Topic: LAME 3.98 Final (Read 233484 times) previous topic - next topic
LAME 3.98 Final
Reply #51
It seems that there is something wrong with the current compiles with libsndfile. A few testruns with .flac files as input produced mp3 files with only noise in them.
Just a plain
LAME.EXE -V 3 "TRACK01.FLAC"
libsndfile-1.dll was in the workig directory of course
Could somebody confirm this please ?
I also have this problem. I am assuming that the precompiled libsndfile-1.dll that is provided with the libsndfile download was not compiled with FLAC support. I don't know this for a fact and, although I've hunted high and low, I can't find any definitive answer to this, but it certainly does not have any FLAC dll dependency. When I have the opportunity, I will try compiling with FLAC support.
This LAME build will work with official pre versions of libsndfile 1.0.18 with FLAC support:
http://www.mega-nerd.com/tmp/?M=D
Direct links - libsndfile-1-0-18pre22a-setup.exe (installer), libsndfile-1.dll (extracted)
LAME 3.98 Final
Reply #52
Thanks ZinCh!
The strange part of this is the fact that FLAC support is explicitly mentioned in the table
http://www.mega-nerd.com/libsndfile/
LAME 3.98 Final
Reply #53
Do you guys recommend -V5.7 to be used in my test?
I think NO coz there is no possibility to make all participating coders to produce equal resulting bit rates. So the use of real-life settings (resulting in acceptable bit rates) seems to be a reasonable compromise.
keeping audio clear together - soundexpert.org
LAME 3.98 Final
Reply #54
Just a plain
Brilliant, thanks.  I'll add this to the Rarewares download. I'll do this momentarily as I'm just about to do a lamedropXPd build that should work with this too, but I'll let you know.
LAME 3.98 Final
Reply #55
OK, I've updated the lame.exe download now compiled to use the libsndfile 1.0.18pre22a dll and I've also added a build of lamedropXPd that works with the same dll and both now accept FLAC files as input and process accordingly.
(Both builds include the new dll.)
LAME 3.98 Final
Reply #56
Whoa!  I've been waiting 3 years for this day!  Whoo hoo!
Just downloaded and tested.  Finally can drop a FLAC and get a MP3.
One note: On the Encoding Options screen is showing "Using L.A.M.E. v3.98 beta 8 encoding engine"....is this a typo, or is this still using beta 8 and not the final version?
Also - is the Variable Bitrate Mode relevant anymore?  Doesn't 3.98 use --vbr-new as default?  Wasn't that what this setting changed, the old vs. new VBR mode?  I'm assuming Standard is now --vbr-new.  Can you clarify?
Lastly - is there anyway to show the -V settings along the slider so we know where along the scale we're locked in on say -V2 -V3 -V4 -V5, etc.  I'm finding it impossible to tell where -V4 is so I can compare LameDrop files with the output of foobar.  If this can't be done, don't sweat it.
Anyway, thank you so much for getting LameDropXPd to work with FLAC.
LAME 3.98 Final
Reply #57
Your right, it was a typo!  I've fixed that and uploaded again. This version does not accept ogg files for input as it uses libsndfile exclusively for input purposes. If you want to drop ogg files as well, you'll need both versions, but they can share the same ini file and co-exist quite happily.
LAME 3.98 Final
Reply #58
OK, looks like we still need to toggle "Fast" on Variable Bitrate Mode to get --vbr-new.  Is the old vbr mode still an option in 3.98 because it looks like the "Standard" setting is still using the old mode.  I thought I read that --vbr-new is now the default.
LAME 3.98 Final
Reply #59
Hi John, thanks for the release with flac support.
You're right, with "Standard" setting lamedrop uses the old mode. I converted few flacs to mp3's and encspot shows in Lame Tag: "VBR Method - vbr-old / vbr-rh". If i encode wav's with normal 3.98 lame, encspot shows in Lame Tag: "VBR Method - vbr mtrh".
Also, LamedropXPd doesn't copy tags from flacs to mp3 like oggdropXPd does. But i guess this is because of libsndfile...
LAME 3.98 Final
Reply #60
You're right, I forgot to change the default on the Method. I've changed it for subsequent compiles, but it's probably not worth uploading again.
And, Kim_C, you're also right, as the FLAC routines are courtesy of libsndfile, tag copying is not catered for, but still a step in the right direction, I think.
LAME 3.98 Final
Reply #61
Wow
As always, thanks !
LAME 3.98 Final
Reply #62
I want to see a comparison of different encoders in mostly equal bitrate ranges. So if -V 5 now produces ~150kbps in a 128kbps test ist's not ok in my opinion. I also would like to see lame 3.98 and 3.97; so we may get a new recommended encoder + setting with lame 3.98 after the test.
LAME 3.98 Final
Reply #63
Thanks to the Lame devs for the new version and many thanks to John33 for finally including FLAC support into LamedropXPd
LAME 3.98 Final
Reply #64
I have seem to have ripped a NES video game music sample that LAME 3.97 sounds worse then 3.98 at -V5.
LAME 3.97 -V 5 --vbr-new
foo_abx 1.3.3 report
foobar2000 v0.9.5.3
2008/07/06 23:54:31
File A: C:\Temp\Metal Gear NFS Rip Preview\NES_MetalGearBGM LAME3.97 V5.mp3
File B: C:\Temp\Metal Gear NFS Rip Preview\NES_MetalGearBGM.flac
23:54:31 : Test started.
23:54:51 : 01/01  50.0%
23:55:00 : 02/02  25.0%
23:55:28 : 03/03  12.5%
23:55:44 : 04/04  6.3%
23:55:58 : 05/05  3.1%
23:56:04 : 06/06  1.6%
23:56:13 : 07/07  0.8%
23:56:27 : 08/08  0.4%
23:56:33 : 09/09  0.2%
23:56:44 : 10/10  0.1%
23:56:46 : Test finished.
Total: 10/10 (0.1%)
LAME 3.98 -V 5
foobar2000 v0.9.5.3
2008/07/06 23:57:43
File A: C:\Temp\Metal Gear NFS Rip Preview\NES_MetalGearBGM LAME3.98 V5.mp3
23:57:43 : Test started.
23:58:13 : 01/01  50.0%
23:58:24 : 02/02  25.0%
23:59:19 : 03/03  12.5%
23:59:39 : 04/04  6.3%
23:59:46 : 05/05  3.1%
00:00:23 : 06/06  1.6%
00:00:40 : 07/07  0.8%
00:00:47 : 07/08  3.5%
00:01:05 : 08/09  2.0%
00:01:46 : 08/10  5.5%
00:01:50 : Test finished.
Total: 8/10 (5.5%)
I have to seem to have more trouble doing a ABX on the 3.98 encode. At the moment am having trouble doing any tests, since I can not barely hear much at of my right ear, which is likely to be a bad ear wax build up hopefully.
The sample was a 30 sec preview, produced on foobar2000 with the Game Emu music plugin. from a NSF file of a NES and MSX game called Metal Gear. The source was a FLAC preview trancode with the Mono to Stero DSP plugin enabled.
EDIT:
I have uploaded the sample
LAME 3.98 Final
Reply #65
Thanks, another great release
BTW, I'm not sure if anyone's noticed but many of the pages on the official LAME sourceforge website are not valid XHTML 1.0 Transitional.
LAME 3.98 Final
Reply #66
john33, a big thank you for the LAME 3.98 compile(s) on Rarewares! Many thanks brother.
LAME 3.98 Final
Reply #67
Is there a 64 bit compile available from anyone yet?
LAME 3.98 Final
Reply #68
I know that there are 64bit versions of LAME out there for Unix, such as the version that I run on my x64 Arch Linux box, but I can't recall ever seeing one for Windows. Is a 64 bit version possible for Windows?
LAME 3.98 Final
Reply #69
There's an old one out there, apparently it was slightly faster, in the order on 10%, in 64-bit. I'm hoping someone has or will do a binary for 3.98.
LAME 3.98 Final
Reply #72
My LAME binary contain 64-bit code.
http://www.rarewares.org/files/mp3/Lame%203.98.dmg
Is that a Mac binary? Why DMG?
Disk images are the standard way of distributing programs in the Mac world (or at least it was when I sold my Mac and bought a PC in 2006). Sadly, in Windows almost every app maker seems to think you need an installer when a simply zip file would suffice.
But back on topic, I gave 3.98 a try and it seems very nice. I embedded cover art into a test file and Foobar and iTunes both picked it up fine. I also noticed in the command help that you can now supply not just the track number but also total tracks of the album. All in all, a nice update I'd say.
LAME 3.98 Final
Reply #73
I can't wait to update my apps.
I am a alt preset extreme kind of sort . I guess this is still V0?
Has this improved any over the early 3.98 betas?
LAME 3.98 Final
Reply #74
Since the "newer VBR code is now LAME's default VBR routine", does that mean that
-V0 --vbr-new
now simply becomes
-V0
