Topic: [Not my release] foo_uie_panel_splitter (Read 411438 times) previous topic - next topic
Reply #925
Hey, guys. Does anyone know what can cause this behavior? The button doesn't show up until I hover over it.
Here is a code:
$if($isvisible_c(Playlistmanager),
$movepanel_c(Albumlist,0,0,%_width%,$sub(%_height%,$div(%_height%,3)))
$drawrect(0,$sub(%_height%,$div(%_height%,3)),%_width%,24,40-40-40,,)
$textbutton(0,$sub(%_height%,$div(%_height%,3)),%_width%,24,$drawtext(PLAYLIST MANAGER,0,$sub(%_height%,$div(%_height%,3)),%_width%,24,150-152-154, hcenter vcenter),$drawtext(PLAYLIST MANAGER,0,$sub(%_height%,$div(%_height%,3)),%_width%,24,150-152-154, hcenter vcenter),PANELSHOW:Playlistmanager:0;REFRESH,options1,options2),
$movepanel_c(Albumlist,0,0,%_width%,$sub(%_height%,24))
$drawrect(0,$sub(%_height%, 24),%_width%,24,40-40-40,,)
$textbutton(0,$sub(%_height%, 24),%_width%,24,$drawtext(PLAYLIST MANAGER,0,$sub(%_height%, 24),%_width%,24,150-152-154, hcenter vcenter),$drawtext(PLAYLIST MANAGER,0,$sub(%_height%, 24),%_width%,24,150-152-154, hcenter vcenter),PANELSHOW:Playlistmanager:-1;REFRESH,options1,options2)
Reply #926
This "isvisible" and "Panelshow" doesn't works very well...
I use global variables and showpanel instead.
Btw. you use many unnecessary code in your script...
"drawtext" in textbutton?
"drawrect" outside a textbutton?
Try this:
$init_ps_global(pl.manager,0)
$puts(btn.y,$ifequal(%pl.manager%,0,$sub(%ps_height%,24),$muldiv(%ps_height%,2,3)))
$puts(btn.cmd,$ifequal(%pl.manager%,0,1,0))
$showpanel_c(Playlistmanager,$ifequal(%pl.manager%,1,1,0))
$textbutton(0,$get(btn.y),%ps_width%,24,PLAYLIST MANAGER,PLAYLIST MANAGER,SETGLOBAL:pl.manager:$get(btn.cmd);REFRESH,brushcolor:40-40-40 fontcolor:150-152-154 hcenter vcenter,brushcolor:40-40-40 fontcolor:150-152-154 hcenter vcenter)
    $movepanel_c(Albumlist,0,0,%ps_width%,$muldiv(%ps_height%,2,3))
    $movepanel_c(Playlistmanager,0,$add($muldiv(%ps_height%,2,3),24),%ps_width%,$sub($div(%ps_height%,3),24))
    $movepanel_c(Albumlist,0,0,%ps_width%,$sub(%ps_height%,24))
    $movepanel_c(Playlistmanager,0,0,0,0)
Of course this will only work really well, when your "Playlist Manager" is correctly placed..
So i added $movepanel_c() with its guessed coordinates.
(haven't tested it, but it should work... hopefully :-))
EDIT: have forgot something...
Make sure, you haven't placed your albumlist with other coordinates on Panel List tab or with another $movepanel_c() in your script, because it looks like you draw your button over the panel...
Reply #927
Sorry, tried it now and there was still a little issue because Playlistmanager was drawn over the Albumlist...
So $movepanel_c(Playlistmanager,...) must be placed one line above the $movepanel_c(Albumlist,...)
PSS is not really convenient...
Corrected code:
Reply #928
tedgo, thank you so much! Your code works great.
Actually, this was my first attempt at working with PSS. Well, and now I know that I should use global variables. :3
Reply #929
ugly, ugly hacks...
SETGLOBAL:NAME:VALUE;COMMAND:Playback/Play or pause;COMMAND:Playback/Play or pause
you don't need REFRESH because it would be redundant with the above addition. this is completely inaudible using the default output method (directsound). i have vague recollections of people hearing glitches when using either ASIO/wasapi. YMMV.
Hey thanks for this hack, I've yet to try it but what's the point of global variables in PSS then? I thought they were used to control code between two different panels.
Reply #930
A new splitter for DUI is on the way (Author: ttsping)
ESLyric panel + wsh panel
Reply #931
I'm trying to achieve something like this. So basically what I'm doing is using the $imageabs_rc function to crop the album cover pic and resize it as a background, but the result is not blurred enough.
Is there a way to increase the blur effect?
I'm late
Reply #932
Is it possible to trigger multiple commands with the $imagebutton function?
I'm late
Reply #933
yes.
Re: [Not my release] foo_uie_panel_splitter
Reply #935
Is there a way to trigger the MENU and CONTEXT commands used in the button functions, on a per track basis? In other words, performing a command when the track changes?
I'm late
Reply #936
I would like to add a button the toggles a child panel. The problem is that the button has to be on the same area of the child panel. I wrote the $movepanel function first and the $imagebutton second, but when I hit the button the panel covers the button and I can't use it to hide the panel. Is there a way to have the button always on top?
I'm late
Reply #937
I badly need a trick to make a panel behave like a button. Basically I would like to perform a command whenever I click on that panel. I tried overlaying a transparent pic $imagebutton on that panel, but it looks like the panel covers the button, no matter the order I write the $imagebutton and $movepanel functions.
Any smart idea to achieve what I want?
I'm late
Reply #938
Is there some reason that COMMAND:'View/Switch to playlist/Radio' doesn't work in a $textbutton? Most every other command works so it's not an issue with the button.
Reply #939
^It's because the menu items are dynamic and not fixed. You could have 1 playlist or 100 - changing all the time. Only components developed with the v1 SDK and newer can launch dynamic commands. WSH panel mod and JScript panel can do it with fb.RunMainMenuCommand.
Reply #940
If the colours are the same as in the Windows SDK, this may help.  This is the help info for the Windows SDK GetSysColor():
COLOR_ACTIVECAPTION
2
Active window title bar.
Specifies the left side color in the color gradient of an active window's title bar if the gradient effect is enabled.
Windows NT and Windows 95:  This remark does not apply.
Did anybody succeed using this with windows 10? I'm trying to replicate the custom title bar colour by using color index 2, but I get a totally different one. Am I using the wrong color index?
EDIT: by custom colors I mean these:
I'm late
Reply #941
I'm trying to have the Y coordinate of a panel be dependent on the value of two global variables. This means it could have 4 different outcomes each having a different value assigned. I tried some combinations or expressions but have little luck.
This doesn't work, yes I know $equal isn't a function (it should be) but can't seem to think of any other way here. Can anyone advise?
$puts(PLAYLIST.Y,
$if($and($equal(%_PLAYLISTX_EXPANDED%,1),$equal(%_FILTER_MODE%,1)),150,
$if($and($equal(%_PLAYLISTX_EXPANDED%,1),$equal(%_FILTER_MODE%,0)),200,
$if($and($equal(%_PLAYLISTX_EXPANDED%,0),$equal(%_FILTER_MODE%,1)),250,
$if($and($equal(%_PLAYLISTX_EXPANDED%,0),$equal(%_FILTER_MODE%,0)),300,
Reply #942
$puts(PLAYLIST.Y,
Try this:
$puts(PLAYLIST.Y,$sub(300,$mul(50,$add($mul(2,%_PLAYLISTX_EXPANDED%),%_FILTER_MODE%))))
EDIT: sorry, there was a last bracket missing, which I added now.
I'm late
Reply #943
Thank you for your answer, it seems to work (you missed a ')' in the expression at the end). But surely there is an a more elegant way of doing this. The numbers I provided were just an example and I don't see this working great with any random numbers which is actually what I'm looking for.
For instance if I were to make it like this I don't see it working well. Especially if I scale it up to 3 global variables instead of 2.
$puts(PLAYLIST.Y,
$if($and($equal(%_PLAYLISTX_EXPANDED%,1),$equal(%_FILTER_MODE%,1)),1167,
$if($and($equal(%_PLAYLISTX_EXPANDED%,1),$equal(%_FILTER_MODE%,0)),90,
$if($and($equal(%_PLAYLISTX_EXPANDED%,0),$equal(%_FILTER_MODE%,1)),310,
$if($and($equal(%_PLAYLISTX_EXPANDED%,0),$equal(%_FILTER_MODE%,0)),1130,
Reply #944
Yes, I edited my previous post when I realized it, but not on time  ;)
$puts(PLAYLIST.Y,
How about this?
$puts(myvar,$sum($mul(2,%_PLAYLISTX_EXPANDED%),%_FILTER_MODE%))
$puts(PLAYLIST.Y,
$ifequal($get(myvar),3,1167,
$ifequal($get(myvar),2,90,
$ifequal($get(myvar),1,310,1130))))
I'm late
Reply #945
Here's the 3 variables version:
$puts(myvar,$sum(%mul(3,%THIRD_VARIABLE%),$mul(2,%_PLAYLISTX_EXPANDED%),%_FILTER_MODE%))
$puts(PLAYLIST.Y,
$ifequal($get(myvar),6,n1,
$ifequal($get(myvar),5,n2,
$ifequal($get(myvar),4,n3,
$ifequal($get(myvar),3,n4,
$ifequal($get(myvar),2,n5,
$ifequal($get(myvar),1,n6,n7)))))))
I'm late
Reply #946
COLOR_ACTIVECAPTION
2
Apparently the color I'm looking for is the system accent color. So, the question now is: is there a color index for the windows 10 accent color that can be used in the $getsyscolor function?
I'm late
Reply #947
I see the logic in your solution and to my estimate it should work but I'm not getting the expected result. I'll have to look into it a bit further to establish if there's more going on here with my script. Thanks for the replies.
Reply #948
Sorry, I just noticed my mistake.: there was a parameter missing in the last $ifequal statement, which I edited now.
I'm late
Reply #949
It seems to only respond on the last value.
Using this
$puts(PLAYLIST.Y,
Only 1130 is recognized no matter what combinations of global values I use. Strange.
