Topic: foo_httpcontrol (Read 952004 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
foo_httpcontrol
Reply #900
Hamallainen: any other troubles with ajquery? I'll look into bracket issue tonight
foo_httpcontrol
Reply #901
I have no other problem (but i don't think i have tested everything).
Just one question, where is supposed to appear show selection total time (from changelog 0.63) ? Near the queue total time ? If yes then it doesn't work for me.
foo_httpcontrol
Reply #902
try this: ajquery_0_65.zip
I've changed shift+]/[ to shift+pageup/pagedown, also made some changes to selection / queue / playlist totaltime indicator
foo_httpcontrol
Reply #903
Thanks. I've tested it a little today.
* shift+pageup/pagedown works but after a some testing it stopped working. If i reload the page, it sarts working again for a little while then stops. Also, sometimes but not always it makes the windows of 'folder browser', 'library search' and 'extra control' (but not album art) move up and down.
* selection totaltime always displays 0:00
queue totaltime works correctly
* also, about selection and shift / control. Sometimes shit behaves as control
I will try to test more tomorrow because right now i dont find a way to make 'shift+pageup/pagedown' and 'shift or control + click' completly working or completly not working.
Also, sorry for my english that is maybe not very understandable and is not helping describing and finding the problem
foo_httpcontrol
Reply #904
if you catch any javascript errors in your browser's error console when selection totaltime turns to 0, it would be helpful. take a screenshot too, please.
anyway, I didn't succeed in finding issues you described in opera/chrome/firefox. I need a step-by-step problem cooking recipe to understand what and where is wrong.
edit: playlist resize stops working when something is selected, fixed. reproduced moving windows (in chrome). still no luck with total time.
foo_httpcontrol
Reply #905
try latest component version, I've just removed additional non-ascii char stripping which seems to affect most of the 3rd party templates.
Thanks, that helped alot. I still have some issues though (lxofith, kevo): can't add tracks to the playlist, it seems as if the link is removed from the plugin. The refresh for the playlist overview seems odd, i have to play a new track for proper refresh. I assume this has to be fixed in the templates.
Great plugin though, i use it alot and love it!!
foo_httpcontrol
Reply #906
files seem to add properly in aforementioned templates using deskop browser. playlist refresh issue seems to be by design, template doesn't request updated data when it should.
anyway, I don't have spare time and interest to maintain all this stuff, so I have to rely on you, end users, on that.
foo_httpcontrol
Reply #907
First, let me say that I have been using the HTTP Control Foobar plugin for a couple of years, and have found it to be excellent. Simple, lightweight, and it just works. Thank you for creating this excellent add-on for Foobar!
Second, I have to ask for help with an issue I've been happening for the last few days. The HTTP Copntrol plug-in will no longer bind to the port I have been using (port 10). I use port 10 to control the music within my network (at my house) from other areas around the house. I've done all the basic things I can think of you troubleshoot the issue (listed below), and cannot figure out where the issue may be. I can't think of anything which has changed on the computer over the last few days other than typical "Windows Updates" types of changes. I'm using Foobar version 1.1.2.
Any help you can provide would be much appreciated!
My plug-in is configured to bind to port 10 on IP address 10.0.0.45. When starting the server I receive a message of "No, bind failed".
From the console I see the following messages:
Error: foo_httpcontrol: bind failed.
foo_httpcontrol: WSAEventSelect Failed
When using 'netstat' to discover listening ports I don't see port 10 in the list (using the command: C:\>netstat -an |find /i "listening")
I turned off my Windows Firewall in the hopes that the firewall was suddenly blocking traffic to that port. I first verified that the Foobar application is int he list of "allowed apps" in the firewall, and then tried turning the firewall off. No luck.
Can you provide any additional troubleshooting steps or tools I can try to resolve the issue?
foo_httpcontrol
Reply #908
first of all, double check that one of your network interfaces have an ip address 10.0.0.45.
have you tried using another port number, bigger than 1024? I have a suspiction you need administrative account and elevated privileges if you want port 10 on windows 7.
edit: I've tested setting port 10 on my w7 x64 and it works in all ip cases: 127.0.0.1, my lan ip and 0.0.0.0.
foo_httpcontrol
Reply #909
hello oblikoamorale,
i don't read the whole 37 pages,
but do you mind to add an extra option to the preferences page like
[x] Bind to local computers ip-address
thus would make it easier for us people who are using foobar portable *not* to insert the local ip-adress every time we're on a new computer, but use the current ip automatic.
EDIT: sorry, found a new version (i'm so into that "get updates" button of foobar, that a almost forget to update your plugin manually) and my which came true with http://127.0.0.1:port/ 8-)
nevermind. great extension to foobar.
foo_httpcontrol
Reply #910
can't edit my last post, so i need to reply to my self.
sorry again, but that did not do the job quite as needed.
seeing this, i'd like to extend my previous request a little bit for more clarifying:
the local ip-address which is not the the local loopback device 120.0.0.1 but the ip-address which can be reached withing the whole network.
especialy for users using laptops which use DHCP only this will be good.
foo_httpcontrol
Reply #911
Have you tried 0.0.0.0? I have mine set as such and it is accessible on any active network connections.
foo_httpcontrol
Reply #912
yes, i did.
i tried 0.0.0.0:8881
and the button shows "open http://127.0.0.1:8881/"
which is available only on the local computer, not in my lan.
also checking the ip of that computer in a browser from an other computer did not work. (of course not, because the plugin is only listening on the loopback device.)
but it does work, if i enter the "correct" ip address of that computer, 192.168.1.88:8881, in the plugin and check that ip from an other computes browser. so there is no firewall problem which should be a problem, i assume.
EDIT:
well, after reading your post and assuming: if it works on your side, it must work here too,
i removed the complete "\foobar2000\user-components\foo_httpcontrol" folder and "\foobar2000\foo_httpcontrol_data" too and the config-file in "foobar2000\configuration\foo_httpcontrol.dll.cfg" and started all over.
guess what?
now it works. thank you!
foo_httpcontrol
Reply #913
fuffi: setting 0.0.0.0 in "Listen on" preferences field makes component listen for incoming connections on all available interfaces. you've been confused by "Open http://127.0.0.0:8888" button when you entered 0.0.0.0, but logically it's ok since 127.0.0.1 is a valid subset of available interfaces.
I didn't want to spend any time figuring out how to enumerate network interfaces and retrieving their parameters to put one of their ip addresses into this button caption, so I figured putting 127.0.0.1 will be enough in this case.
Note that after you change "Listen on" value, I think you have to restart fb2k or restart server by unchecking "Start server", pressing Apply, and checking "Start server" and Apply again.
foo_httpcontrol
Reply #914
thank you for the explanation. i did restart the server, but i did not restart foobar. maybe that was the problem.
now it works and i'm sorry to bother you with no "real" problem :-)
cheers,
foo_httpcontrol
Reply #915
I have double-checked everything you suggested. It's quite odd. I was running the "port 10" configuration on my Windows 7 64 bit machine for the last year or two without issue. All of a sudden it stopped working. I've tested ports from 10 through 8888 (trying random numbers in that range). Can't get any of them to bind. The machine does still have an IP of 10.0.0.45.
I'm going to try and install other types of remote control plug-ins to see if they can successfully bind to a port.
If you have any other troubleshooting steps or suggestions for me I'm open to trying anything to better understand the issue and how to resolve it!
Thanks for your help and your FANTASTIC Foobar plug-in!
foo_httpcontrol
Reply #916
I was able to fix my problem with a Windows System Restore. My guess is that a windows update or a security essentials update somehow compromised the machine's ability to allow port binding.
I realized that the remote desktop protocol was no longer allowing connections, and this made me suspicious that the fact that port 3389 for RDP was failing, Foobar HTTP Control was failing, and it was more of a systemic issue with my machine.
So.....nevermind! Thanks for your attempts at helping me!
foo_httpcontrol
Reply #917
hello,
it's me again.
i recogized, that, with every "automatic" update via the "get updates"-button from foobar,
the plugin folder will be complete deleted and filled only with data from the installed zip.
this means for me, i cannot store data/information/notes/configuration-examples, etc into that folders anymore, so i need a new place, relative to the plugins.
storing data in the foobar mail folder is not what i like to do, because it bloats the folder.
so i created a folder "user-configuration" in the foobar mainfolder
e:\tc\portable\foobar2000\user-configuration\<pluginname_data>
to store my configuration/files/notes/information.
now, my question related to this plugin:
how to put that path into the "home directory" setting, if i want to keep my portability.
i cannot store "e:\tc\portable\foobar2000\user-configuration\foo_httpcontrol_data"
because on another machine E:\ does not exists.
https://code.google.com/p/foo-httpcontrol/wiki/Installation did not helped me, and %APPDATA% points not to the folders, i'd like.
anybody a hint? maybe something with ..\ or .\..\ ?
i tried that, but didnt figured it out to work.
foo_httpcontrol
Reply #918
component is not uploaded to official foobar2000 components repository so it's not a subject to autoupdating, replacing files or whatever else you are thinking of. don't worry and use your user profile\foobar2000\foo_httpcontrol_data as before.
foo_httpcontrol
Reply #919
yes, i forgot about that. agian.
so you don't want to make this an official plugin anywhen? (i had no crashes of you fine plugin until now, althougth, the foobar toubleshooter told me sometimes. if i remember right.)
foo_httpcontrol
Reply #921
The iPhone remote controls of anamon are out now as stand-alone versions.
Get info here.
Demo video here.
foo_httpcontrol
Reply #922
I am unable to open the URL:PORT on my iphone though  .
My iphone is connected via wifi on the same network as my computer.
foo_httpcontrol
Reply #923
check your firewall settings for foobar2000.
You can also check, if the server has started by clicking the button 'open http://...' in httpcontrol preferences...
edit: typo
foo_httpcontrol
Reply #924
Turned out to be my firewall, thanks
