Topic: CUETools versions 1.9.5 through 2.1.6 (Read 2026390 times) previous topic - next topic
0 Members and 15 Guests are viewing this topic.
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #651
Can somebody explain to me what "CDDBId mismatch" means exactly plz? When I first started using cuetools I thought that it was due to missing data track, but I don't think so anymore as missing data track is reported separatly. So far I didn't worry much about "CDDBId mismatch" as it seems it is a rare case.
I think I understand that this is a clash between the calculated CDDBId from my files & the database, but I happen to fall on cases where there is a "CDDBId mismatch" & "Disk not present in database" at the same time, so I don't understand anymore. An ID missmatch could be due to missing HTOA, but then how could cuetools detect this & even sometimes reports valid CRC despite CDDBId mismatch?
In the end, I don't understand what "CDDBId mismatch" means & I slowly start to worry because I already have 4 disks like this on my collection & I only passed half of it through cuetools.
Any help is welcomed
Reply #652
well.. i think this is the cause, sauvage.... CDDBId is what freedb.org etc, uses to look up artist/tracknames, etc from... they use their own "identifier" to lookup discs.... most likely, i think CDDBid mismatch means that your CUE file says something like REM DISCID or uses the DISCID tag of the file to lookup that on CDDB. in certain cases, you can have two (or more) discs from different artists  with that same ID. that is, it's not unique. there are several of these "disc id" calculations... freedb, Gracenote, musicbrainz, accuraterip; they're all checksums tied to ID numbers which identify a certain disc.
in any case, what your CUE or embedded tag says the discid is, apparently CUETools deems it to be wrong. I could see this happening two ways. 1) it was one of these cases where it happened to be a totally different artist... or possibly the rip was identified as wrong because it was a later or different pressing.
in the case of the double entry wrong/missing.... i could imagine this situation --- your DISCID says this disk is  band X - CD1. CUETools calculates its AR checksum (different than DISCID), and does not find a match in the database.
i could easily reproduce this by picking a rare cd that is not in the database, then add a random DISCID number to my cue/tag... it'll obviously be a mismatch on the disc id.. and will also not be found in AR database.
so main point is DISCID != AR checksum, they're two totally different things. if it says mismatch, AAAAAA is really BBBBBB... then CueTools has obviously found the correct matching disc in CDDB database, and let you know that. that doesn't necessarily mean that your pressing of that CD is the same as the one submitted...
after thinking about it for a sec, just think of it this way --- this is the most simple way i can put it --- you can have the SAME ALBUM but DIFFERENT PRESSINGS. you know this... CDDB does not. DISCID is not unique to pressings/different offsets (or even the same artist/album!). it ignores offsets, etc.. where is AR does not. AR is more accurate in identifying a disc than CDDB. accuraterip never pops up and asks you "is this disk Tool - Undertow or The Beatles - Yellow Submarine?"
wikipedia: CDDB was designed around the task of identifying entire CDs, not merely single tracks. The identification process involves creating a "discid", a sort of "fingerprint" of a CD created by performing calculations on the track duration information stored in the table-of-contents of the CD  ....  Since identification of CDs is based on the length and order of the tracks, CDDB cannot identify playlists in which the order of tracks has been changed, or compilations of tracks from different CDs. CDDB also cannot distinguish between different CDs that have the same number of tracks and the same track lengths.
so CDDB simple takes into account the CD's TOC basically. as said above, it doesn't care what the data is, as long as the number of tracks and their lengths.
these are my thoughts and may be incomplete or incorrect. i do not know all the technical differences -- BUT i will let the master, Mr. Chudov explain it to us, so we know for sure!
Reply #653
Chinch:
Thks for the hint about the REM DISCID in cue sheet, I completely forgot about it.
I had a closer look a my 4 rips with CDDBId mismatch, it seems that you're pointing me to the right direction: the last part of the AR ID that cuetools calculate is always different than the DISCID in the cue sheet.
For example cuetools calculates [Disc ID: 00149761-00c5921c-b00ba00c]
& in same time the EAC cue sheet indicates REM DISCID C40E1F0E
So the clash is between these two numbers in the cuetools log:
CDDBId mismatch: C40E1F0E vs B00BA00C
So now the question is why does these two ID clash ? The answer that comes to my mind is missing HTOA, the HTOA was maybe used in the EAC cue sheet calculation but disapeared as it was not ripped & now cuetools is missing it ? Am I right ? I think I recall old EAC versions didn't rip HTOA in CDImage, CDDBId mismatch could be an hint of this.
This answer leaves me unsatisfied as I have a rip that have a CDDBId mismatch, but still gives me an accurate result, is it possible ? I thought CRC were tied to an ID ... (my other 3 rips with mismatch are not in database) What does it means ? That there is two commercial version of it one with HTOA & one without ? So despite having destroyed my HTOA I still match on the one without ? It's a bit weird as a rationnal explanation.
Is my self-made explanation correct ? Is there other possible cause of CDDBId mismatch ? Does missing data track have anything to do with CDDBId mismatch ? (I don't think so as IMHO cuetools should report both missing data & CDDBId mismatch at the same time if it was the case, but in the beginning I mixed the two in my mind, so I'd better ask to remove the doubt)
Thks Gregory, if you could clear this
Reply #654
Yes, this is a mismatch between CDDBid calculated by EAC and stored in CUE sheet, and the one calculated by CUETools.
Remember, that the last digit of CDDBId is number of tracks - that's how i usually detect the presense of data track.
In your case the difference is somehow not one, but two tracks. EAC saw 14 tracks, CUETools sees 12.
I have no idea what that means, to be honest. Maybe some wierdness like two data tracks...
CUETools 2.1.6
Reply #655
Thnx for the answers on CDDBId Mismatch Gregory,
today I found something new that I don't understand, I'd like to have your opinion on it ... it's a CD with an hidden track at the end (track 99) (Marilyn Manson - Antichrist Superstar) & 4 sec silence tracks from track  17 to 98, track 17 being a special case it's silence but not empty CRC (there is some data).
Anyway the thing I don't understand are tracks 20 & 36, these two tracks are empty (CRC [00000000]) but result as Partial match ??? how can this happen ??? I don't understand ... it sounds impossible for me, I don't get it.
Here is the (very looong) log:
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: That's what codebox is for![/size][/b]
[Verification date: 04/09/2009 20:07:24]
[Disc ID: 01c6a4f5-62ab4f93-2c122463]
Track [ CRC ] Status
 01 [4b23ce19] (50/233) Accurately ripped
 02 [fa92fa55] (49/236) Accurately ripped
 03 [bc5d380d] (49/236) Accurately ripped
 04 [f9998e90] (49/236) Accurately ripped
 05 [3374440d] (49/236) Accurately ripped
 06 [3d968825] (48/232) Accurately ripped
 07 [9ef2184d] (48/232) Accurately ripped
 08 [0da904b2] (48/230) Accurately ripped
 09 [4c72ce63] (46/230) Accurately ripped
 10 [31355e3d] (46/226) Accurately ripped
 11 [affd1d20] (48/228) Accurately ripped
 12 [8b14ba33] (48/230) Accurately ripped
 13 [5a296fb3] (46/225) Accurately ripped
 14 [94e8fc9e] (47/229) Accurately ripped
 15 [037d4910] (47/224) Accurately ripped
 16 [b00f0484] (47/219) Accurately ripped
 17 [409e21ca] (04/17) Accurately ripped
 18 [00000000] (00/00) No matches
 19 [00000000] (00/00) No matches
 20 [00000000] (01/01) Partial match
 21 [00000000] (00/00) No matches
 22 [00000000] (00/00) No matches
 23 [00000000] (00/00) No matches
 24 [00000000] (00/00) No matches
 25 [00000000] (00/00) No matches
 26 [00000000] (00/00) No matches
 27 [00000000] (00/00) No matches
 28 [00000000] (00/00) No matches
 29 [00000000] (00/00) No matches
 30 [00000000] (00/00) No matches
 31 [00000000] (00/00) No matches
 32 [00000000] (00/00) No matches
 33 [00000000] (00/00) No matches
 34 [00000000] (00/00) No matches
 35 [00000000] (00/00) No matches
 36 [00000000] (01/01) Partial match
 37 [00000000] (00/00) No matches
 38 [00000000] (00/00) No matches
 39 [00000000] (00/00) No matches
 40 [00000000] (00/00) No matches
 41 [00000000] (00/00) No matches
 42 [00000000] (00/00) No matches
 43 [00000000] (00/00) No matches
 44 [00000000] (00/00) No matches
 45 [00000000] (00/00) No matches
 46 [00000000] (00/00) No matches
 47 [00000000] (00/00) No matches
 48 [00000000] (00/00) No matches
 49 [00000000] (00/00) No matches
 50 [00000000] (00/00) No matches
 51 [00000000] (00/00) No matches
 52 [00000000] (00/00) No matches
 53 [00000000] (00/00) No matches
 54 [00000000] (00/00) No matches
 55 [00000000] (00/00) No matches
 56 [00000000] (00/00) No matches
 57 [00000000] (00/00) No matches
 58 [00000000] (00/00) No matches
 59 [00000000] (00/00) No matches
 60 [00000000] (00/00) No matches
 61 [00000000] (00/00) No matches
 62 [00000000] (00/00) No matches
 63 [00000000] (00/00) No matches
 64 [00000000] (00/00) No matches
 65 [00000000] (00/00) No matches
 66 [00000000] (00/00) No matches
 67 [00000000] (00/00) No matches
 68 [00000000] (00/00) No matches
 69 [00000000] (00/00) No matches
 70 [00000000] (00/00) No matches
 71 [00000000] (00/00) No matches
 72 [00000000] (00/00) No matches
 73 [00000000] (00/00) No matches
 74 [00000000] (00/00) No matches
 75 [00000000] (00/00) No matches
 76 [00000000] (00/00) No matches
 77 [00000000] (00/00) No matches
 78 [00000000] (00/00) No matches
 79 [00000000] (00/00) No matches
 80 [00000000] (00/00) No matches
 81 [00000000] (00/00) No matches
 82 [00000000] (00/00) No matches
 83 [00000000] (00/00) No matches
 84 [00000000] (00/00) No matches
 85 [00000000] (00/00) No matches
 86 [00000000] (00/00) No matches
 87 [00000000] (00/00) No matches
 88 [00000000] (00/00) No matches
 89 [00000000] (00/00) No matches
 90 [00000000] (00/00) No matches
 91 [00000000] (00/00) No matches
 92 [00000000] (00/00) No matches
 93 [00000000] (00/00) No matches
 94 [00000000] (00/00) No matches
 95 [00000000] (00/00) No matches
 96 [00000000] (00/00) No matches
 97 [00000000] (00/00) No matches
 98 [00000000] (00/00) No matches
 99 [39bceae7] (45/199) Accurately ripped
Offsetted by -1992:
 01 [93bee790] (05/233) Accurately ripped
 02 [382a6ade] (05/236) Accurately ripped
 03 [db79d6cf] (05/236) Accurately ripped
 04 [fba7b773] (05/236) Accurately ripped
 05 [8764309a] (05/236) Accurately ripped
 06 [21f865f6] (05/232) Accurately ripped
 07 [ded2e896] (05/232) Accurately ripped
 08 [3e9837fa] (05/230) Accurately ripped
 09 [8c226b77] (05/230) Accurately ripped
 10 [c0e75c5a] (05/226) Accurately ripped
 11 [180c855b] (05/228) Accurately ripped
 12 [5eb53dab] (05/230) Accurately ripped
 13 [5a51ab4c] (05/225) Accurately ripped
 14 [22707ff5] (05/229) Accurately ripped
 15 [730531e6] (05/224) Accurately ripped
 16 [d6b61fad] (05/219) Accurately ripped
 17 [06583633] (17/17) Partial match
 99 [775ef473] (04/199) Accurately ripped
Offsetted by -1345:
 01 [32c0890a] (05/233) Accurately ripped
 02 [255c6072] (05/236) Accurately ripped
 03 [765b3aa2] (05/236) Accurately ripped
 04 [d8e622f2] (05/236) Accurately ripped
 05 [96f1a995] (05/236) Accurately ripped
 06 [f43a2bcf] (05/232) Accurately ripped
 07 [58ba3a5a] (05/232) Accurately ripped
 08 [a530d2e3] (05/230) Accurately ripped
 09 [f4d4c81b] (05/230) Accurately ripped
 10 [04cae13e] (05/226) Accurately ripped
 11 [b92d4c37] (05/228) Accurately ripped
 12 [ad1b2e23] (05/230) Accurately ripped
 13 [c8a4ab62] (05/225) Accurately ripped
 14 [f5e4633b] (05/229) Accurately ripped
 15 [4fc7c95b] (05/224) Accurately ripped
 16 [6885b061] (05/219) Accurately ripped
 17 [2186eff8] (17/17) Partial match
 99 [208c3fe9] (05/199) Accurately ripped
Offsetted by -1328:
 01 [f55ee0a9] (17/233) Accurately ripped
 02 [822374e5] (17/236) Accurately ripped
 03 [7eb5536f] (17/236) Accurately ripped
 04 [b0aff29f] (17/236) Accurately ripped
 05 [c391e6f8] (18/236) Accurately ripped
 06 [48162003] (17/232) Accurately ripped
 07 [940f5e9f] (17/232) Accurately ripped
 08 [d8f326e2] (17/230) Accurately ripped
 09 [27284532] (17/230) Accurately ripped
 10 [1e059214] (17/226) Accurately ripped
 11 [2ab9565f] (17/228) Accurately ripped
 12 [dea566c2] (17/230) Accurately ripped
 13 [19f804af] (17/225) Accurately ripped
 14 [bd9364c2] (17/229) Accurately ripped
 15 [fd699f25] (17/224) Accurately ripped
 16 [cdab79bf] (17/219) Accurately ripped
 17 [9adb8056] (17/17) Partial match
 99 [2327326f] (15/199) Accurately ripped
Offsetted by -747:
 01 [692f161f] (02/233) Accurately ripped
 02 [4218ab29] (00/236) No matches
 03 [c0035400] (00/236) No matches
 04 [747baa57] (00/236) No matches
 05 [3900408b] (00/236) No matches
 06 [d088dc97] (00/232) No matches
 07 [4dc24a0d] (00/232) No matches
 08 [e002b7ed] (00/230) No matches
 09 [2eed2694] (00/230) No matches
 10 [88c14c8f] (00/226) No matches
 11 [f98cdac7] (00/228) No matches
 12 [ba577135] (00/230) No matches
 13 [b280f684] (00/225) No matches
 14 [b9f028f1] (00/229) No matches
 15 [63334577] (00/224) No matches
 16 [4d14febd] (00/219) No matches
 17 [cf8429c8] (17/17) Partial match
 99 [513a0573] (00/199) No matches
Offsetted by -681:
 01 [819f8dfa] (29/233) Accurately ripped
 02 [6df41e52] (31/236) Accurately ripped
 03 [17f41ef9] (31/236) Accurately ripped
 04 [5302b1f5] (30/236) Accurately ripped
 05 [03f671ec] (31/236) Accurately ripped
 06 [d02ae344] (31/232) Accurately ripped
 07 [2797ed48] (31/232) Accurately ripped
 08 [3f8bc1cb] (30/230) Accurately ripped
 09 [c286a974] (30/230) Accurately ripped
 10 [9f1a4382] (31/226) Accurately ripped
 11 [77c36958] (29/228) Accurately ripped
 12 [d802ded1] (30/230) Accurately ripped
 13 [bb808006] (28/225) Accurately ripped
 14 [fe53b4a7] (30/229) Accurately ripped
 15 [b79e2f61] (30/224) Accurately ripped
 16 [23b8519f] (30/219) Accurately ripped
 17 [8b268f50] (17/17) Partial match
 99 [9deef9a5] (25/199) Accurately ripped
Offsetted by -664:
 01 [9a0bf154] (10/233) Accurately ripped
 02 [6b04050a] (10/236) Accurately ripped
 03 [36388002] (10/236) Accurately ripped
 04 [38f786c4] (10/236) Accurately ripped
 05 [19001e28] (10/236) Accurately ripped
 06 [21cd9f2d] (10/232) Accurately ripped
 07 [ababe751] (10/232) Accurately ripped
 08 [734e15ca] (10/230) Accurately ripped
 09 [733e868d] (10/230) Accurately ripped
 10 [5f487a6d] (10/226) Accurately ripped
 11 [9f1bbb02] (10/228) Accurately ripped
 12 [e0c94f5b] (10/230) Accurately ripped
 13 [e3e4b951] (10/225) Accurately ripped
 14 [68a6faf0] (10/229) Accurately ripped
 15 [f63bfc7b] (10/224) Accurately ripped
 16 [58f546c0] (09/219) Accurately ripped
 17 [9c7b209f] (17/17) Partial match
 99 [f122cac5] (07/199) Accurately ripped
Offsetted by 760:
 01 [8beb03eb] (06/233) Partial match
 02 [ed446133] (06/236) Accurately ripped
 03 [3260126e] (06/236) Accurately ripped
 04 [c40ec9a6] (06/236) Accurately ripped
 05 [451739ed] (06/236) Accurately ripped
 06 [2bdea9dc] (06/232) Accurately ripped
 07 [fb2801c3] (06/232) Accurately ripped
 08 [9011193a] (06/230) Accurately ripped
 09 [439a7be3] (06/230) Accurately ripped
 10 [39daa826] (06/226) Accurately ripped
 11 [490d6594] (06/228) Accurately ripped
 12 [7978cdc2] (05/230) Accurately ripped
 13 [26c39089] (06/225) Accurately ripped
 14 [f548e9f8] (06/229) Accurately ripped
 15 [4a96d80f] (05/224) Accurately ripped
 16 [4e09c7bd] (05/219) Partial match
 17 [fbcaa9b6] (17/17) Partial match
 99 [625e921e] (05/199) Partial match
Offsetted by 872:
 01 [dd639869] (15/233) Accurately ripped
 02 [3f31f6d5] (16/236) Accurately ripped
 03 [b3d7b32b] (15/236) Accurately ripped
 04 [dd915cfe] (15/236) Accurately ripped
 05 [990b68d3] (15/236) Accurately ripped
 06 [a02d3c56] (15/232) Accurately ripped
 07 [cfd60456] (16/232) Accurately ripped
 08 [f4206fca] (15/230) Accurately ripped
 09 [da84947b] (16/230) Accurately ripped
 10 [c3348744] (15/226) Accurately ripped
 11 [011f075e] (14/228) Accurately ripped
 12 [8db0c3ae] (15/230) Accurately ripped
 13 [41a9f043] (15/225) Accurately ripped
 14 [f47f871e] (15/229) Accurately ripped
 15 [6ebdf21a] (15/224) Accurately ripped
 16 [3ddb6353] (14/219) Accurately ripped
 17 [2e0ec70d] (02/17) Accurately ripped
 99 [7bf9ddc2] (11/199) Accurately ripped
Offsetted by 1427:
 01 [1fbb47f9] (08/233) Partial match
 02 [0b6f9d2b] (08/236) Accurately ripped
 03 [eb8c0bba] (08/236) Accurately ripped
 04 [353f656f] (08/236) Accurately ripped
 05 [f251f9b0] (08/236) Accurately ripped
 06 [6f73d04e] (07/232) Accurately ripped
 07 [a5c9d2b7] (08/232) Accurately ripped
 08 [51ac714f] (08/230) Accurately ripped
 09 [2531f314] (08/230) Accurately ripped
 10 [951e7c9e] (08/226) Accurately ripped
 11 [5822f128] (08/228) Accurately ripped
 12 [5c492651] (08/230) Accurately ripped
 13 [7771265a] (08/225) Accurately ripped
 14 [48394fe3] (08/229) Accurately ripped
 15 [46828872] (07/224) Accurately ripped
 16 [71345b93] (08/219) Partial match
 17 [fced92bf] (17/17) Partial match
 99 [bac2a86f] (07/199) Partial match
Offsetted by 2015:
 01 [f3492269] (02/233) Partial match
 02 [80c531d3] (02/236) Accurately ripped
 03 [54f027e8] (02/236) Accurately ripped
 04 [edc695ec] (02/236) Accurately ripped
 05 [bb2ee106] (02/236) Accurately ripped
 06 [5930e438] (02/232) Accurately ripped
 07 [828d0f5c] (02/232) Accurately ripped
 08 [5efcf7c3] (02/230) Accurately ripped
 09 [1406df21] (02/230) Accurately ripped
 10 [aa50cc96] (02/226) Accurately ripped
 11 [6e95529e] (02/228) Accurately ripped
 12 [f6bf153e] (02/230) Accurately ripped
 13 [8482d80b] (02/225) Accurately ripped
 14 [fd9126a2] (02/229) Accurately ripped
 15 [5fb4d835] (02/224) Accurately ripped
 16 [6a386099] (02/219) Partial match
 17 [7ae3f8d2] (17/17) Partial match
 99 [63586307] (02/199) Partial match
Offsetted by 2086:
 01 [17be47e3] (69/233) Partial match
 02 [41195d37] (69/236) Accurately ripped
 03 [2551de18] (71/236) Accurately ripped
 04 [554aa117] (70/236) Accurately ripped
 05 [9d820193] (70/236) Accurately ripped
 06 [0dd66af8] (69/232) Accurately ripped
 07 [bacc5686] (67/232) Accurately ripped
 08 [5546b0ec] (67/230) Accurately ripped
 09 [1a70a33b] (69/230) Accurately ripped
 10 [565fa4d9] (65/226) Accurately ripped
 11 [11e1f813] (68/228) Accurately ripped
 12 [6e436b40] (69/230) Accurately ripped
 13 [7e58dbe0] (67/225) Accurately ripped
 14 [18368019] (67/229) Accurately ripped
 15 [970c5ea4] (65/224) Accurately ripped
 16 [ee476e21] (62/219) Partial match
 17 [fc300961] (08/17) Accurately ripped
 99 [06811b15] (62/199) Partial match
Offsetted by 2339:
 01 [53dbdaa2] (02/233) Accurately ripped
 02 [334adc12] (02/236) Accurately ripped
 03 [49551e7a] (02/236) Accurately ripped
 04 [921c879f] (02/236) Accurately ripped
 05 [c7f7ae45] (02/236) Accurately ripped
 06 [487f2340] (02/232) Accurately ripped
 07 [90281100] (02/232) Accurately ripped
 08 [ee2956bf] (02/230) Accurately ripped
 09 [cb13a0a1] (02/230) Accurately ripped
 10 [f8db0b4c] (02/226) Accurately ripped
 11 [75e5e713] (02/228) Accurately ripped
 12 [43ae1737] (02/230) Accurately ripped
 13 [e03d641b] (02/225) Accurately ripped
 14 [7b1c6402] (02/229) Accurately ripped
 15 [51476228] (02/224) Accurately ripped
 16 [ce04fb25] (02/219) Accurately ripped
 17 [1f81bde3] (17/17) Partial match
 99 [0e9b378f] (02/199) Accurately ripped
Offsetted by 2357:
 01 [74671628] (15/233) Accurately ripped
 02 [27908390] (16/236) Accurately ripped
 03 [66a6f3c3] (15/236) Accurately ripped
 04 [d23870d8] (15/236) Accurately ripped
 05 [80379e36] (15/236) Accurately ripped
 06 [7ac52300] (15/232) Accurately ripped
 07 [f0db3f85] (15/232) Accurately ripped
 08 [d9abcdcd] (15/230) Accurately ripped
 09 [efafcbec] (14/230) Accurately ripped
 10 [ba2019af] (14/226) Accurately ripped
 11 [654b0a33] (14/228) Accurately ripped
 12 [8969d345] (14/230) Accurately ripped
 13 [b66616e7] (14/225) Accurately ripped
 14 [7376584e] (15/229) Accurately ripped
 15 [466f08c7] (14/224) Accurately ripped
 16 [375cc1c5] (13/219) Accurately ripped
 17 [f1f09860] (03/17) Accurately ripped
 99 [42c998b3] (09/199) Accurately ripped
Offsetted by 2369:
 01 [9b448147] (00/233) No matches
 02 [57135899] (00/236) No matches
 03 [6caf398c] (00/236) No matches
 04 [d171a773] (02/236) Accurately ripped
 05 [e347cc46] (00/236) No matches
 06 [8a92025e] (00/232) No matches
 07 [c43d4cdb] (00/232) No matches
 08 [76ad7281] (00/230) No matches
 09 [98d321ba] (00/230) No matches
 10 [a405b51a] (00/226) No matches
 11 [8460d6ae] (00/228) No matches
 12 [f4335489] (00/230) No matches
 13 [dbbec2e1] (00/225) No matches
 14 [aef5aad4] (00/229) No matches
 15 [b25fc542] (00/224) No matches
 16 [e22562ba] (00/219) No matches
 17 [c23ec634] (17/17) Partial match
 99 [65932ecb] (00/199) No matches
Track [ CRC32  ] [W/O NULL]
 -- [8DFCE543] [C1843DC7]
 01 [6E92FC4E] [48268136]
 02 [9F44ABAB] [82640D64]
 03 [06EA5868] [C35DD86F]
 04 [78556267] [2AE7FD72]
 05 [7ADFA01B] [B99BDBA4]
 06 [8813D7C6] [0B07FFBD]
 07 [7EC72AF0] [E4003279]
 08 [9CF0092B] [2056A58A]
 09 [BFCF1CA8] [8A674008]
 10 [2D24E227] [1469E6AD]
 11 [D6E9C8C4] [1D707D2F]
 12 [E31E2909] [A3B4F359]
 13 [D506A265] [18DC6E60]
 14 [5F03E5AA] [BC30712B]
 15 [184635CB] [375570FA]
 16 [FC022D76] [75A27F67]
 17 [A180A5B8] [B5641F62]
 18 [02864C0E] [00000000] W/O NULL
 19 [02864C0E] [00000000] W/O NULL
 20 [02864C0E] [00000000] W/O NULL
 21 [02864C0E] [00000000] W/O NULL
 22 [02864C0E] [00000000] W/O NULL
 23 [02864C0E] [00000000] W/O NULL
 24 [02864C0E] [00000000] W/O NULL
 25 [02864C0E] [00000000] W/O NULL
 26 [02864C0E] [00000000] W/O NULL
 27 [02864C0E] [00000000] W/O NULL
 28 [02864C0E] [00000000] W/O NULL
 29 [02864C0E] [00000000] W/O NULL
 30 [02864C0E] [00000000] W/O NULL
 31 [02864C0E] [00000000] W/O NULL
 32 [02864C0E] [00000000] W/O NULL
 33 [02864C0E] [00000000] W/O NULL
 34 [02864C0E] [00000000] W/O NULL
 35 [02864C0E] [00000000] W/O NULL
 36 [02864C0E] [00000000] W/O NULL
 37 [02864C0E] [00000000] W/O NULL
 38 [02864C0E] [00000000] W/O NULL
 39 [02864C0E] [00000000] W/O NULL
 40 [02864C0E] [00000000] W/O NULL
 41 [02864C0E] [00000000] W/O NULL
 42 [02864C0E] [00000000] W/O NULL
 43 [02864C0E] [00000000] W/O NULL
 44 [02864C0E] [00000000] W/O NULL
 45 [02864C0E] [00000000] W/O NULL
 46 [02864C0E] [00000000] W/O NULL
 47 [02864C0E] [00000000] W/O NULL
 48 [02864C0E] [00000000] W/O NULL
 49 [02864C0E] [00000000] W/O NULL
 50 [02864C0E] [00000000] W/O NULL
 51 [02864C0E] [00000000] W/O NULL
 52 [02864C0E] [00000000] W/O NULL
 53 [02864C0E] [00000000] W/O NULL
 54 [02864C0E] [00000000] W/O NULL
 55 [02864C0E] [00000000] W/O NULL
 56 [02864C0E] [00000000] W/O NULL
 57 [02864C0E] [00000000] W/O NULL
 58 [02864C0E] [00000000] W/O NULL
 59 [02864C0E] [00000000] W/O NULL
 60 [02864C0E] [00000000] W/O NULL
 61 [02864C0E] [00000000] W/O NULL
 62 [02864C0E] [00000000] W/O NULL
 63 [02864C0E] [00000000] W/O NULL
 64 [02864C0E] [00000000] W/O NULL
 65 [02864C0E] [00000000] W/O NULL
 66 [02864C0E] [00000000] W/O NULL
 67 [02864C0E] [00000000] W/O NULL
 68 [02864C0E] [00000000] W/O NULL
 69 [02864C0E] [00000000] W/O NULL
 70 [02864C0E] [00000000] W/O NULL
 71 [02864C0E] [00000000] W/O NULL
 72 [02864C0E] [00000000] W/O NULL
 73 [02864C0E] [00000000] W/O NULL
 74 [02864C0E] [00000000] W/O NULL
 75 [02864C0E] [00000000] W/O NULL
 76 [02864C0E] [00000000] W/O NULL
 77 [02864C0E] [00000000] W/O NULL
 78 [02864C0E] [00000000] W/O NULL
 79 [02864C0E] [00000000] W/O NULL
 80 [02864C0E] [00000000] W/O NULL
 81 [02864C0E] [00000000] W/O NULL
 82 [02864C0E] [00000000] W/O NULL
 83 [02864C0E] [00000000] W/O NULL
 84 [02864C0E] [00000000] W/O NULL
 85 [02864C0E] [00000000] W/O NULL
 86 [02864C0E] [00000000] W/O NULL
 87 [02864C0E] [00000000] W/O NULL
 88 [02864C0E] [00000000] W/O NULL
 89 [02864C0E] [00000000] W/O NULL
 90 [02864C0E] [00000000] W/O NULL
 91 [02864C0E] [00000000] W/O NULL
 92 [02864C0E] [00000000] W/O NULL
 93 [02864C0E] [00000000] W/O NULL
 94 [02864C0E] [00000000] W/O NULL
 95 [02864C0E] [00000000] W/O NULL
 96 [02864C0E] [00000000] W/O NULL
 97 [02864C0E] [00000000] W/O NULL
 98 [79914BAF] [00000000] W/O NULL
 99 [823FBB6A] [2A15BCBE]
Reply #656
The database has entries for those tracks. I assume in someone's rip they were not entirely silent due to ripping errors.
CUETools 2.1.6
Reply #657
Thks, I didn't thought about this possibility, at first it's quite funny to think that scratches produces ghost tracks  ... but then it's annoying as even if future cuetools version reports empty tracks as accurate, my rip will not be reported as accurate... Is there anyway Spoon can purge such results ? Wouldn't something like keeping record for empty tracks & purge ghost tracks if 99% of silence tracks disagree with a lone non-silence track help ? I mean it should be possible to purge such results if the database would keep track of silence tracks but I don't think it does, does it ?
Reply #658
CUETools is great, thanks so much for this!
Suggestion: for none output, allow it to convert even if original files aren't there.
Edit: I get "Could not load file or assembly 'CUETools.Codecs.TTA" for 2.0.4a, and I installed the vcredist_x86.exe already, any other reasons this should happen?
Reply #659
When I encode corrected offsets tracks CUETools rightly informs me that some samples are going to be lost:
Write offset settings is non-zero which will cause some samples to be discarded.
If I verify the generated tracks with AccurateRipDB and all the tracks are 100% accurate (with high confidence), can I say I have the perfect copy of the disc, even if there are lost samples and new empty samples created by the offset correction?
Reply #660
Yes, because the "discarded samples" are most probably zeros.
Reply #661
If 100% of tracks are Accurate with confidency 2 on the same target offset then it is not a probability it is a certainty, because the all the CRC match with the target pressing.
Reply #662
Gregory, are there any plans to implement multi-threaded processing? Multi-threaded decode/verify and multi-threaded encode?
Reply #663
As far as I understund real multi-threading as nothing to do with cuetools, it must be supported in the external command line for cuetools to support it. Like F2K there can be the trick to launch several tracks at once, but the purpose of cuetools is to work on whole albums so it's the opposite of its philosophy IMHO. Furthermore it may be (I dunno & I'm guessing) a real headache to code with non-silence offset which affect the split point. People buying quad core should wonder why they buy a quad core before buying. Instead of annoying every developper with multithreading ... that's the exact reason why I won't buy a Core I5 but I am waiting for Core I3. For the same price, I'd rather buy a Core I3 & a SSD than a Core I5 alone ... the only multithreaded software I use is x264.
Reply #664
OK I've solved my problem.
I have only 1 question about CUETools now. If I'm splitting a CUE with a 30 second pre-gap, as shown below, is there any way to have it put "PREGAP" in the resulting CUE sheet as EAC would, rather than make an extra 30 second file [of silence] called HTOA, as CUETools keeps doing?
FILE "Mind~Flux - Body-Beat-Box.ape" WAVE
  TRACK 01 AUDIO
    TITLE "Warm-Up"
    PERFORMER "Mind Flux"
    INDEX 00 00:00:00
    INDEX 01 00:00:30
Thanks...
Reply #665
I don't know about anyone else, but I'm not really liking the new interface in the latest version (and versions after 2.0.2a). I've tried really hard to adjust to it, but it just looks and feels too awkward. Version 2.0.2a matches my preferences perfectly, and it has all the qualities of a simple, minimal application. All the important features are all located in the main window, none of them disappearing or reappearing when choosing different options, and it just simply performs more like a standard Windows application. I would never assume 2.0.2a was developed with .NET just by using it, however with the newer versions, it's far too apparent.
Some requests:
I normally don't do batch jobs and just convert albums one at a time when I need to, and I would very much prefer to have some sort of a Browse... button that would open up a general Open window such as the one below. Sometimes I want to be able to manually type in the location of the folder, instead of having to search through and click multiple tick boxes.
Also, I noticed the option to place converted files in a subfolder has been removed in later versions. Could that option be put back in? I usually have an Explorer window open where the original files are stored while CUETools is converting, and it's convenient to have the converted files located near the original files.
Thank you
Reply #666
i have a album in ape files that i am trying to convert flac files,everytime i try to use CUETools, i insert the cdimage cue file & it says unsupprted audio type.
can a expert of the CUETools program please advise me.
Reply #667
Could be single channel files instead of the normal 2 channel files.
Some people convert songs in mono to one channel with p.e. adobe audition or audacity.
If that is the case cuetools gives also that kind of error.
Reply #668
If you have an explorer window open, why don't you drag 'n drop the directories?
I always have an explorer window open and imho drag'n drop is much faster then any browse window.
I like the lay-out very much (only problem is the overwrite warning of logfiles I would like to get rid of)
This option is still there: use the template pull down menu and choose: [%directoryname%\]new[%unique%]\%filename%.cue
Reply #669
I have been using cuetools since 1.9.5a and I like the new UI layout very much.
I run windows XP in 1440x900 with a custom DPI setting of 115% (110 dpi) and most of the
UI problems are gone with this version and the ones left have been documented (thanks sauvage78  ).
I have used cuetools only to create flac files but today I created alac files for the first time
(using ffmpeg svn 19874) and cuetools did not write accuraterip tags to the alac files (using the same options as flac).
Is there an additional parameter that I am missing ? thanks.
Reply #670
I created alac files for the first time (using ffmpeg svn 19874) and cuetools did not write accuraterip tags to the alac files (using the same options as flac).
I have tested the buitin encoders (flac, ape) and some additional external encoders (lame, Nero). The external ones don't seem to write accuraterip tags, so I am guessing this is a limitation of the external encoders ?
cheers
Reply #671
Hello, Thanks a lot for this wonderful tool.
I have tried the latest, but found it's gui to be too 'basic'/confusing,
& the foobar type variables are unknown to me so I settled on CUETOOLS 2.01.
-Are there any drawbacks to using v 2.01, reliability / Format Wise?
Also, Can I Define a PROXY somewhere so I can use it with a proxy from a non internet connected PC?
Reply #672
It's been almost 4 years since the first Intel dual-core part. I don't think multi-core architecture is going away, and only going to become more and more critical to software design in the future.
I'm sure a lot of people had the same feelings when graphical desktop environments started becoming popular, and all the programs had to be changed to support Windows or X11. At this point, not designing for multi-core is a sure way for your program to become obsolete relatively quickly.
Is your perfect hearing worth <$200? -- USE EAR PLUGS
Reply #673
Well indeed heavy multi-threading is the future, but what I meant is that actually a lightly overclocked 32mn dual core will beat a basic 45mn quad core for the same heat & power consumption (or be very near). [for exemple lighly overclocked Core I3 530 Vs basic Athlon II X4 620] So in the end, multi-threading is only really great if you already own a quad-core, if you don't there is no need to hurry buying a quad-core. Multi-threading will come naturally to developper when quad-core will swallow the low end CPU market, which will happen very soon.
Don't get me wrong I would love a multi-threaded Cuetools, it's just that I think that there is more important missing features to code in Cuetools.
Reply #674
If I had to gamble, I would say you attempted feeding cuetools with a 48 khz file or similar, ie not a 16 bit 44.1 file, check the files audio properties.
