Topic: foo_playlist_tree_mod (Read 140640 times) previous topic - next topic
Reply #100
Although I have to check, why it doesn't work, you should better use %codec% IS mp3 for that purpose. This works.
Reply #101
Is there a chance for playlist tree for DUI?
Reply #102
It is currently not planned.
Reply #103
%codec% IS mp3 works great, thanks for the hint!!
Tim
Reply #104
Ok, so now this is working there is one bit I'm just not able to figure. I want to limit a playlist to a particular size, but also want to exclude anything other than MP3s. Here's the basic query:
(let ((total-size 0))
  (for-each-db-entry
  (lambda (handle)
    (let ((size (get-file-size handle)))
      (if (< (+ size total-size) 20000000000)
     (begin
       (add-node
         handle
         (list (format-title handle "%artist%")
          (format-title handle "%album%")
          (format-title handle "%title%")))
       (set! total-size (+ total-size size))))))
  "%rating% GREATER 2"
  "$rand()"))
This works great. But, the bit limiting to mp3 is the clincher & I can't seem to get the right syntax going. I've tried adding:
  "$ext(%path%) IS mp3"
  "$ext(%_path%) IS mp3"
  "$ext(%path%)" IS mp3
And everything else I can think of but no joy. Of course, $ext(%path%) IS mp3 works fine in normal queries, but I can't figure out the right syntax in @scheme queries, can someone tell me the right syntax here?
Tim
Ok, so the original reason I was trying to limit to mp3 was to avoid cue files being part of the result, for whatever reason the %codec% IS mp3 doesn't work to keep those out, I guess maybe cuz the original file is still mp3.
But, I finally figured out the correct syntax, so posting it here:
    "%rating% GREATER 3 AND \"$ext(%path%)\" IS mp3 AND %length_seconds% GREATER 1800 AND %genre% IS vocal trance"
ie, have to put the $ext(%path%) in escaped quotes.
Tim
Reply #105
I'm getting a fairly consistent crash in this component when trying to form a query that uses a titleformat tag coming from the foo_customdb database. For example, I have a RATING field defined in my foo_customdb, which translates to the %rating% titleformat tag. If I try to make a playlist tree query with the CRITERIA set to something like "%rating% GREATER 1", foobar will crash about 30% of the time when updating the query. The crash report says:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 011A1945h
Access violation, operation: read, address: 00000000h
Last win32 error: 2
Call path:
entry=>app_mainloop=>titleformat_object::run
Reply #106
I can't reproduce it here. Please, post the full report enclosed in codebox tags.
Reply #107
Sure, here's the full crash report:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01A01945h
Last win32 error: 2
Call path:
Code bytes (01A01945h):
01A01905h:  C7 06 14 59 A8 01 89 75 F0 89 46 04 89 46 08 89
01A01915h:  46 0C FF 75 0C 89 45 FC FF 75 08 89 46 10 E8 7E
01A01925h:  00 00 00 8B 4D F4 8B C6 5E 64 89 0D 00 00 00 00
01A01935h:  C9 C2 08 00 33 C0 39 44 24 08 76 11 8B 4C 24 04
01A01945h:  80 3C 08 00 74 07 40 3B 44 24 08 72 EF C3 E9 E1
01A01955h:  FF FF FF 56 8B 74 24 10 85 F6 76 13 8B 4C 24 08
01A01965h:  8B 44 24 0C 2B C1 8A 14 08 88 11 41 4E 75 F7 5E
01A01975h:  C3 56 57 8B 7C 24 10 8D 47 01 50 8B F1 E8 BB 01
Stack (0012EF4Ch):
0012EF2Ch:  7750051A 0158F7E0 0158F7E0 77DDEDF1
0012EF3Ch:  00000000 0158F800 00000000 00000000
0012EF4Ch:  01A015DB 00000000 FFFFFFFF 01A9A3A0
0012EF5Ch:  01A06C9E 01AB4398 01A1FA61 01AB4398
0012EF6Ch:  01A0157E 0012F034 01A84248 FFFFFFFF
0012EF7Ch:  0012F040 01A5DE6A 00000000 FFFFFFFF
0012EF8Ch:  6E4136DD FFFFFFFE 01AB2660 02CFA598
0012EF9Ch:  01AB2660 7C91B24B 0001041C 01AB5730
0012EFACh:  0012EF08 0001F0D0 0012EFF4 7C900030
0012EFBCh:  7C910060 FFFFFFFF 7C91005D 01A70146
0012EFCCh:  01AB0000 00000000 01A70165 6E413699
0012EFDCh:  00000000 0012F070 00000008 0012F08C
0012EFECh:  0012EFD8 00407B87 0012F080 00000000
0012EFFCh:  01A858DC 01AB4428 00000002 00000002
0012F00Ch:  00000001 01A858DC 01AB7BC8 0000005F
0012F01Ch:  00000080 0000005E 00000064 01AB7C88
0012F02Ch:  01A9A3A0 01474F3F 0012F080 01A833E3
0012F03Ch:  00000002 0012F08C 01A5E229 00000008
0012F04Ch:  02D01110 0012F06C 6E413611 0012F068
0012F05Ch:  0012F04C 01A9A3A0 01A9A394 0012F04C
Registers:
EAX: 00000000, EBX: 00000008, ECX: 00000000, EDX: 01A01574
ESI: 0012F06C, EDI: 0012F0D0, EBP: 0012EF7C, ESP: 0012EF4C
Crash location:
Module: foo_customdb
Offset: 1945h
Loaded modules:
foobar2000                      loaded at 00400000h - 005BA000h
ntdll                            loaded at 7C900000h - 7C9B2000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
DSOUND                          loaded at 73F10000h - 73F6C000h
ole32                            loaded at 774E0000h - 7761D000h
VERSION                          loaded at 77C00000h - 77C08000h
WINMM                            loaded at 76B40000h - 76B6D000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 76C90000h - 76CB8000h
dbghelp                          loaded at 59A60000h - 59B01000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
PowerMenuHook                    loaded at 003A0000h - 003B3000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B15000h
MSASN1                          loaded at 77B20000h - 77B32000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_cdda                        loaded at 00AF0000h - 00B3E000h
foo_input_std                    loaded at 00F40000h - 0108E000h
foo_dop                          loaded at 01090000h - 0123C000h
SETUPAPI                        loaded at 77920000h - 77A13000h
gdiplus                          loaded at 4EC50000h - 4EDFB000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
QUARTZ                          loaded at 74810000h - 7497E000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_ui_std                      loaded at 01290000h - 0139E000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_rgscan                      loaded at 013C0000h - 0140F000h
foo_jesus                        loaded at 01450000h - 01477000h
foo_playlist_tree_mod            loaded at 01480000h - 01500000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 01520000h - 015C4000h
foo_audioscrobbler              loaded at 01610000h - 01643000h
foo_dsp_std                      loaded at 01670000h - 016B9000h
foo_albumlist                    loaded at 016E0000h - 0173C000h
foo_skip                        loaded at 01760000h - 01781000h
foo_converter                    loaded at 017B0000h - 01821000h
foo_ui_columns                  loaded at 01850000h - 019DB000h
foo_customdb                    loaded at 01A00000h - 01AA5000h
foo_fileops                      loaded at 01AC0000h - 01B08000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
CFNetwork                        loaded at 05500000h - 05599000h
WININET                          loaded at 3D930000h - 3DA16000h
Normaliz                        loaded at 021B0000h - 021B9000h
urlmon                          loaded at 78130000h - 78263000h
iertutil                        loaded at 3DFD0000h - 3E1B8000h
CoreFoundation                  loaded at 055A0000h - 0566A000h
MSVCR80                          loaded at 056C0000h - 0575B000h
pthreadVC2                      loaded at 021D0000h - 021E0000h
objc                            loaded at 05860000h - 0587C000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
icuin40                          loaded at 05980000h - 05A7D000h
icuuc40                          loaded at 05D20000h - 05E01000h
icudt40                          loaded at 4AD00000h - 4BA5B000h
ASL                              loaded at 05E60000h - 05E70000h
SQLite3                          loaded at 05E80000h - 05EE3000h
zlib1                            loaded at 05F00000h - 05F13000h
iphlpapi                        loaded at 76D60000h - 76D79000h
iTunesMobileDevice              loaded at 062D0000h - 063E9000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
Stack dump analysis:
Address: 01A015DBh (foo_customdb+15DBh)
Address: 01A9A3A0h (foo_customdb+9A3A0h)
Address: 01A06C9Eh (foo_customdb+6C9Eh)
Address: 01A1FA61h (foo_customdb+1FA61h)
Address: 01A0157Eh (foo_customdb+157Eh)
Address: 01A84248h (foo_customdb+84248h)
Address: 01A5DE6Ah (foo_customdb+5DE6Ah)
Address: 7C91B24Bh (ntdll+1B24Bh), symbol: "RtlpWaitForCriticalSection" (+8Ch)
Address: 7C900030h (ntdll+30h)
Address: 7C910060h (ntdll+10060h), symbol: "RtlFreeHeap" (+133h)
Address: 7C91005Dh (ntdll+1005Dh), symbol: "RtlFreeHeap" (+130h)
Address: 01A70146h (foo_customdb+70146h)
Address: 01A70165h (foo_customdb+70165h)
Address: 00407B87h (foobar2000+7B87h)
Address: 01A858DCh (foo_customdb+858DCh)
Address: 01474F3Fh (foo_jesus+24F3Fh)
Address: 01A833E3h (foo_customdb+833E3h)
Address: 01A5E229h (foo_customdb+5E229h)
Address: 01A9A394h (foo_customdb+9A394h)
Address: 01A83409h (foo_customdb+83409h)
Address: 0047510Eh (foobar2000+7510Eh)
Address: 0052CD18h (foobar2000+12CD18h)
Address: 00474FC9h (foobar2000+74FC9h)
Address: 7C9101DBh (ntdll+101DBh), symbol: "RtlAllocateHeap" (+117h)
Address: 7C9100C4h (ntdll+100C4h), symbol: "RtlAllocateHeap" (+0h)
Address: 0052F808h (foobar2000+12F808h)
Address: 004752DEh (foobar2000+752DEh)
Address: 004749D6h (foobar2000+749D6h)
Address: 00550C34h (foobar2000+150C34h)
Address: 004C84D5h (foobar2000+C84D5h)
Address: 0057A960h (foobar2000+17A960h)
Address: 00554FD4h (foobar2000+154FD4h)
Address: 004C978Dh (foobar2000+C978Dh)
Address: 0052D088h (foobar2000+12D088h)
Address: 004C9710h (foobar2000+C9710h)
Address: 00559FD0h (foobar2000+159FD0h)
Address: 005331D9h (foobar2000+1331D9h)
Address: 004754CAh (foobar2000+754CAh)
Address: 7C810687h (kernel32+10687h), symbol: "CreateRemoteThread" (+1BBh)
Address: 00550C2Ch (foobar2000+150C2Ch)
Address: 0057A980h (foobar2000+17A980h)
Address: 00550D3Ch (foobar2000+150D3Ch)
Address: 7C910222h (ntdll+10222h), symbol: "RtlAllocateHeap" (+15Eh)
Address: 7C90E920h (ntdll+E920h), symbol: "strchr" (+113h)
Address: 0044E580h (foobar2000+4E580h)
Address: 00517311h (foobar2000+117311h)
Address: 7C8106F9h (kernel32+106F9h), symbol: "CreateThread" (+22h)
Address: 7C910228h (ntdll+10228h), symbol: "RtlAllocateHeap" (+164h)
Address: 7C91019Bh (ntdll+1019Bh), symbol: "RtlAllocateHeap" (+D7h)
Address: 004C9584h (foobar2000+C9584h)
Address: 00531BABh (foobar2000+131BABh)
Address: 005304ECh (foobar2000+1304ECh)
Address: 004C9687h (foobar2000+C9687h)
Address: 7C9100B8h (ntdll+100B8h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C910041h (ntdll+10041h), symbol: "RtlFreeHeap" (+114h)
Address: 00534481h (foobar2000+134481h)
Address: 004B71FDh (foobar2000+B71FDh)
Address: 00517330h (foobar2000+117330h)
Address: 004BB599h (foobar2000+BB599h)
Address: 0051B0F0h (foobar2000+11B0F0h)
Address: 004ED4EDh (foobar2000+ED4EDh)
Address: 7C90DF5Ah (ntdll+DF5Ah), symbol: "ZwWaitForSingleObject" (+Ch)
Address: 0058888Dh (foobar2000+18888Dh)
Address: 7C90DC2Ah (ntdll+DC2Ah), symbol: "ZwSetEventBoostPriority" (+Ch)
Address: 7C91B2A9h (ntdll+1B2A9h), symbol: "RtlpUnWaitCriticalSection" (+22h)
Address: 7C901046h (ntdll+1046h), symbol: "RtlEnterCriticalSection" (+46h)
Address: 0057D7C4h (foobar2000+17D7C4h)
Address: 00474F3Fh (foobar2000+74F3Fh)
Address: 0053814Eh (foobar2000+13814Eh)
Address: 00475323h (foobar2000+75323h)
Address: 004B72A2h (foobar2000+B72A2h)
Address: 004B9277h (foobar2000+B9277h)
Address: 0052C090h (foobar2000+12C090h)
Address: 004B9804h (foobar2000+B9804h)
Address: 0148AF80h (foo_playlist_tree_mod+AF80h)
Address: 00579684h (foobar2000+179684h)
Address: 014D34E0h (foo_playlist_tree_mod+534E0h)
Address: 005305EAh (foobar2000+1305EAh)
Address: 004B951Eh (foobar2000+B951Eh)
Address: 0054B958h (foobar2000+14B958h)
Address: 01488937h (foo_playlist_tree_mod+8937h)
Address: 0057A724h (foobar2000+17A724h)
Address: 0112F7CCh (foo_dop+9F7CCh)
Address: 01494D04h (foo_playlist_tree_mod+14D04h)
Address: 01490D23h (foo_playlist_tree_mod+10D23h)
Address: 0149EB5Fh (foo_playlist_tree_mod+1EB5Fh)
Address: 0149DD0Fh (foo_playlist_tree_mod+1DD0Fh)
Address: 014DC73Ch (foo_playlist_tree_mod+5C73Ch)
Address: 014DC5C8h (foo_playlist_tree_mod+5C5C8h)
Address: 014D4DD8h (foo_playlist_tree_mod+54DD8h)
Address: 01489941h (foo_playlist_tree_mod+9941h)
Address: 7E428EABh (USER32+18EABh), symbol: "DefWindowProcW" (+18Bh)
Address: 7E44048Fh (USER32+3048Fh), symbol: "DeregisterShellHookWindow" (+1CFh)
Address: 7E428EB0h (USER32+18EB0h), symbol: "DefWindowProcW" (+190h)
Address: 7E428EECh (USER32+18EECh), symbol: "DefWindowProcW" (+1CCh)
Address: 7C90E473h (ntdll+E473h), symbol: "KiUserCallbackDispatcher" (+13h)
Address: 7E428E53h (USER32+18E53h), symbol: "DefWindowProcW" (+133h)
Address: 7E4194BEh (USER32+94BEh), symbol: "GetWindowLongA" (+61h)
Address: 7E42C174h (USER32+1C174h), symbol: "SetPropW" (+BBh)
Address: 014D4E7Eh (foo_playlist_tree_mod+54E7Eh)
Address: 014CC1FBh (foo_playlist_tree_mod+4C1FBh)
Address: 7E42B326h (USER32+1B326h), symbol: "MoveWindow" (+88h)
Address: 7E42B330h (USER32+1B330h), symbol: "MoveWindow" (+92h)
Address: 7E4278D0h (USER32+178D0h), symbol: "GetWindowTextLengthW" (+9Ah)
Address: 7E4278E0h (USER32+178E0h), symbol: "GetWindowTextLengthW" (+AAh)
Address: 018B3870h (foo_ui_columns+63870h)
Address: 7E42B341h (USER32+1B341h), symbol: "MoveWindow" (+A3h)
Address: 7E46CF6Eh (USER32+5CF6Eh), symbol: "TrackPopupMenuEx" (+Ch)
Address: 7E465339h (USER32+55339h), symbol: "TrackPopupMenu" (+1Bh)
Address: 014D26F6h (foo_playlist_tree_mod+526F6h)
Address: 014CCC74h (foo_playlist_tree_mod+4CC74h)
Address: 01484194h (foo_playlist_tree_mod+4194h)
Address: 014CC360h (foo_playlist_tree_mod+4C360h)
Address: 7E41882Ah (USER32+882Ah), symbol: "GetDC" (+163h)
Address: 7E428EA0h (USER32+18EA0h), symbol: "DefWindowProcW" (+180h)
Address: 003A1860h (PowerMenuHook+1860h)
Address: 7E428EFCh (USER32+18EFCh), symbol: "DefWindowProcW" (+1DCh)
Address: 014CCD4Ch (foo_playlist_tree_mod+4CD4Ch)
Address: 014F06F4h (foo_playlist_tree_mod+706F4h)
Address: 01496F3Fh (foo_playlist_tree_mod+16F3Fh)
Address: 01494DAFh (foo_playlist_tree_mod+14DAFh)
Address: 01494E4Dh (foo_playlist_tree_mod+14E4Dh)
Address: 014DBCE4h (foo_playlist_tree_mod+5BCE4h)
Address: 014D276Dh (foo_playlist_tree_mod+5276Dh)
Address: 0148B278h (foo_playlist_tree_mod+B278h)
Address: 014D9410h (foo_playlist_tree_mod+59410h)
Address: 003A1420h (PowerMenuHook+1420h)
Address: 7E4318D1h (USER32+218D1h), symbol: "UnhookWinEvent" (+25h)
Address: 7E43E1ADh (USER32+2E1ADh), symbol: "User32InitializeImmEntryTable" (+E18h)
Address: 7E43E18Ah (USER32+2E18Ah), symbol: "User32InitializeImmEntryTable" (+DF5h)
Address: 7E41970Eh (USER32+970Eh), symbol: "IsChild" (+0h)
Address: 014D4AE8h (foo_playlist_tree_mod+54AE8h)
Address: 7E418734h (USER32+8734h), symbol: "GetDC" (+6Dh)
Address: 7E418816h (USER32+8816h), symbol: "GetDC" (+14Fh)
Address: 7E418830h (USER32+8830h), symbol: "GetDC" (+169h)
Address: 7E4189CDh (USER32+89CDh), symbol: "GetWindowLongW" (+127h)
Address: 7E4191C6h (USER32+91C6h), symbol: "GetMessageW" (+0h)
Address: 7C90FE30h (ntdll+FE30h), symbol: "RtlRestoreLastWin32Error" (+0h)
Address: 7E4189F0h (USER32+89F0h), symbol: "GetWindowLongW" (+14Ah)
Address: 7E418A10h (USER32+8A10h), symbol: "DispatchMessageW" (+Fh)
Address: 7E41929Bh (USER32+929Bh), symbol: "PeekMessageW" (+0h)
Address: 004646DBh (foobar2000+646DBh)
Address: 004654C4h (foobar2000+654C4h)
Address: 0054F5E8h (foobar2000+14F5E8h)
Address: 0055A2ACh (foobar2000+15A2ACh)
Address: 00400000h (foobar2000+0h)
Address: 0055A290h (foobar2000+15A290h)
Address: 0051F52Ch (foobar2000+11F52Ch)
Address: 0051D514h (foobar2000+11D514h)
Address: 7C91027Fh (ntdll+1027Fh), symbol: "RtlAllocateHeap" (+1BBh)
Address: 00517E02h (foobar2000+117E02h)
Address: 10002778h (shared+2778h), symbol: "uPrintCrashInfo_OnEvent" (+B0h)
Address: 0054F238h (foobar2000+14F238h)
Address: 00537D77h (foobar2000+137D77h)
Address: 00465707h (foobar2000+65707h)
Address: 00517B01h (foobar2000+117B01h)
Address: 005420B8h (foobar2000+1420B8h)
Address: 0057F090h (foobar2000+17F090h)
Address: 0053FCE0h (foobar2000+13FCE0h)
Address: 004157A6h (foobar2000+157A6h)
Address: 00517B15h (foobar2000+117B15h)
Address: 0053817Dh (foobar2000+13817Dh)
Address: 00518F46h (foobar2000+118F46h)
Environment:
App: foobar2000 v1.0.1
OS: Windows 5.1.2600 Service Pack 3 x86
CPU: Intel® Pentium® D CPU 3.20GHz, features: MMX SSE SSE2 SSE3
Audio: HTO STRIKER 7.1 Audio Device
UI: Columns UI 0.3.8.5
Components:
Core (2010-03-06 13:44:16)
    foobar2000 core 1.0.1
foo_albumlist.dll (2010-03-06 13:42:18)
    Album List 4.4
foo_audioscrobbler.dll (2010-02-07 16:16:48)
    Audioscrobbler 1.4.6
foo_cdda.dll (2010-03-06 13:42:14)
    CD Audio Decoder 3.0
foo_converter.dll (2010-03-06 13:42:12)
    Converter 1.4
foo_customdb.dll (2010-03-04 13:10:54)
    Custom Database 0.1.0_beta1
foo_dop.dll (2010-04-02 18:09:34)
    iPod manager 0.6.7.4
foo_dsp_std.dll (2010-03-06 13:42:26)
    Standard DSP Array 1.0
foo_fileops.dll (2010-03-06 13:41:12)
    File Operations 2.1.2
foo_input_std.dll (2010-03-06 13:42:00)
    Standard Input Array 1.0
foo_jesus.dll (2010-01-03 13:41:18)
    Autosave & Autobackup 8
foo_playlist_tree_mod.dll (2010-01-09 15:37:50)
    Playlist Tree Mod Panel 3.0.6.3 Scheme [Jan  9 2010 - 15:37:18]
foo_rgscan.dll (2010-03-06 13:41:56)
    ReplayGain Scanner 2.0.9
foo_skip.dll (2010-01-16 15:43:34)
    Skip Track 0.7
foo_ui_columns.dll (2010-03-21 00:43:13)
    Columns UI 0.3.8.5
foo_ui_std.dll (2010-03-06 13:42:34)
    Default User Interface 0.9.5
Recent events:
Custom Database: Initialize
Custom Database: table quicktag already exists (1)
Custom Database: table database_version already exists (1)
Custom Database: index url_idx already exists (1)
Custom Database: Completed
Startup time : 0:07.007730
iPod manager: Listening for Apple mobile devices.
Reply #108
I guessed that:
Crash location:
Offset: 1945h
It has nothing to do with foo_playlist_tree_mod. It's a problem of foo_customdb.
But it could help not to use %rating% as tag, when using foo_customdb, as this tag may also be a real tag in your files. If this is the case, foo_customdb has at least sometimes problems and crashes.
Reply #109
Where does playlist tree mod store configuration data?  I moved around my columns ui and now my playlist tree mod structure has returned to its default settings.  this has happened to me before, and I just re-create all the playlists, but it seems like a waste of time....
Reply #110
Search for *.pts files in your application or profile folder and load them with Mainmenu -> Library -> Playlist Tree Mod -> File -> Open
Reply #111
I know you addressed the question about 3 months ago, but wanted to ask again for an update, any plans for possible DUI support?
Reply #112
Can support Windows 7 Themed appearance like Library Tree?
Reply #113
I get this message on console.
Warning: Missing @node or @playlist in query criteria
But I cannot understand this.
Please explain.
My trouble query Example
Source:
@not @node<A> @and @not @node<B>
"@not @node<A>" is work fine.
But "@not @node<B>" is not work for my environment.
I think it work at olden days.
It is bug? or my some mistake?
And, work fine following Source.
@not @node<A> @and @not @node<C>
Why? I think B and C node is normal.
It not output following message.
Warning: Node NODENAME not found
I can understand this. I set correct node name on Source field.
@Windows 7 x64 foobar2000 v1.0.3
Thank you!
Reply #114
What happened to the legacy context menu items that were in v3.0.6.2 but seem to have vanished in v3.0.6.3?  I can 'Add to playback queue' for a selected file in the former amongst other legacy menu items, but the only command I get on the latter's context menu is 'Remove'
Geopoliticus Child Watching the Birth of the New Man
Reply #115
When I turn foobar I'm getting error. I read recommendations in this topic and removed fields with name RATING from my tags.
It seems to me that the error occurs when the entire library in a playlist. When playlists have part of library just then errors occur less frequently.
Help me solve the problem please.
Also I'm getting error when i search with query: %rating% PRESENT. But this query tested in other foobars and it was valid.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 02231945h
Call path:
entry=>initquit::on_init=>titleformat_object::run
Code bytes (02231945h):
02231905h:  C7 06 14 59 2B 02 89 75 F0 89 46 04 89 46 08 89
02231915h:  46 0C FF 75 0C 89 45 FC FF 75 08 89 46 10 E8 7E
02231925h:  00 00 00 8B 4D F4 8B C6 5E 64 89 0D 00 00 00 00
02231935h:  C9 C2 08 00 33 C0 39 44 24 08 76 11 8B 4C 24 04
02231945h:  80 3C 08 00 74 07 40 3B 44 24 08 72 EF C3 E9 E1
02231955h:  FF FF FF 56 8B 74 24 10 85 F6 76 13 8B 4C 24 08
02231965h:  8B 44 24 0C 2B C1 8A 14 08 88 11 41 4E 75 F7 5E
02231975h:  C3 56 57 8B 7C 24 10 8D 47 01 50 8B F1 E8 BB 01
Stack (0012F18Ch):
0012F16Ch:  03ACEB70 7C9C94F8 77F643DD 7C9C94F8
0012F17Ch:  00000004 00000000 03ACE07C 00000000
0012F18Ch:  022315DB 00000000 FFFFFFFF 022CA3A0
0012F19Ch:  02236C9E 022E2810 0224FA61 022E2810
0012F1ACh:  0223157E 0012F274 022B4248 FFFFFFFF
0012F1BCh:  0012F280 0228DE6A 00000000 FFFFFFFF
0012F1CCh:  24A51167 0012F1F0 022E2610 02F5C440
0012F1DCh:  022E2610 010003CC 0012F1C4 022E2230
0012F1ECh:  0012F148 0042A815 0012F1C4 00000001
0012F1FCh:  7C910060 FFFFFFFF 7C91005D 022A0146
0012F20Ch:  0012F220 0040791A 0012F310 03AB0984
0012F21Ch:  03AB0988 0012F254 00407A15 022B5A80
0012F22Ch:  022B5A80 00000004 0012F2C0 00000000
0012F23Ch:  022B58DC 0494D4E0 00000003 00000004
0012F24Ch:  00000002 022B58DC 0494DCF8 0000001A
0012F25Ch:  00000020 00000019 00000064 0494CB80
0012F26Ch:  00480AE1 015AAABC 0012F2C0 022B33E3
0012F27Ch:  00000002 0012F2CC 0228E229 00000004
0012F28Ch:  02F5C7E0 0012F2AC 24A5112B 022CA3A0
0012F29Ch:  0012F28C 022CA3A0 0042DC28 0012F28C
Registers:
EAX: 00000000, EBX: 00000004, ECX: 00000000, EDX: 02231574
ESI: 0012F2AC, EDI: 0012F310, EBP: 0012F1BC, ESP: 0012F18C
Crash location:
Offset: 1945h
Loaded modules:
foobar2000                      loaded at 00400000h - 005F2000h
ntdll                            loaded at 7C900000h - 7C9B3000h
kernel32                        loaded at 7C800000h - 7C8F8000h
snxhk                            loaded at 64D00000h - 64D31000h
COMCTL32                        loaded at 773C0000h - 774C3000h
msvcrt                          loaded at 77C00000h - 77C58000h
ADVAPI32                        loaded at 77DC0000h - 77E6C000h
USER32                          loaded at 7E360000h - 7E3F1000h
SHLWAPI                          loaded at 77F60000h - 77FDC000h
DSOUND                          loaded at 73ED0000h - 73F2C000h
ole32                            loaded at 774D0000h - 7760D000h
VERSION                          loaded at 77BF0000h - 77BF8000h
WINMM                            loaded at 76B20000h - 76B4E000h
UxTheme                          loaded at 5B260000h - 5B298000h
SHELL32                          loaded at 7C9C0000h - 7E339000h
zlib1                            loaded at 5A4C0000h - 5A4D4000h
imagehlp                        loaded at 76C80000h - 76CA8000h
dbghelp                          loaded at 59C60000h - 59D01000h
COMDLG32                        loaded at 76380000h - 763C9000h
CRYPT32                          loaded at 77A70000h - 77B06000h
MSASN1                          loaded at 77B10000h - 77B22000h
gdiplus                          loaded at 4EBE0000h - 4ED8B000h
MSCTF                            loaded at 746E0000h - 7472C000h
WINTRUST                        loaded at 76C20000h - 76C4E000h
wdmaud                          loaded at 72CE0000h - 72CE9000h
msacm32                          loaded at 72CD0000h - 72CD8000h
MSACM32                          loaded at 77BD0000h - 77BE5000h
midimap                          loaded at 77BC0000h - 77BC7000h
foo_softplaylists                loaded at 01030000h - 01098000h
foo_audioscrobbler              loaded at 010B0000h - 010E3000h
foo_input_monkey                loaded at 01110000h - 01159000h
foo_urlencode                    loaded at 01180000h - 011A3000h
foo_dsp_std                      loaded at 011C0000h - 01208000h
foo_out_asio                    loaded at 01230000h - 01266000h
foo_quicksearch                  loaded at 01290000h - 012C1000h
MSVCP90                          loaded at 78480000h - 7850E000h
MSVCR90                          loaded at 78520000h - 785C3000h
foo_uie_biography                loaded at 012F0000h - 01348000h
foo_out_wasapi                  loaded at 01370000h - 01396000h
foo_lyricsdb                    loaded at 013C0000h - 013F0000h
OLEAUT32                        loaded at 77110000h - 7719B000h
WININET                          loaded at 771A0000h - 77261000h
foo_uie_explorer                loaded at 01410000h - 0144D000h
CLBCATQ                          loaded at 76FC0000h - 7703F000h
COMRes                          loaded at 014D0000h - 015A5000h
foo_freedb2                      loaded at 01480000h - 014C0000h
foo_cdda                        loaded at 015D0000h - 0161E000h
foo_utils                        loaded at 01640000h - 01684000h
foo_input_std                    loaded at 016B0000h - 01800000h
foo_uie_lyrics2                  loaded at 01820000h - 0190E000h
foo_uie_albumlist                loaded at 01A40000h - 01A83000h
foo_ui_std                      loaded at 01AB0000h - 01BC8000h
MSIMG32                          loaded at 76350000h - 76355000h
foo_uie_wsh_panel_mod            loaded at 01BF0000h - 01CB2000h
IMM32                            loaded at 76360000h - 7637D000h
foo_converter                    loaded at 01D10000h - 01D8B000h
foo_texttools                    loaded at 01DB0000h - 01DE4000h
foo_musicbrainz                  loaded at 01E10000h - 01E6C000h
WINHTTP                          loaded at 4D550000h - 4D5A9000h
foo_uie_panel_splitter          loaded at 01FF0000h - 02049000h
foo_uie_elplaylist              loaded at 02070000h - 020E3000h
foo_rgscan                      loaded at 02110000h - 0215D000h
foo_uie_graphical_browser        loaded at 02180000h - 02214000h
foo_customdb                    loaded at 02230000h - 022D5000h
foo_unpack                      loaded at 022F0000h - 0231E000h
foo_input_dts                    loaded at 02340000h - 023A3000h
foo_albumlist                    loaded at 023D0000h - 0242D000h
foo_masstag                      loaded at 02450000h - 024A4000h
foo_abx                          loaded at 024D0000h - 02502000h
foo_ui_columns                  loaded at 02540000h - 026D0000h
urlmon                          loaded at 026E0000h - 02785000h
USP10                            loaded at 75540000h - 755AB000h
foo_fileops                      loaded at 027C0000h - 02807000h
foo_w7shell                      loaded at 02850000h - 0288D000h
foo_unpack_7z                    loaded at 028A0000h - 028CB000h
foo_run                          loaded at 028F0000h - 0294F000h
foo_discogs                      loaded at 02970000h - 029D1000h
foo_input_alac                  loaded at 029F0000h - 02A0D000h
SXS                              loaded at 7E690000h - 7E748000h
JScript                          loaded at 75C20000h - 75C9D000h
xpsp2res                        loaded at 04EE0000h - 05207000h
scrrun                          loaded at 73560000h - 7358A000h
wshom                            loaded at 66EC0000h - 66EE1000h
MPR                              loaded at 71B00000h - 71B12000h
mscms                            loaded at 73AF0000h - 73B05000h
WINSPOOL                        loaded at 72FC0000h - 72FE6000h
icm32                            loaded at 58BE0000h - 58C21000h
msxml3                          loaded at 74940000h - 74AA4000h
msxml6                          loaded at 58800000h - 58946000h
Address: 022315DBh (foo_customdb+15DBh)
Address: 022CA3A0h (foo_customdb+9A3A0h)
Address: 02236C9Eh (foo_customdb+6C9Eh)
Address: 0224FA61h (foo_customdb+1FA61h)
Address: 0223157Eh (foo_customdb+157Eh)
Address: 022B4248h (foo_customdb+84248h)
Address: 0228DE6Ah (foo_customdb+5DE6Ah)
Address: 0042A815h (foobar2000+2A815h)
Address: 022A0146h (foo_customdb+70146h)
Address: 0040791Ah (foobar2000+791Ah)
Address: 00407A15h (foobar2000+7A15h)
Address: 022B5A80h (foo_customdb+85A80h)
Address: 022B58DCh (foo_customdb+858DCh)
Address: 00480AE1h (foobar2000+80AE1h)
Address: 022B33E3h (foo_customdb+833E3h)
Address: 0228E229h (foo_customdb+5E229h)
Address: 0042DC28h (foobar2000+2DC28h)
Address: 022B3409h (foo_customdb+83409h)
Address: 00480CDCh (foobar2000+80CDCh)
Address: 0054CD38h (foobar2000+14CD38h)
Address: 00480BD6h (foobar2000+80BD6h)
Address: 0054FDF8h (foobar2000+14FDF8h)
Address: 00480EBBh (foobar2000+80EBBh)
Address: 0047EAB4h (foobar2000+7EAB4h)
Address: 004E51A2h (foobar2000+E51A2h)
Address: 005A7B30h (foobar2000+1A7B30h)
Address: 0057B23Ch (foobar2000+17B23Ch)
Address: 00407BD2h (foobar2000+7BD2h)
Address: 004E6406h (foobar2000+E6406h)
Address: 0054D1D1h (foobar2000+14D1D1h)
Address: 00481176h (foobar2000+81176h)
Address: 7C90FDDDh (ntdll+FDDDh), symbol: "RtlQueryInformationActivationContext" (+10Bh)
Address: 00576688h (foobar2000+176688h)
Address: 00576680h (foobar2000+176680h)
Address: 005A7B50h (foobar2000+1A7B50h)
Address: 005767D4h (foobar2000+1767D4h)
Address: 00401D0Fh (foobar2000+1D0Fh)
Address: 7C810644h (kernel32+10644h), symbol: "CreateRemoteThread" (+178h)
Address: 7C90DB4Ah (ntdll+DB4Ah), symbol: "ZwResumeThread" (+Ch)
Address: 7C8106A3h (kernel32+106A3h), symbol: "CreateRemoteThread" (+1D7h)
Address: 004568C0h (foobar2000+568C0h)
Address: 7C90CF7Ah (ntdll+CF7Ah), symbol: "ZwAllocateVirtualMemory" (+Ch)
Address: 7C919BB3h (ntdll+19BB3h), symbol: "RtlReAllocateHeap" (+703h)
Address: 00580700h (foobar2000+180700h)
Address: 7C919D11h (ntdll+19D11h), symbol: "RtlReAllocateHeap" (+861h)
Address: 7C910FE8h (ntdll+10FE8h), symbol: "wcsncpy" (+A0Fh)
Address: 7C911046h (ntdll+11046h), symbol: "wcsncpy" (+A6Dh)
Address: 026012B6h (foo_ui_columns+C12B6h)
Address: 025FFDBDh (foo_ui_columns+BFDBDh)
Address: 025DDA47h (foo_ui_columns+9DA47h)
Address: 7C90DF5Ah (ntdll+DF5Ah), symbol: "NtWaitForSingleObject" (+Ch)
Address: 7C91AC7Bh (ntdll+1AC7Bh), symbol: "RtlpWaitForCriticalSection" (+8Ch)
Address: 0055AE5Eh (foobar2000+15AE5Eh)
Address: 00539716h (foobar2000+139716h)
Address: 7C91AD33h (ntdll+1AD33h), symbol: "RtlpUnWaitCriticalSection" (+7Ch)
Address: 7C90DC2Ah (ntdll+DC2Ah), symbol: "NtSetEventBoostPriority" (+Ch)
Address: 00480EF2h (foobar2000+80EF2h)
Address: 004D3510h (foobar2000+D3510h)
Address: 004D54C1h (foobar2000+D54C1h)
Address: 0054B740h (foobar2000+14B740h)
Address: 004D5A15h (foobar2000+D5A15h)
Address: 7C9101E0h (ntdll+101E0h), symbol: "RtlAllocateHeap" (+11Ch)
Address: 005A668Ch (foobar2000+1A668Ch)
Address: 00550F32h (foobar2000+150F32h)
Address: 004D56EEh (foobar2000+D56EEh)
Address: 00570BD4h (foobar2000+170BD4h)
Address: 00427042h (foobar2000+27042h)
Address: 00570D14h (foobar2000+170D14h)
Address: 0054D71Ah (foobar2000+14D71Ah)
Address: 0042762Ch (foobar2000+2762Ch)
Address: 0040C08Ah (foobar2000+C08Ah)
Address: 00425EBFh (foobar2000+25EBFh)
Address: 005712B8h (foobar2000+1712B8h)
Address: 014252AAh (foo_uie_explorer+152AAh)
Address: 00425BEEh (foobar2000+25BEEh)
Address: 00555180h (foobar2000+155180h)
Address: 00426C9Fh (foobar2000+26C9Fh)
Address: 005A5908h (foobar2000+1A5908h)
Address: 00555231h (foobar2000+155231h)
Address: 00429A98h (foobar2000+29A98h)
Address: 004283E1h (foobar2000+283E1h)
Address: 005A537Ch (foobar2000+1A537Ch)
Address: 00550578h (foobar2000+150578h)
Address: 00556A4Bh (foobar2000+156A4Bh)
Address: 00428DBFh (foobar2000+28DBFh)
Address: 7C80A4C7h (kernel32+A4C7h), symbol: "QueryPerformanceCounter" (+0h)
Address: 00407F89h (foobar2000+7F89h)
Address: 005712A8h (foobar2000+1712A8h)
Address: 0054D810h (foobar2000+14D810h)
Address: 00557A8Ah (foobar2000+157A8Ah)
Address: 004290B2h (foobar2000+290B2h)
Address: 005A539Ch (foobar2000+1A539Ch)
Address: 7C91150Eh (ntdll+1150Eh), symbol: "RtlDeleteCriticalSection" (+15Dh)
Address: 7C91154Ch (ntdll+1154Ch), symbol: "RtlDeleteCriticalSection" (+19Bh)
Address: 7C97E120h (ntdll+7E120h)
Address: 7C911522h (ntdll+11522h), symbol: "RtlDeleteCriticalSection" (+171h)
Address: 02207FC0h (foo_uie_graphical_browser+87FC0h)
Address: 022080E8h (foo_uie_graphical_browser+880E8h)
Address: 0057EBC8h (foobar2000+17EBC8h)
Address: 021AD68Fh (foo_uie_graphical_browser+2D68Fh)
Address: 005A6F94h (foobar2000+1A6F94h)
Address: 02180000h (foo_uie_graphical_browser+0h)
Address: 021AD8C8h (foo_uie_graphical_browser+2D8C8h)
Address: 021AD8D3h (foo_uie_graphical_browser+2D8D3h)
Address: 0049B265h (foobar2000+9B265h)
Address: 01642A77h (foo_utils+2A77h)
Address: 01663B28h (foo_utils+23B28h)
Address: 01642BF5h (foo_utils+2BF5h)
Address: 021F6D88h (foo_uie_graphical_browser+76D88h)
Address: 026688D8h (foo_ui_columns+1288D8h)
Address: 00558B16h (foobar2000+158B16h)
Address: 0046DC9Ah (foobar2000+6DC9Ah)
Address: 0054B279h (foobar2000+14B279h)
Address: 0046F1D7h (foobar2000+6F1D7h)
Address: 0056C810h (foobar2000+16C810h)
Address: 00539357h (foobar2000+139357h)
Address: 0053FB61h (foobar2000+13FB61h)
Address: 004333B0h (foobar2000+333B0h)
Address: 0053D1E0h (foobar2000+13D1E0h)
Address: 0055A8BBh (foobar2000+15A8BBh)
Address: 100027D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 00574A44h (foobar2000+174A44h)
Address: 1000281Eh (shared+281Eh), symbol: "uCallStackTracker::uCallStackTracker" (+31h)
Address: 0046F4DDh (foobar2000+6F4DDh)
Address: 00542E37h (foobar2000+142E37h)
Address: 005AA320h (foobar2000+1AA320h)
Address: 0053C9EAh (foobar2000+13C9EAh)
Address: 00539629h (foobar2000+139629h)
Address: 00539623h (foobar2000+139623h)
Address: 00566768h (foobar2000+166768h)
Address: 0056676Ch (foobar2000+16676Ch)
Address: 00563761h (foobar2000+163761h)
Address: 0055AE8Dh (foobar2000+15AE8Dh)
Address: 0053A822h (foobar2000+13A822h)
Address: 7C817077h (kernel32+17077h), symbol: "RegisterWaitForInputIdle" (+49h)
Address: 7C839AA8h (kernel32+39AA8h), symbol: "ValidateLocale" (+2B0h)
Address: 7C817080h (kernel32+17080h), symbol: "RegisterWaitForInputIdle" (+52h)
Address: 0053A875h (foobar2000+13A875h)
Address: 0057005Ch (foobar2000+17005Ch)
Address: 004E0049h (foobar2000+E0049h)
Address: 004F0044h (foobar2000+F0044h)
Address: 00530057h (foobar2000+130057h)
Environment:
App: foobar2000 v1.1.5
CPU: Intel® Pentium® 4 CPU 2.60GHz, features: MMX SSE SSE2
Audio: SoundMAX Digital Audio
UI: Columns UI 0.3.8.8
Components:
Core (2011-02-27 19:44:04 UTC)
    foobar2000 core 1.1.5
foo_abx.dll (2009-05-21 14:57:38 UTC)
    ABX Comparator 1.3.4
foo_albumlist.dll (2011-02-27 19:42:12 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2010-06-04 05:27:04 UTC)
    Audioscrobbler 1.4.7
foo_cdda.dll (2011-02-27 19:42:04 UTC)
foo_converter.dll (2011-02-27 19:41:48 UTC)
    Converter 1.5
foo_customdb.dll (2010-03-04 09:10:54 UTC)
foo_discogs.dll (2010-07-22 12:59:06 UTC)
    Discogs Tagger 1.25
foo_dsp_std.dll (2011-02-27 19:42:22 UTC)
foo_fileops.dll (2011-02-27 19:40:50 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2011-02-27 19:40:56 UTC)
    freedb Tagger 0.6.3
foo_input_alac.dll (2011-02-26 14:05:53 UTC)
    ALAC Decoder 1.0.7
foo_input_dts.dll (2010-09-05 09:31:04 UTC)
    DTS decoder 0.3.0
foo_input_monkey.dll (2011-02-26 14:05:53 UTC)
    Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2011-02-27 19:41:24 UTC)
foo_lyricsdb.dll (2009-10-05 08:35:38 UTC)
    foo_lyricsdb 0.0.8 beta 0
foo_masstag.dll (2009-09-18 06:01:36 UTC)
    Masstagger 1.8.4
foo_musicbrainz.dll (2009-04-10 20:27:30 UTC)
    MusicBrainz Tagger 0.2
foo_out_asio.dll (2011-01-15 17:36:45 UTC)
    ASIO support 1.2.7
foo_out_wasapi.dll (2009-05-19 19:45:18 UTC)
    WASAPI output support 2.1
foo_quicksearch.dll (2010-10-20 13:48:46 UTC)
    Quick Search Toolbar 2.3
foo_rgscan.dll (2011-02-27 19:41:56 UTC)
foo_run.dll (2009-06-07 12:15:18 UTC)
    Run services 0.3.7
foo_softplaylists.dll (2011-02-25 18:01:09 UTC)
    Soft Playlists 2011-02-05
foo_texttools.dll (2010-09-05 09:31:06 UTC)
    Text Tools 1.0.5
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2011-02-27 19:42:12 UTC)
foo_uie_albumlist.dll (2009-06-13 22:49:20 UTC)
    Album list panel 0.3.5
foo_uie_biography.dll (2010-12-11 05:47:22 UTC)
    Biography View 0.4.2.4
foo_uie_elplaylist.dll (2010-10-30 18:51:16 UTC)
    ELPlaylist 0.6.9.1.2(beta)
foo_uie_explorer.dll (2010-02-22 13:51:30 UTC)
    Explorer Tree 2.04.8
foo_uie_graphical_browser.dll (2008-04-19 19:37:54 UTC)
    Graphical Browser rev015
foo_uie_lyrics2.dll (2010-04-12 16:19:24 UTC)
    Lyric Show Panel 2 0.4.6.15
foo_uie_panel_splitter.dll (2009-12-09 21:16:12 UTC)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_wsh_panel_mod.dll (2011-01-08 08:11:34 UTC)
    WSH Panel Mod 1.4.2
foo_unpack.dll (2011-02-27 19:41:36 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_unpack_7z.dll (2011-01-15 17:36:49 UTC)
    7-Zip reader 1.5
foo_urlencode.dll (2009-03-11 11:24:48 UTC)
    UrlEncode 0.0.2
foo_utils.dll (2008-02-08 19:26:58 UTC)
    Playlist Tools 0.6.2 beta 6
foo_w7shell.dll (2010-01-17 01:09:20 UTC)
    Windows 7 integration 0.2.9.1
Recent events:
WSH Panel Mod ({401D69A0-FCFA-48C4-8153-00EF93527792}): initialized in 7 ms
WSH Panel Mod ({AFD0583F-4155-412D-86DD-5F34509EB4D7}): initialized in 5 ms
WSH Panel Mod ({4556DAE2-F6EB-480B-80C9-C964FE105C3C}): initialized in 11 ms
WSH Panel Mod ({85C46DB2-CDFC-4686-BDD5-AFE59D84507F}): initialized in 4 ms
WSH Panel Mod ({C607789A-79D7-4B38-B4B6-4EC677F4866D}): initialized in 16 ms
WSH Panel Mod ({73707C43-1A66-4975-8712-EBDE0AAF6000}): initialized in 6 ms
WSH Panel Mod ({E4101BAA-6B63-451E-B522-431C39897915}): Parsing file "C:\Program Files\foobar2000\\\s7e_files\\js\\md5.js"
WSH Panel Mod ({E4101BAA-6B63-451E-B522-431C39897915}): initialized in 59 ms
Custom Database: unknown error (21)
Reply #116
already answered here. Just scroll up a little bit.
Reply #118
perhaps you should read your own post again.
Crash location:
Offset: 1945h
Reply #119
Crash location:
Offset: 1945h
I realized that the fault foo_customdb. I am wondering how to solve this problem. Please help me.
Reply #120
Then ask the author of foo_customdb to fix his component. This is the wrong thread for your problem.
Reply #121
Hi fbuser,
I can't check right now if this is Wine-related (running linux), but just today I discovered that selection of multiple items is not possible here (the usual ctrl, ctrl + shift). Any chance for implementing this? I know the "Selection option/Playlist Tree Mod/Add to active playlist" circumvents that problem, but at first sight the usual ctrl, ctrl + shift seems more convenient, at least for me...
Thanks for your work!
Reply #122
Hi. Need some support in query, please help
My files have %play_stamp% tag, it multivalued and can contain timestamps when file was listened:
2011-03-05 22:14
2011-03-15 19:54
2011-04-03 18:54
2011-05-05 01:54
i want to make query to see what files were listened by months so the example file above must looks like:
2011-03
2011-04
2011-05
me maked query for it: $cut(%<play_stamp>%,7)|%artist% - %title%
but the problem is that item dublicated... file was played twice in 2011.03 so this node have 2 similar items...
is there some way to avoid this dublicates?
Reply #123
i implemented fb2k in our community-radio-station and from now on use this plug-in as our "automated radio station".
now i wanna add one of my media-library-default-queries => %last_played% DURING LAST WEEK as a non-scheme-query-rule
can somebody tell me why this doesnt work in playlist_tree_mod? am i stupid or should it work?
the format of my %last_played%-tag is YYYY-MM-DD HH:MM:SS like 2011-07-03 11:34:45. wrong format?
love this plug-in, thx for your effort!
Reply #124
thx for providing that much help, now with v.1.1.10 i cant even start foobar with playlisttreemod without getting an error of this plugin.
it seems i should rely on different components and providers...
