Topic: I need to add a URL location (Read 16665 times) previous topic - next topic
Essentially my code takes a URL generated from UPnP xml from a controller that is the path to the music file.
Most likely I will only ever be clearing the playlist and then adding a single file to Foobar2000.  then playing it etc.
Could I please get help with the code needed to do this?  I also need to pass that back to the main thread from my code.
Thank you
Darren
My plugin gets a location from the network as a URL.  I just need to tell Foobar2000 to add this as a file for playback.  I am looking through the SDK and cannot find how to add a file for playing.
Please help.
Thank you
Darren
The following code clears the active playlist and adds the tracks (possibly more than one) referred to by the given URL to it. It creates an undo point, so the user can revert to the previous playlist content. The select parameter controls if the new tracks will be selected. The parent window argument is needed for an eventual progress window; do not pass NULL for this! (core_api::get_main_window is an appropriate choice, if you do not have a window of your own.)
// Not tested, but should work.
void finding_a_better_name_for_this_function_is_left_as_an_exercise_for_the_reader(const char *url, bool select, HWND parentwnd)
    static_api_ptr_t<playlist_manager> pm;
    t_size playlist = pm->get_active_playlist(); // Use a different playlist if desired.
    pm->playlist_undo_backup(playlist); // Highly recommended unless you modify a locked, "smart" playlist (that you own)
    pm->playlist_clear(playlist); // If you want to replace the existing playlist content.
    pm->playlist_add_locations(
        playlist,
        pfc::list_single_ref_t<const char *>(url),
        select,
        parentwnd);
Thank you .  I get this error when I try to build with it.
error LNK2001: unresolved external symbol __imp__StrCmpLogicalW@8
Darren
You have to link your plugin with shlwapi.lib
I dont know how to handle he HWND parentwnd
and could someone please tell me how to use abort_callback &p_abort
when I do this in the main_thread_callback
I run my UPnP stack in another thread.  I am using main_thread_callback to control foobar2000, which works fine.
When I create a class for handling passing the URL to the main_thread_callback
static_api_ptr_t<main_thread_callback_manager> mtcm;
mtcm->add_callback(new service_impl_t<AVTOpen>(CurrentURI,true,handle));
The URI path gets destroyed inside the virtual void callback_run().
I don't have enough experience with class to fix this issue.
Also, how do I use the main_thread_callback to pass playback information (position etc) back to my thread?
please help
Thank you
Darren
EDIT:  Figured this out
