Topic: LAME 3.98 Final (Read 199065 times) previous topic - next topic
  • robert
LAME 3.98 Final
Reply #150
Where does that blank come frome in "Lame 3.98.2" ?
@vpa:
You'll have to rename the directory you created. Make doesn't like paths containing blanks.
  • Last Edit: 25 September, 2008, 02:06:18 PM by robert
  • vpa
LAME 3.98 Final
Reply #151
@vpa:
Thanks. It still doesn't work with gcc 3.3, but at least 4.0.1 compiles it now.
WavPack 4.50.1 -hhx6 | LAME 3.98.2 -V 0
  • /mnt
LAME 3.98 Final
Reply #152
I have just been doing some testing with V0 --vbr-new on LAME 3.97 and found a track that was not transparent to me at that setting and almost also on 3.98.2.
LAME 3.97 -V0 --vbr-new
foo_abx 1.3.3 report
foobar2000 v0.9.5.5
2008/09/28 00:18:38
File A: C:\Temp\LAME V0\White Zombie - Astro-Creep 2000\05. Electric Head, Pt. 2 (The Ecstasy).mp3
File B: C:\Rips\White Zombie - Astro-Creep 2000\05. Electric Head, Pt. 2 (The Ecstasy).flac
00:18:38 : Test started.
00:19:25 : 01/01  50.0%
00:19:31 : 02/02  25.0%
00:19:38 : 03/03  12.5%
00:19:44 : 04/04  6.3%
00:19:52 : 04/05  18.8%
00:19:55 : 05/06  10.9%
00:20:01 : 06/07  6.3%
00:20:06 : 07/08  3.5%
00:20:12 : 08/09  2.0%
00:20:16 : 08/10  5.5%
00:20:20 : 09/11  3.3%
00:20:24 : 10/12  1.9%
00:20:31 : 11/13  1.1%
00:20:39 : 12/14  0.6%
00:20:58 : 13/15  0.4%
00:21:08 : 14/16  0.2%
00:21:14 : 15/17  0.1%
00:21:18 : 16/18  0.1%
00:21:28 : 16/19  0.2%
00:21:34 : 17/20  0.1%
00:21:47 : 17/21  0.4%
00:21:57 : 18/22  0.2%
00:22:03 : 19/23  0.1%
00:22:12 : 20/24  0.1%
00:22:19 : 21/25  0.0%
00:22:24 : Test finished.
Total: 21/25 (0.0%)
Drum smearing at 0:06, or could be a stereo collapse artifact or a noise on the left channel.
LAME 3.98.2 -V0
foobar2000 v0.9.5.5
2008/09/28 00:38:44
File A: C:\Rips\White Zombie - Astro-Creep 2000\05. Electric Head, Pt. 2 (The Ecstasy).flac
File B: C:\Temp\Transcodes\Mp3\Electric Head, Pt. 2 (The Ecstasy) LAME 3.98.2.mp3
00:38:44 : Test started.
00:39:14 : 01/01  50.0%
00:39:37 : 02/02  25.0%
00:39:48 : 02/03  50.0%
00:39:54 : 03/04  31.3%
00:40:06 : 04/05  18.8%
00:40:12 : 05/06  10.9%
00:40:22 : 05/07  22.7%
00:40:29 : 06/08  14.5%
00:40:36 : 07/09  9.0%
00:40:50 : 07/10  17.2%
00:40:57 : 07/11  27.4%
00:41:08 : 08/12  19.4%
00:41:15 : 09/13  13.3%
00:41:26 : 10/14  9.0%
00:41:40 : 11/15  5.9%
00:41:47 : 12/16  3.8%
00:42:02 : 13/17  2.5%
00:42:07 : 13/18  4.8%
00:42:16 : 14/19  3.2%
00:42:27 : 15/20  2.1%
00:42:32 : 16/21  1.3%
00:42:37 : 17/22  0.8%
00:42:51 : 18/23  0.5%
00:42:59 : 19/24  0.3%
00:43:06 : 20/25  0.2%
00:43:14 : 21/26  0.1%
00:43:29 : 22/27  0.1%
00:43:40 : Test finished.
Total: 22/27 (0.1%)
The artifact at 0:06 is gone, but at 0:27 something sounds odd, which could be smearing.
I have uploaded a sample of the track.
  • Last Edit: 27 September, 2008, 09:21:17 PM by /mnt
  • krmathis
LAME 3.98 Final
Reply #153
I've compiled it long time ago on my G5 myself, but I just tried your universal binary: I get a bus error on my iMac G5  Maybe it's not realy "universal"?
"Universal" point to the fact that its both PPC and Intel code in the same binary.
Perhaps you don't run Mac OS 10.5, which is what I used to compile this...
  • vpa
LAME 3.98 Final
Reply #154
Yes indeed. I'm still running 10.4
  • Sylph
LAME 3.98 Final
Reply #155
Does anyone know why I cannot download lame_enc.dll from LAME's site and instead have to go to RareWares?
LAME 3.98 Final
Reply #156
Because the LAME site does not offer binaries at all due to patent restrictions (distributing sources does not require patent fees to be paid, distributing binaries does AFAIK).
  • Sylph
LAME 3.98 Final
Reply #157
Perhaps I am mistaken, but I think a few versions back that was possible.
Thank you for the reply.
  • robert
LAME 3.98 Final
Reply #158
@vpa:
What is the problem with gcc 3.3? At what point will the build process fail?
  • [JAZ]
LAME 3.98 Final
Reply #159
3.3 was labeled sometimes as a buggy version of gcc.
I have tried using version 3.4.5 in mingw (windows) and with it compiles just fine. Of course, it may be using different #define paths.
  • vpa
LAME 3.98 Final
Reply #160
I'll give it a try again this evening and post the error log.
  • francesco
LAME 3.98 Final
Reply #161
i have update lame to 3.98
but this version 3.98.2 is different i can't find the history about the 3.98.2
i mean in rarewares i can find 3.98.2
where can i find info about the  improvement about 3.98.2 vs 3.98
in the history i can find this , nothing about the 3.98.2
LAME 3.98.1    not yet released
    * Rogério Brito:
          o More fixes for the abx tool for Unix systems:
                + Plugged a memory leak.
                + Fixed an endianness problem: users of big-endian machines can now do abx tests.
          o Fixed history's HTML doctype
          o Fixed history so that it finally validates at W3's validator
          o Fixed compilation of frontend mp3rtp.c. Thanks to Kris Karas. Bugtracker item [ 2015432 ] mp3rtp missing uint16_t in lame 3.98
    * Robert Hegemann:
          o Fix for Bugtracker item [ 2031704 ] --id3v1-only didnt work in 3.98-final
          o Fix for Bugtracker item [ 2022035 ] encoder_padding value and resampling
          o Fix for Bugtracker item [ 2029282 ] Frequency filtering API broken in 3.98
          o Fix for Bugtracker item [ 2039648 ] potential memory leak in parse_args() function in parse.c
          o Fix for some tagging issues:
                + Made search for ID3v1 genres more sloppy, abbrevations may match more often as some simple typos. Examples:
                      # --tg "Alt. Rock" matches genre "Alternate Rock"
                      # --tg "acapela" matches genre "A Cappella"
                + New switch --pad-id3v2-size "n": adds ID3v2 tag with n padding bytes.
LAME 3.98    July 4 2008
    * Anton Sergunov:
          o Frontend DirectShow: enabling LAME dshow filter to connect to "File Writer Filter".
    * Rogério Brito:
          o Updates to the Debian Packaging
          o Fixes to the abx tool for Unix systems (so that more people can evaluate LAME's compression against the original files)
    * Alexander Leidinger:
          o explicitely link the math lib to the lame lib
          o add switch to disable the use of the compaq optimized math lib
  • Last Edit: 07 October, 2008, 12:00:06 PM by francesco
  • robert
LAME 3.98 Final
Reply #162
3.98.2 has a fix for a bug introduced in 3.98.1:
- [ 2123206 ] lame 3.98.1 segfaults with -h
  • vpa
LAME 3.98 Final
Reply #163
Well, I freshly depacked the source and now it also works with gcc3.3
Something must have been messed up that worse that even a make clean didn't fix it.
LAME 3.98 Final
Reply #164
and 3.98.2 is somehow broken. It doesn't compile on OS X. Neither with gcc 3.3 nor with 4.0.1 :
(cd .libs/libmp3lame.lax/libmpgdecoder.a && ar x /Users/frankseyen/Desktop/Lame 3.98.2/lame-398-2/libmp3lame/../mpglib/.libs/libmpgdecoder.a)
ar: /Users/frankseyen/Desktop/Lame: Inappropriate file type or format
make[3]: *** [libmp3lame.la] Error 1
I am having one hell of a time trying to figure out how to make the new Lame release work with EAC as it has no .exe file in the zip download! All the code stuff is so far over my head.  I need  simple answer as to how to get high rate VBR working with the new LAME release! (A command line code would be great once it is working!)
I realize there are many different command codes ( I have seen far too many!  ) but don't know how to decide on what is best for a highest rate VBR encode in EAC.
Thanks in advance for any help.
LAME 3.98 Final
Reply #165
Get the latest LAME bundle  here (3.98.2)
Then, follow the wiki for EAC + LAME
Forget about  --vbr-new  since it's by default in 3.98.2
--> -V0 %s %d
V0 is the best quality VBR setting
BUT:
Since the recent release of lame 3.98.2, I've read a lot of forum posts. Most of people who used V2 by the past now prefer V3 and even lower because of the constant development and improvement of the codec.
http://www.hydrogenaudio.org/forums/index....showtopic=65101
I'm 23, have a pretty good hearing and use V5.5 for portable. You'd be surprised the amazing quality you'll get.
  • Last Edit: 24 November, 2008, 02:29:17 PM by melomaniac
  • start78
LAME 3.98 Final
Reply #166
My experience with embedding album art:
foobar2000 shows it. My hardware player doesn't.
If i embed an albumart from the same source file with mp3tag, both f2k and my hardware player show it.
What i found out: Mp3tag embeds the albumart as "front cover", but an albumart embedded with the lame encoder is called "other".
Is there a way to tell the encoder to embed the albumart as "front cover"? Or would you call it worth a change for one of the next versions?
  • Last Edit: 02 November, 2008, 04:23:11 PM by start78
  • eschw95458
LAME 3.98 Final
Reply #167
Has anyone compiled 398.2 for os x.  If you have can you please point me to it.  Thanks
  • vpa
LAME 3.98 Final
Reply #168
If you are using a PowerPC Mac, then try Lame for OSX PPC
It contains a gcc 3.3 compile, a gcc 4.01 compile and a fresh cvs checkout (3.99 a1) compiled with gcc 4.01. I hope it's helpfull for you.
  • Last Edit: 13 December, 2008, 07:01:34 AM by vpa
  • sblasl
LAME 3.98 Final
Reply #169
How about a version for the Intel side of OS X?
Thanks in advance.
  • eschw95458
LAME 3.98 Final
Reply #170
Thanks for the reply, Sorry I didn't respond quicker I was gone for the holiday.
  I am not using PPC.  Intel Imac 2g Core Duo with 10.5.6.
  • Gew
LAME 3.98 Final
Reply #171
Just out of curiosity, why hasn't LAME v3.98.2 become the recommended version here at HA? Just about every music group (on "the scene") uses 3.97, prolly 'cuz it's HA-recommended. Me myself, I'm trying to figure out if there are any known disadvantages on 3.98 apart from 3.97? Known stability bugs? Compatibility bugs?? Anything(!) that would have you prefer 3.97 > 3.98.2? I've done lots of research, trying to fetch this answer someplace else, but there's not much to go on. And since I'm no audio pro, I'm kinda lost in a maze here..
Thankfor for all answers~
  • john33
LAME 3.98 Final
Reply #172
Just out of curiosity, why hasn't LAME v3.98.2 become the recommended version here at HA?....
Why do you say that? The Wiki clearly recommends 3.98.2.
John
My compiles and utilities are at http://www.rarewares.org/
  • Buckchoi
LAME 3.98 Final
Reply #173
"The Scene" appears to be slow to adopt new standards.
  • rohangc
LAME 3.98 Final
Reply #174
Maybe I am blind, but the wiki recommends the latest stable version, and the same page states that the latest stable version is 3.98. not 3.98.2. I just fixed this in the wiki.
