Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1941225 times) previous topic - next topic
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #625
What does this mean?
Padded some input files to a frame boundary
Reply #626
As far as I understund, it means the cut point didn't fall on a full frame so cuetools added samples of silence to make it fall on a full frame. It's something like that. I already encountered this when I tried to made a CDImage+cue of NIN free OEF releases which were released as online separate tracks & weren't compliant to CD. It shouldn't matter if it matches, I think. You can encounter the opposite "Truncated xxx extra samples in some input files".
Reply #627
What is the difference between "Playstation type data track" & "CD-Extra data track" other than the fact that cuetools cannot guess the lenght of missing playstation data ? Will the Disk ID be recognized if I simply delete the playstation data track in cue ? (Don't seems to work) Is the rip unusable with cuetools if I don't have the playstation data length at all ? The cue is weird, Track 1 is data, F2K will not even load it.
Reply #628
CD-Extra is an audio disc format with data track after the audio.
Playstation type has data track before the audio.
CUE sheets look a bit differently, but in both cases you have to know data track length to be able to use AccurateRip.
With playstation type there's no easy way to guess it.
CUETools 2.1.6
Reply #629
Usually that means that source files are not a valid CD rip. This usually happens if the audio files were edited, or the album is a web release by the artist, which was never meant for CD.
CUETools 2.1.6
Reply #630
Today after the XPSP3 live update the program now return this error and return in the initial state (waiting for press the go button):
No idea yet. We'll see if someone else has the same problem.
What was in that update? There's usually a link to a knowledge base article on the microsoft website in update log.
CUETools 2.1.6
Reply #631
Ok thks
I think I will just delete the data track in this cue as the fact that F2K will not load it is very unpractical anyway.
Reply #632
Windows XP Aggiornamento per Windows XP (KB961118)
Microsoft .NET Framework 3.5 Service Pack 1 e .NET Framework 3.5 Family Update per .NET, dalla versione 2.0 alla 3.5 (KB951847) x86
Reply #634
This is an old update. It should have come more than half a year ago.
Maybe you should try reinstalling http://www.microsoft.com/downloads/details...;displaylang=en
i agree.. and maybe if that fails, the vc++ redistro, that fixed mine (i didn't look at the actual update KB to see what it updated, sorry).
as always, i recommend this tool to at least verify that you have no problems with your .NET installs. See a description, screenshot and links:
This .NET Framework setup verification tool is designed to  automatically perform a set of steps to verify the installation state  of one or more versions of the .NET Framework on a computer.  It will  verify the presence of files, directories, registry keys and values for  the .NET Framework.  It will also verify that simple applications that  use the .NET Framework can be run correctly.
Here is a link to the website for the product
Here is the direct download link
Reply #635
As I am thinking about it, one small change that I would like to see in the future is empty silence tracks reported as accurate. I have several of those:
Danzig - 1993 - Thrall-Demonsweatlive (EP)
Danzig - 1994 - Danzig 4 (Digipack)
Korn - 1998 - Follow The Leader
Nine Inch Nails - 1992 - Broken (EP) (Digipack)
Cuetools reports them as not accurate due to [00000000] (00/00) No matches.
There should be an exception for empty tracks as this is a special case.
An empty track doesn't need a match to be accurate
[00000000] (00/00) Empty track. + "Accurately ripped" in batch log would be more usefull, IMHO.
Reply #636
Gregory, just to let you know: both links in the About... box don't work :-)
Reply #637
Thank you for your interest in my problem.
.NET Framework 2.0 SP2
Product verification succeded!
.NET Framework 3.0 SP2
.NET Framework 3.5 SP1
Do it.
Nothing new.
I repeat
What I can do for reuse the program?
Reply #638
I'm not sure if this validation tool verifies configuration files.
Check your machine.config (Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG\machine.config or something like this).
Try adding something like this to the configSections section.
    <sectionGroup name="system.serviceModel" type="System.ServiceModel.Configuration.ServiceModelSectionGroup, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
      <section name="behaviors" type="System.ServiceModel.Configuration.BehaviorsSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="bindings" type="System.ServiceModel.Configuration.BindingsSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="client" type="System.ServiceModel.Configuration.ClientSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="comContracts" type="System.ServiceModel.Configuration.ComContractsSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="commonBehaviors" type="System.ServiceModel.Configuration.CommonBehaviorsSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowDefinition="MachineOnly" allowExeDefinition="MachineOnly"/>
      <section name="diagnostics" type="System.ServiceModel.Configuration.DiagnosticSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="extensions" type="System.ServiceModel.Configuration.ExtensionsSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="machineSettings" type="System.ServiceModel.Configuration.MachineSettingsSection, SMDiagnostics, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowDefinition="MachineOnly" allowExeDefinition="MachineOnly"/>
      <section name="serviceHostingEnvironment" type="System.ServiceModel.Configuration.ServiceHostingEnvironmentSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
      <section name="services" type="System.ServiceModel.Configuration.ServicesSection, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
    </sectionGroup>
Or this: http://www.dotnettech.net/BCL/Article.aspx...0%2f430270.aspx
CUETools 2.1.6
Reply #639
Must say, I like this program more and more. I don't think I use the full potential of the program yet, but I'm trying.
I also have 2 requests.
At the bottom of the log there are 2 or 3 rows of checksums (CRC, without null, (if exists) log).
It would be nice if you could add a fourth: AR crc.
I have to use tripleflac now and again to compare two rips who aren't in the AR database yet.
It would be nice if Cuetools could give me the AR checksums.
After updating to 2.0.4a the program asks if it's all right to overwrite a previous log.
Very annoying if you want to batch check a batch which wasn't in the database last time and you want to do a recheck.
Also very annoying when trying out different pregaps.
Couldn't find a setting to disable this message. My second request: I would appreciate if you added such a setting.
Reply #640
Thnx for a the 2.0.4a version. The apps works and looks very good now.
I'm still looking for the option to output filenames in lowercase.
Integrating the feature into CueTools will save us lowercase guys for a massive
amout of work when it comes to editing the cue sheet and m3u files.
Also, for some reason the "Force ANSI filenames" changes invalid characters to underscores (or perhaps spaces?). There should either be possible to define a ruleset (ie. define that for example & is changed to and, : is changed to _-_) or just delete the character. Personally I think the extra underscores is a bit annoying.
  TRACK 04 AUDIO
    TITLE "We Share Our Mothers' Health"
    PERFORMER "The Knife"
    INDEX 00 06:08:64
FILE "04-The_Knife-We_Share_Our_Mothers__Health.flac" WAVE
I hope that you will consider my suggestions for 2.0.5.
Would also love replay-gain support for multiple FLAC files (not necessarily inside the cue file).
Have you also considered compiling Linux compatible binaries using Mono? Probably some extra work, but I promise I'll use it =)
Reply #641
  TRACK 04 AUDIO
    INDEX 00 06:08:64
doesn't the program support foobar variables/functions? i thought i read that... i could be completely wrong though.. but if it does, you could try and use the function $lower(%artist%-%title%) or whatever you want.
I didn't even notice the "a" version was out until yesterday... what is changed? i notice it will ask to overwrite accuraterip log if it exists. seems there may be more default profiles? i also just noticed there is a 64 bit version too... maybe i overlooked this, but it's nice since i'm running 64-bit OS.
yeah, btw, i'm pretty sure it supports foobar naming schema, cause i'm looking in the options and i see it is using some variables. check out this wiki for all of the modifiers (not sure how many or again, if they are even supported, but it's worth a shot): Foobar Title Formatting Reference  [edit: actually i found the exact info on the CUETools homepage... here is the link to it.
so anyone know what else is changed or is there a changelog?
Reply #642
2.0.4a is mostly minor interface fixes, nothing important.
No special binaries required for Linux, x86 ones should work, but... The problem is it only supports wav files when run on linux. This will hopefully change in the next version, when a pure managed FLAC encoder/decoder will be added.
I will add lowercase option, but more complicated things (like the rulesets) will probably have to be done using foobar-style functions, i will add more of them.
CUETools 2.1.6
Reply #643
I'm trying to use the "Verify" option on a FLAC encoded album. The program fails with the following error:
Exception: Could not load file or assembly 'CUETools.Codecs.TTA, Version=1.0.3507.34128, Culture=neutral,
PulicKeyToken=null' or one of its dependencies. This application has failed to start because the application
configuration is incorrect. Reinstallign the application may fix this problem. (Exception from HRESULT: 0x80073681):
This application has failed to start because the application configuration is incorrect. Reinstalling the application may
fix this problem. (Exception from HRESULT: 0x800736B1)
Any idea what the problem is?
Is your perfect hearing worth <$200? -- USE EAR PLUGS
Reply #645
If you are getting an error loading CUETools.Codecs.TTA, you need to install this update
Thanks I found it. I'm not complaining, but I would suggest you detect that issue in the program and point the user to the required update, instead of the funky error message.
Reply #646
Great configuration, many thanks Gregory !
In 2.0.4a version when I encode album with various artists in embedded flac, the artists name is not written in line "PERFORMER". It's only write : "various".
Original Cue sheet :
REM GENRE Soundtrack
REM DATE 1980
REM DISCID 90099B0B
REM COMMENT ExactAudioCopy v0.99pb4
PERFORMER "Various"
TITLE "The Blues Brothers"
REM REPLAYGAIN_ALBUM_GAIN +0.25 dB
REM REPLAYGAIN_ALBUM_PEAK 0.710358
FILE "Various - The Blues Brothers.wav" WAVE
  TRACK 01 AUDIO
    TITLE "She Caught The Katy"
    PERFORMER "The Blues Brothers"
    REM REPLAYGAIN_TRACK_GAIN +0.38 dB
    REM REPLAYGAIN_TRACK_PEAK 0.529999
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Peter Gunn Theme"
    REM REPLAYGAIN_TRACK_GAIN +1.53 dB
    REM REPLAYGAIN_TRACK_PEAK 0.575104
    INDEX 00 04:09:27
    INDEX 01 04:12:40
  TRACK 03 AUDIO
    TITLE "Gimme Some Lovin'"
    REM REPLAYGAIN_TRACK_GAIN -0.28 dB
    REM REPLAYGAIN_TRACK_PEAK 0.587189
    INDEX 00 07:58:48
    INDEX 01 08:02:05
  TRACK 04 AUDIO
    TITLE "Shake Your Tailfeather"
    PERFORMER "Ray Charles & The Blues Brothers"
    REM REPLAYGAIN_TRACK_GAIN -0.14 dB
    REM REPLAYGAIN_TRACK_PEAK 0.582825
    INDEX 00 11:07:16
    INDEX 01 11:11:58
  TRACK 05 AUDIO
    TITLE "Everybody Needs Somebody To Love"
    REM REPLAYGAIN_TRACK_GAIN -0.27 dB
    REM REPLAYGAIN_TRACK_PEAK 0.598083
    INDEX 00 13:59:64
    INDEX 01 14:03:18
  TRACK 06 AUDIO
    TITLE "The Old Landmark"
    PERFORMER "James Brown"
    REM REPLAYGAIN_TRACK_GAIN +1.68 dB
    REM REPLAYGAIN_TRACK_PEAK 0.455566
    INDEX 00 17:25:69
    INDEX 01 17:28:45
  TRACK 07 AUDIO
    TITLE "Think"
    PERFORMER "Aretha Franklin"
    REM REPLAYGAIN_TRACK_GAIN +0.69 dB
    REM REPLAYGAIN_TRACK_PEAK 0.584290
    INDEX 00 20:25:37
    INDEX 01 20:27:18
  TRACK 08 AUDIO
    TITLE "Theme From Rawhide"
    REM REPLAYGAIN_TRACK_GAIN +1.66 dB
    REM REPLAYGAIN_TRACK_PEAK 0.529633
    INDEX 00 23:40:51
    INDEX 01 23:43:73
  TRACK 09 AUDIO
    TITLE "Minnie The Moocher"
    PERFORMER "Cab Calloway"
    REM REPLAYGAIN_TRACK_GAIN +2.12 dB
    REM REPLAYGAIN_TRACK_PEAK 0.554657
    INDEX 00 26:20:56
    INDEX 01 26:23:00
  TRACK 10 AUDIO
    TITLE "Sweet Home Chicago"
    REM REPLAYGAIN_TRACK_PEAK 0.710358
    INDEX 00 29:45:71
    INDEX 01 29:49:63
  TRACK 11 AUDIO
    TITLE "Jailhouse Rock"
    REM REPLAYGAIN_TRACK_GAIN +0.23 dB
    REM REPLAYGAIN_TRACK_PEAK 0.546844
    INDEX 00 37:39:74
    INDEX 01 37:41:18
Embedded Cue sheet :
REM DATE 1980
REM DISCID 90099B0B
PERFORMER "Various"
FILE "Various - The Blues Brothers.flac" WAVE
  TRACK 01 AUDIO
    PERFORMER "Various"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    PERFORMER "Various"
    INDEX 00 04:09:27
    INDEX 01 04:12:40
  TRACK 03 AUDIO
    PERFORMER "Various"
    INDEX 00 07:58:48
    INDEX 01 08:02:05
  TRACK 04 AUDIO
    PERFORMER "Various"
    INDEX 00 11:07:16
    INDEX 01 11:11:58
  TRACK 05 AUDIO
    PERFORMER "Various"
    INDEX 00 13:59:64
    INDEX 01 14:03:18
  TRACK 06 AUDIO
    PERFORMER "Various"
    INDEX 00 17:25:69
    INDEX 01 17:28:45
  TRACK 07 AUDIO
    TITLE "Think"
    PERFORMER "Various"
    INDEX 00 20:25:37
    INDEX 01 20:27:18
  TRACK 08 AUDIO
    PERFORMER "Various"
    INDEX 00 23:40:51
    INDEX 01 23:43:73
  TRACK 09 AUDIO
    PERFORMER "Various"
    INDEX 00 26:20:56
    INDEX 01 26:23:00
  TRACK 10 AUDIO
    PERFORMER "Various"
    INDEX 00 29:45:71
    INDEX 01 29:49:63
  TRACK 11 AUDIO
    PERFORMER "Various"
    INDEX 00 37:39:74
    INDEX 01 37:41:18
In 1.9.5a version it works !
Can you fix this ?
Sorry for my bad english.
Reply #647
anything i should do for 'winetricks' if i were to try to run this via wine?
Reply #648
i tried running it via wine and got this
Reply #649
Why wine? Mono is supposed to be used for .NET applications. There are no tricks, but FLAC will only work with next version. Of course you can try to set up an external flac encoder/decoder, i haven't tried it. You go to the setting page, decoders tab, select one of the decoders and press 'insert'. Then select flac extension, path to flac and parameters like "-d %I -o -"; Than at extensions tab select flac and set the default decoder to whatever you named it.
CUETools 2.1.6
