not explained in the offical documentation and I was not able to find it somewhere else, so what does -E stand for?
http://flac.sourceforge.net/documentation_tools_flac.html
Unless it is case-sensitive (which is the case for other commands)
-e, --exhaustive-model-search
Exhaustive model search (expensive!). Normally the encoder estimates the best model to use and encodes once based on the estimate. With an exhaustive model search, the encoder will generate subframes for every order and use the smallest. If the max LPC order is high this can significantly increase the encode time but can shave off another 0.5%.
<translation>use of this switch is pretty silly</translation>
Looking through the source code, it seems the -E option turns on escape coding, which means the FLAC encoder attempts unencoded partitioned Rice residuals (explained here).
Maybe it´s not documented because it is not in the stable release (any more)?
Because it says invalid option here.
