Topic: .Ogg Vorbis aotuv (Read 502997 times) previous topic - next topic
.Ogg Vorbis aotuv
Reply #375
just want to say thanks to Aoyumi for all your hard work and report a bug in your(and almost every other ogg encoder I have found) with LONG audio file conversion.
on files 6+hours long the encoder just errors out (not sure where the cut off is,  3hrs is fine, 6 errors), the only vorbis encoder I have found that dosnt have this issue no matter the file length/size is Spoon's encoder (dbpoweramp).
to explain I listen to alot of audio books, And size for quality I prefer vorbis to mp3, I just happened to run into this bug A while back and hope somebody can address the issue so i dont have to use spoons SLOW encoder despite its great quality its just SLOW.
.Ogg Vorbis aotuv
Reply #376
The encoding is possible via standard input in the current VENC.
I don't know about other encoders. Sorry.
.Ogg Vorbis aotuv
Reply #377
Aoyumi, is your patch available somewhere so I can patch my libvorbis 1.3.1 in Linux with it?
.Ogg Vorbis aotuv
Reply #378
There is not the patch for the moment.
If you use Wine on Linux, you can use the test version.
.Ogg Vorbis aotuv
Reply #379
libvorbis is used by other software I use: Native Linux software. Wine doesn't help. Wine only runs Windows programs.
Anyway, it would be nice if you could post your patch, not just the binary. Please don't forget that you are required (I think) to do this in the first place because of the libvorbis license terms.
.Ogg Vorbis aotuv
Reply #380
Anyway, it would be nice if you could post your patch, not just the binary. Please don't forget that you are required to do this in the first place because of the libvorbis license terms.
libvorbis has BSD-style license.
libvorbis - Copyright © 2002-2008 Xiph.org Foundation
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
- Neither the name of the Xiph.org Foundation nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
That's all.
.Ogg Vorbis aotuv
Reply #381
That it is used by various programs was not assumed.
I am concerned about a test copy being used in a wide range.
I respect software with developers.
Therefore I think that the license issue should be read carefully.
By the way, did you confirm a license terms?
[>> lvqcl]
Thank you for quotation.
.Ogg Vorbis aotuv
Reply #382
I wasn't sure about the license. I assumed Vorbis was open source, which means we need to have the source. At least I'm sure it was open source in the past at some point. But I guess other people know this stuff better than me.
Anyway, it's sad that you don't provide the patch for this  That way you only support Windows users and windows programs, which I don't use. Why not provide the patch? You provide the binary, so why not the patch? It would help many people. I'm still stuck to libvorbis 1.2.1, which has been dropped by my Linux distribution because it has security issues, and also it makes using some new versions of various programs impossible because they only work with new versions of libvorbis.
Please, consider providing a patch so that we can use new libvorbis + aotuv.
.Ogg Vorbis aotuv
Reply #383
If you have observed the history of Aoyumi's work, you should know that he always tests in this way and then once he is satisfied with his tuning efforts, full source is provided. The testing currently tasking place should probably be regarded as alpha testing of the incremental tuning that's taking place. Please be patient, you'll have access to the source once this next version is released. It's not usual to release source while testing is taking place.
BTW, 'open source' is a loose term that doesn't begin to define the terms of the licence under which it may be made available.
.Ogg Vorbis aotuv
Reply #384
I love people who are rude(sorry but the attitude Nikaki puts forth is quite rude in my opinion) and expect to get what they demand.
I see this more in "open source" situations then in any others, I dont know why it is other then the fact that many FOSS people feel entitled to get what they want when they want it.....
I want to thank you again for your hard work Aoyumi, You are the one person who is actually trying to improve vorbis, and I for one respect that, dont let Hikaki's attitude bother you, and keep up the excellent work!!
.Ogg Vorbis aotuv
Reply #385
Preparations are necessary to open it. It takes far time than I show test build.  For example, the source cord overflows with  personal memo, and it is necessary for it to rewrite it beforehand.
Of course the work is not only it.
It is very likely that I don't show the test binary at present if there was the premise to open the source cord.
.Ogg Vorbis aotuv
Reply #386
@AshenTech
I'm not rude. I only wanted to use this with non-Windows operating systems. One has to be pretty emo to be offended by anything I said, since it was not rude by any stretch of the imagination.
@Aoyumi
We don't need the source code because we want to look at it  We only need it so we can compile it. It doesn't matter if the source is pretty or not.
.Ogg Vorbis aotuv
Reply #387
Well, you wont get the source code, no matter how much you whine, because test version is only for testing (and there are enough testers on windows), not for people using it. You need to develop some patience, until Aoyumi considers the new aotuv ready you can always use the previous version.
.Ogg Vorbis aotuv
Reply #388
@AshenTech
Actually, I interpreted it as rude. A polite request and the graciousness to accept the answer you don't want would be open-minded.
So... (resume topic) I am always enthusiastic about cutting-edge tunings of Vorbis in the low bitrate range, I am rather fond of the results of -q-2 as an alternative for my radio show online archive to the more obscure Speex format (not knocking Speex, it just Vorbis has the advantage of having more supported players).
.Ogg Vorbis aotuv
Reply #389
just a quick note, the sansa clip/clip+ and fuze all now have rockbox so speex is OK on its support by affordable players, but you are correct vorbis would be more supported.
I personally find q-0 to be the best choice for audio books and radio shows as when the audio gets more complex it scales up, but normally it keeps the bitrate very close to what speex gives me at its top quality settings.
q--2 (-2) can sound horrible on some headphones due to artifacts(dont really think anybody has optimized the - numbers to much even for voice)
and Im glad Im not the only one who saw his comments/attitude as rude, it came off as very demanding, as if hes entitled to get what he wants when he wants it........reminds me of my buddies teen age daughter who lived with her mother for a few years, spoiled little brat......
.Ogg Vorbis aotuv
Reply #390
@Aoyumi:
Hello, I found that vorbis 1.3.1 for q4 or more has better stereo separation (or stereo fidelity) than the aotuv b5.7.
I look in the source of 1.3.1 and they put a lot of rewrite code in psy.c
please consider take attention in stereo sound stage and intensity of the music in your tunnings, they do a very good job in the harshness of some songs IMHO
sorry i sound rude, my inglish is poor
thanks
.Ogg Vorbis aotuv
Reply #391
Now you're the one being rude, accusing me of whining.
Well, that's the problem. I can't. It's been blacklisted for security reasons (that older libvorbis version has security bugs). I know that Windows doesn't care about stuff like this, but other OSes do.
.Ogg Vorbis aotuv
Reply #392
Enough with the open source, Windows vs *nix yawnathon.  Any further posts on the subject will be permanently deleted, and users will receive a TOS #5 warning.
I'm on a horse.
.Ogg Vorbis aotuv
Reply #393
It is the same thing for me.
I can understand your thought, but cannot go along.
I can say nothing as far as there is not the sample.
But the stereo processing is changed with the existing test version.
.Ogg Vorbis aotuv
Reply #394
I test venc,exe version aoTuV post-beta5.7 [20100718] at -q2
with de aotuv b5.7 the song Wild Wild West of will smith, and in the chorus at the 2nd voice that have a high pitch i hear a little loss of power and stereo, is like a loss of high frecuency fault like blur or something.
but with de testing version post b5.7(above) i can't hear  a big difference, in fact i hear differences (i guess for the quality level) but the energy of the music is almost the same
b5.7 = 99kbps (q2)
testing= 107 kbps  (q2)
K:\>venc -q2 www.wav www.ogg
aoTuV Post Beta 5.7 - OggVorbis Encoder (c) 2003-2010 Aoyumi
Output file : "www.ogg"
Stream info.: 2ch/44.1kHz/16bit(int) -> 2ch/44.1kHz/32bit(float)
Quality 2 (nominal bitrate : 96kbps)
Processing...Done.
[Report of the encoded file]
   play time    : 245.533 sec.
  encode time   : 11.692 sec. (x21.000)
stream bitrate : 107.34 kbps
bit reduction  : 1 / 13.1
i think tha is most visible the stereo at high quality (q4 or q5) when the music is more detailed and at this level of q i cant hear (q2) any artifacts but i hear the loss of power  or wide stereo image or blur or roughness .
in conclusion, i'm waiting the new aotuv version based in the code of stereo  procesing of  1.3 series
thanks mr. aoyumi
PD: i hear the difference in the stereo in the songs with 360º stereo sound like the chorus of "s club 7- friday night"  but others with flat stereo i can't hear nothing
.Ogg Vorbis aotuv
Reply #395
AlexDDR,
It will be helpful if you will upload up to 30 seconds (allowed limit) of  mentioned sample somewhere. It could be Upload section or somewhere else like rapidshare.
The words has a little meaning without sample.
Also, read the rules. Especially N8.
.Ogg Vorbis aotuv
Reply #396
AlexDDR,
Sorry my mistake for not having posted results of ABX to confirm my findings, until then I beg you not to take into account my long post until I have the ABX support we'll see how it goes with foobar and ABX.
thakns for the warning, I was a little disoriented
.Ogg Vorbis aotuv
Reply #397
I released the new test version. (for tester)
CHANGES (from post-beta5.7 [20100718])
* The one of the issue of noise to rarely occur at the low bit rate (eg -q-2) was improved.
* New dynamic stereo processing is added.
If you found the problem that is peculiar to this version, please inform me.
.Ogg Vorbis aotuv
Reply #398
Any feedback on this build it's been a month without any reply or bugs found.
Keep up the good work Aoyumi, I've been following your progress for few years.
Thank you for your great work!!!
.Ogg Vorbis aotuv
Reply #399
Hello,
I'm looking forward to the next version.
Thank's for your excellent work, Aoyumi.
Best regards
akapuma
