Topic: foo_bubble_coverflow (Read 420456 times) previous topic - next topic
Reply #100
I am getting this with Version 0.12:
ERROR  foo_bubble_coverflow: This plugin needs a hardware video card supporting OpenGL
Version 0.11 worked fine.
Ha you're the first user hit by this message, congratulation!
It's a check, when a OpenGL window could be created to see if it's not using the software renderer because I saw a crash yesterday on my PC when this was used.
Can you install the older version (it's still on http://bubbleguuum.free.fr/foo_bubble_coverflow) and copy paste the content of the foobar console ?
Reply #101
Hi bubbleguuum...tested version v.0.12 works great here on foobar v.0.9.5...I like the shading and reflections, and the option for a no cover file is great!...but I was wondering change you change the font of the "front cover caption"
Reply #102
Here is the output from the console with version 0.11
ERROR : hello
Microsoft Corporation
GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
GLEW_ARB_texture_non_power_of_two not supported
ARB_texture_rectangle not supported
EXT_texture_rectangle not supported
comserver2: Registering class objects succeeded.
Autoplaylists initialized in: 0:00.000282
ERROR : Could Not Unregister Class.
create_by_guid failed: 1D56881C-CA24-470C-944A-DED830F9E95D
Startup time : 0:11.618942
Surf's Up!
"Columnated Ruins Domino"
Reply #103
I updated my video driver and now version 0.12 is working. Here is the updated Console printout:
foo_bubble_coverflow: OpenGL vendor: NVIDIA Corporation
foo_bubble_coverflow: OpenGL version: 1.5.7
foo_bubble_coverflow: OpenGL extensions:
GL_ARB_imaging GL_ARB_multitexture
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shading_language_100
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_rectangle
GL_ARB_transpose_matrix
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_S3_s3tc GL_EXT_texture_env_add
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shared_texture_palette
GL_EXT_stencil_wrap
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_object
GL_EXT_vertex_array
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region
GL_NV_blend_square
GL_NV_fence
GL_NV_fog_distance
GL_NV_light_max_exponent
GL_NV_packed_depth_stencil
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_register_combiners
GL_NV_texgen_reflection
GL_NV_texture_env_combine4
GL_NV_texture_rectangle
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_SGIS_generate_mipmap
GL_SGIS_multitexture
GL_SGIS_texture_lod
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
foo_bubble_coverflow: ARB_texture_non_power_of_two: no
foo_bubble_coverflow: ARB_texture_rectangle: yes
foo_bubble_coverflow: EXT_texture_rectangle: no
foo_bubble_coverflow: EXT_texture_filter_anisotropic: yes
foo_bubble_coverflow: SGIS_generate_mipmap: yes
foo_bubble_coverflow: WGL_ARB_multisample: no
foo_bubble_coverflow: WGL_EXT_swap_control: yes
foo_bubble_coverflow: Swap interval = 1
Thanks for your help, Bubbleguuum!
Surf's Up!
Reply #104
Hi bubbleguuum,
Just enquiring, any chance of a version that read embedded album art? Would be nice. It is still a great plugin nonetheless.
Thank you!!!
Reply #105
Just re-installed everything nice a fresh with a new PUI, and still whenever I put the panel in, it pops up a new window.
Please is someone could help me, I just updated my vid drivers, and still no help,.. could it be a prob with Windowblinds?
Please, any help would be appreciated.
Reply #106
Hm, crashed again. The interesting thing is, when i freshly add the dll to my components folder - after deleting the settings of coverflow - it all works. Then, after quitting and restarting foobar, the crash happens.
Win XP SP2, Radeon x1650 with latest drivers.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00B7AF62h
Access violation, operation: read, address: 00000004h
Call path:
entry=>user_interface::init
Code bytes (00B7AF62h):
00B7AF22h:  01 00 8B 54 24 14 8B FE 89 46 08 89 56 04 89 7C
00B7AF32h:  24 14 EB 06 89 44 24 14 8B F8 C7 44 24 60 FF FF
00B7AF42h:  FF FF F6 44 24 10 01 74 17 33 FF 8D 74 24 20 C7
00B7AF52h:  44 24 24 00 00 00 00 E8 42 04 00 00 8B 7C 24 14
00B7AF62h:  8B 4F 04 8D 44 24 0C 50 33 F6 51 89 74 24 14 E8
00B7AF72h:  28 65 01 00 3B C6 74 03 89 47 08 8B 47 04 8D 54
00B7AF82h:  24 10 52 50 89 74 24 18 E8 E5 64 01 00 3B C6 74
00B7AF92h:  03 89 47 08 8B 4C 24 0C 8D 54 24 3C 52 68 08 18
Stack (0012D6FCh):
0012D6DCh:  7FFDE000 AA966398 AA965D34 00000001
0012D6ECh:  AA965F9C 0000003B 00000083 007EE328
0012D6FCh:  3F31DB61 019E3E10 019E3FC8 00007603
0012D70Ch:  00000000 00000000 3F31DB79 00000000
0012D71Ch:  7C91EE18 7C9206F0 FFFFFFFF 7C9206EB
0012D72Ch:  00B876CD 019E0000 00000000 00000020
0012D73Ch:  019E3E10 019E3A54 00000000 0012D760
0012D74Ch:  00B87C3B 00000020 0012D79C 00B94BF8
0012D75Ch:  FFFFFFFF 0012D7F0 0012D7F0 00B76265
0012D76Ch:  3F31DB11 019E3DD0 019E3A54 0012D820
0012D77Ch:  00000000 00B779C2 019E4100 019E4228
0012D78Ch:  019E3DD0 019E3A54 00000000 0000000F
0012D79Ch:  0012D814 00B94EF8 FFFFFFFF 00B7671E
0012D7ACh:  00000000 0012D7F0 3F31DBD9 019E3A54
0012D7BCh:  004EAC08 00000001 004D0F50 00000002
0012D7CCh:  00000002 0000002E 019E3A54 0012D81C
0012D7DCh:  00000000 00000000 00000000 019E3DD0
0012D7ECh:  019E41B8 00464954 019E42C0 0012D83C
0012D7FCh:  00000001 0000001B 00000047 0000004F
0012D80Ch:  3F31DBA5 0012D864 0012D864 00B95090
Registers:
EAX: 00000000, EBX: 019E3FC8, ECX: 7FFDE000, EDX: 4ED2627C
ESI: 00000000, EDI: 00000000, EBP: 0012D764, ESP: 0012D6FC
Crash location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Loaded modules:
foobar2000                      loaded at 00400000h - 0051E000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C907000h
COMCTL32                        loaded at 773A0000h - 774A3000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE2000h
Secur32                          loaded at 77FC0000h - 77FD1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 7E360000h - 7E3F0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7E670000h - 7EE91000h
ole32                            loaded at 774B0000h - 775ED000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
uxtheme                          loaded at 5B0F0000h - 5B128000h
LgWndHk                          loaded at 003C0000h - 003C7000h
MSCTF                            loaded at 746A0000h - 746EB000h
msctfime                        loaded at 75250000h - 7527E000h
foo_abx                          loaded at 00A90000h - 00AC3000h
foo_albumlist                    loaded at 00AE0000h - 00B45000h
foo_bubble_coverflow            loaded at 00B70000h - 00BB3000h
OPENGL32                        loaded at 5F0D0000h - 5F19C000h
GLU32                            loaded at 68FC0000h - 68FE0000h
DDRAW                            loaded at 736D0000h - 73719000h
DCIMAN32                        loaded at 73B30000h - 73B36000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
foo_cdda                        loaded at 019F0000h - 01A25000h
foo_converter                    loaded at 01A50000h - 01AB5000h
foo_dsp_std                      loaded at 01AE0000h - 01B27000h
foo_fileops                      loaded at 01B50000h - 01B97000h
OLEAUT32                        loaded at 770F0000h - 7717B000h
foo_freedb2                      loaded at 01BC0000h - 01C01000h
foo_input_shorten                loaded at 01C30000h - 01C5D000h
foo_input_std                    loaded at 01C80000h - 01DA5000h
foo_masstag                      loaded at 01DD0000h - 01E20000h
foo_rgscan                      loaded at 01E40000h - 01E90000h
foo_ui_columns                  loaded at 01EB0000h - 01FB0000h
foo_ui_std                      loaded at 01FD0000h - 02083000h
MSIMG32                          loaded at 76320000h - 76325000h
foo_unpack                      loaded at 020B0000h - 020DD000h
atioglxx                        loaded at 69000000h - 6953D000h
atioglx2                        loaded at 02320000h - 02D89000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
imagehlp                        loaded at 76C50000h - 76C78000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
VERSION                          loaded at 77BD0000h - 77BD8000h
Stack dump analysis:
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 00B876CDh, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B87C3Bh, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B94BF8h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B76265h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B779C2h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B94EF8h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B7671Eh, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 004EAC08h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F50h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00464954h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00B95090h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B75C11h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00BA1268h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 004EAF18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EA870h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00B952BBh, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B75CA4h, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 00B7372Fh, location: "foo_bubble_coverflow", loaded at 00B70000h - 00BB3000h
Address: 01EECC7Bh, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F74660h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E36B400h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000C4h)
Address: 01EED690h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F74668h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E36B4CBh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36CF9Eh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+0000003Bh)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E36B51Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 01F72354h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01EEC11Bh, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F659A1h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01EEC121h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E368B26h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 01F2DBA0h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 01F66832h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F2DD35h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E36D05Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+000000F8h)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36F9FEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+000001A3h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 01EB0000h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F74BF8h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36FE13h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 7E36FDD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 7E36FDFEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 7C925A00h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+0000025Dh)
Address: 7C925A65h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+000002C2h)
Address: 7C98C174h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C925041h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000046h)
Address: 7C925233h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000238h)
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 01F74C46h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7C9255C9h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlHashUnicodeString" (+00000164h)
Address: 7C925152h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000157h)
Address: 7C92554Ah, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Address: 7C9253F5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7E369951h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsChild" (+00000243h)
Address: 7C920833h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 01EB0108h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7C920838h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 7E3699E4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsChild" (+000002D6h)
Address: 7E369A12h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsChild" (+00000304h)
Address: 7E36A303h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ClientThreadSetup" (+000002F9h)
Address: 7E369A18h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsChild" (+0000030Ah)
Address: 7E36A31Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ClientThreadSetup" (+00000310h)
Address: 7E36A33Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ClientThreadSetup" (+00000331h)
Address: 004E004Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7E369D60h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "UnregisterClassW" (+000002BCh)
Address: 7E3C0270h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E360000h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7E36B3A7h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 01EE8CA2h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01EE8E6Ah, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E36FECCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000002A7h)
Address: 01F90BD0h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F3B7ABh, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7E36FC58h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 01F2DA21h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F11845h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01EE642Ah, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01F65A79h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 01EE76CAh, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 00430668h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 01F74688h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Address: 7C923E88h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004E9h)
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 01F746D6h, location: "foo_ui_columns", loaded at 01EB0000h - 01FB0000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
Shorten decoder 0.4.2.1  (foo_input_shorten)
Converter 1.0.2  (foo_converter)
Default User Interface 0.9.5  (foo_ui_std)
RAR reader 1.1  (foo_unpack)
ABX Comparator 1.3.1  (foo_abx)
Album List 4.1  (foo_albumlist)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Masstagger 1.6  (foo_masstag)
ZIP/GZIP reader 1.0  (foo_unpack)
freedb Tagger 0.5.2.1  (foo_freedb2)
foobar2000 core 0.9.5  (Core)
CD Audio Decoder 2.1.2  (foo_cdda)
Cover Flow 0.12  (foo_bubble_coverflow)
Columns UI 0.2.1 alpha 10 v3  (foo_ui_columns)
Standard DSP Array 1.0  (foo_dsp_std)
File Operations 2.0  (foo_fileops)
Reply #107
Hey bubbleguuum, I took a look at v 0.12 changes and fixes, and they sound good,
but I havent tested v 0.12 because im at work.
I would like to report a bug which is in 0.11, and not included in 0.12 fix list.
When there is nothing in the playlist and I click on the coverflow panel (im using it in UI Panel),
foobar crashes.
Yeh, and one feature request, can we have an option to what can be displayed in the coverflow window/panel
if there is nothing in the playlist.
Besides, all these little bug, the plugin looks right.
A teacher is a student in denial.
Reply #108
bubbleguuum
I don't solve next thing.
When I include your component in CUI, I  have cover flow in separate window and blank CUI element
I can change preferences of coverflow window  with right click on blank CUI element.
I use FB 0.9.5, colunms_ui  0.2.1 alpha 10 v4, your plugin version 0.12.
With plugin version 0.11 result is the same.
Separate windows from View/Show cove rflow window work good.
Reply #109
Foobar crashes and gives me this error:
I also get this error when trying to load foobar again:
under Vista Home Premium, foobar 0.9.5 beta 2, FofR-Skin (Panels UI).
Reply #110
Hi, top new design.
But after restarting my foobar the preferences of coverflow are reset and no cover are displayed (cover.jpg)
MfG Frank
Reply #111
I got the same error as Keikonium and Grimes.
Reply #112
i've just tested 0.12 and it workd quite fine (using it as window with dui)... only one wierd thing:
shift+mousewheel seems like not changing fov and just move camera forward and backward (now it works exactly the same as ctrl+wheel)... im sure it worked as intended in 0.11 version. does anybody else encounter this behavior?
edit: after few times playin with shift and ctrl i found out that shift doesnt work precisly same as ctrl but it still doesnt work as it used to or imho is supposed to... and after some time ive found out this sweet redraw bug where reflection was above text:
after restart it was gone and every thing was back to normal
(except that "no cover file" isnt saved after restart)
Reply #113
bubbleguuum
Same exact problem as you, only Im using PUI
Reply #115
same here, got the same error.
It used to work with v 0.11
Im using Geforce 6200, with the latest drivers.
Reply #116
foobar crashes.
The bug: thanks, this is fixed.
blank panel : what would you display if the playlist is empty ?
bubbleguuum
Very strange, I'm going to do a debug build of 0.12 to have more meaningful logs for those crashes
[a href="http://img165.imageshack.us/my.php?image=63725946te3.jpg" target="_blank"][/url]
shift+mwheel changes the fov, it has not changed. It may look like moving the camera but it's not: try to move back the camera after you changes the FOV.
Not sure about the text bug, but I made a small change and will see if it fixes it in next version
I tried several times, and the cover file was always remembered....
Thanks to all people testing. As you can see this is still largely beta and even if I do some testing on my config, I can't catch it all. For the people who experience a crash just after replacing the old dll by the new I may have made a mistake in the code handling the new configuration. You should try to remove the plugin (delete the DLL), relaunch foobar, answer yes to delete settings of the plugin, then put back the newer dll and it might work.
Reply #118
I had already removed the component and deleted its settings to get my foobar to work again, but readding it didn't fix it. I will test the new debug build . *testing...*
I've uploaded a debug version of 0.12. If you get nasty crashes install it and report the crah log which should be much more useful. Thanks!
http://bubbleguuum.free.fr/foo_bubble_cove..._0.12_debug.zip
Upon loading foobar, I got a warning about being a debug component, I assume thats normal . When I try to view the component with foobar IN A PANEL, it crashes. No crash log, no nothing. I can't even view the console to see any debug output. It does work fine in windowed mode tho (and it does in the non-debug version too) and here is the console output for that:
Autoplaylists initialized in: 0:00.000062
Startup time : 0:02.424291
Audioscrobbler: Handshake successful.
foo_bubble_coverflow: OpenGL version: 2.1.2
foo_bubble_coverflow: OpenGL extensions: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
foo_bubble_coverflow: WGL_ARB_multisample: yes
foo_bubble_coverflow: Using full scene antialiasing
Skipping file://C:\Documents and Settings\Owner\My Documents\My Music\Less Than Jake\Losers, Kings, And The Things We Don't Understand\Less Than Jake - Econolodged.mp3
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Reply #120
yeah im terribly sry... dont know why but i thought that it worked totaly differently in previous versions so ive tested 0.11 and it realy act same as the new... sry for false alarm
Reply #121
Do you plan to make it possible to search for "*.jpg" files?
Wildcard function?
greetings,.
Reply #122
Tried your debug version of 0.12, but got no crash log, because error (unsupported format...) is occurring during start of foobar.
Hi, thanx for 0.12 but like grimes, now it cras at the launch (before any foobar window display!!) :
, and same after having delete the .dll, reloaded foobar, deleted settings, and re-install the dll
foobar 0.9.4.5, PUI 0.14.9, CG = nvidia 8800GTS
back to 0.11 for waiting a fix (cry)
Reply #123
What happens if you remove the panel and launch the standalone window ?
Reply #124
it works in a window ... what have you change for panels ?
i try this : launch my foobar under PanelsUI with the coverflow panel (in comment in the PUI script), then i've modified script to add the coverflow panel => crash, but this time i have a dump, it seems that it's PanelsUI that crash, but due to 0.12 new coverflow panel ...
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 775DB15Fh
Access violation, operation: write, address: 00000014h
Call path:
entry=>user_interface::shutdown
Code bytes (775DB15Fh):
775DB11Fh:  C0 89 4D F0 0F 84 2C 5B FE FF 8B 4E 04 F6 C1 01
775DB12Fh:  8D 7E 04 0F 85 60 26 FE FF 8B 55 0C 90 8B C1 2B
775DB13Fh:  C2 8B D8 8B C1 F0 0F B1 1F 3B C1 0F 85 39 26 FE
775DB14Fh:  FF 33 C0 89 45 0C 89 45 08 8B 06 83 F8 FF 74 04
775DB15Fh:  83 40 14 01 8B 5D F4 8B 7D F0 90 80 3D 82 03 FE
775DB16Fh:  7F 00 0F 85 1F B6 03 00 8B 45 FC 83 F8 FF 57 6A
775DB17Fh:  00 0F 84 75 B6 03 00 50 E8 08 55 02 00 3D 02 01
775DB18Fh:  00 00 0F 84 75 B6 03 00 85 C0 0F 8C 0B B7 03 00
Stack (00239E10h):
00239DF0h:  00000000 00000000 00000000 00000000
00239E00h:  00000000 00000000 00000000 00000000
00239E10h:  027B4FD0 027B4FD4 02B0CD80 6F6F692E
00239E20h:  02A90148 02000002 00020014 6F6F692E
00239E30h:  0000007D 00239E7C 02AA0348 00000320
00239E40h:  FFFF0000 6F6F692D 00000000 00000000
00239E50h:  00000000 00000000 7FFDF000 00000174
00239E60h:  00239E88 775DB071 00000000 00000000
00239E70h:  02B0CD80 027B4FD0 02B1444C 00000004
00239E80h:  00000000 00000001 00239ECC 0276468D
00239E90h:  027B4FD0 02B16908 02B1444C 027646F9
00239EA0h:  610A1394 02B14420 027709C1 B1C45C78
00239EB0h:  02B16908 00000050 02B0CD80 02B14420
00239EC0h:  00239EF0 0278C29A 00000000 00239F00
00239ED0h:  027746AB B1C45DB4 02B16908 02B1381C
00239EE0h:  02B0CD80 00000000 00239ED4 00239A40
00239EF0h:  00239F2C 0277B070 B39D9B5C 00000000
00239F00h:  00239F38 0276C7EA 02B14420 00000050
00239F10h:  00000020 02770998 B1C45D8C 02B16908
00239F20h:  02B13808 02B0CD80 02B1381C 00239F54
Registers:
EAX: 00000000, EBX: FFFFFFFC, ECX: 00000000, EDX: 00000004
ESI: 027B4FD0, EDI: 027B4FD4, EBP: 00239E60, ESP: 00239E10
Crash location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlPcToFileHeader" (+000002E6h)
Loaded modules:
foobar2000                      loaded at 00960000h - 00A7E000h
ntdll                            loaded at 775A0000h - 776BE000h
kernel32                        loaded at 76050000h - 76128000h
COMCTL32                        loaded at 74C00000h - 74D94000h
msvcrt                          loaded at 76A20000h - 76ACA000h
ADVAPI32                        loaded at 76440000h - 764FF000h
RPCRT4                          loaded at 76340000h - 76403000h
GDI32                            loaded at 76560000h - 765AB000h
USER32                          loaded at 76830000h - 768CE000h
SHLWAPI                          loaded at 75E60000h - 75EB5000h
SHELL32                          loaded at 76AD0000h - 7759E000h
ole32                            loaded at 768D0000h - 76A14000h
COMDLG32                        loaded at 76680000h - 766F4000h
IMM32                            loaded at 776C0000h - 776DE000h
MSCTF                            loaded at 765B0000h - 76677000h
LPK                              loaded at 76550000h - 76559000h
USP10                            loaded at 76130000h - 761AD000h
uxtheme                          loaded at 742D0000h - 7430F000h
tiptsf                          loaded at 72D20000h - 72D80000h
OLEAUT32                        loaded at 761E0000h - 7626C000h
version                          loaded at 75560000h - 75568000h
foo_abx                          loaded at 00350000h - 00383000h
foo_albumlist                    loaded at 01100000h - 01147000h
foo_bubble_coverflow            loaded at 011A0000h - 011E3000h
OPENGL32                        loaded at 74450000h - 7451B000h
GLU32                            loaded at 74730000h - 74753000h
DDRAW                            loaded at 73010000h - 730F6000h
DCIMAN32                        loaded at 73490000h - 73496000h
SETUPAPI                        loaded at 75EC0000h - 76048000h
dwmapi                          loaded at 73000000h - 7300C000h
gdiplus                          loaded at 73B30000h - 73CDA000h
foo_cdda                        loaded at 014C0000h - 014F5000h
foo_comserver2                  loaded at 01570000h - 015C6000h
foo_converter                    loaded at 016A0000h - 01709000h
foo_cwb_hooks                    loaded at 01500000h - 0152E000h
foo_dsp_std                      loaded at 015D0000h - 01611000h
foo_fileops                      loaded at 01630000h - 01677000h
foo_freedb2                      loaded at 01720000h - 01760000h
foo_infobox                      loaded at 01760000h - 0179E000h
foo_input_std                    loaded at 01C40000h - 01D58000h
foo_masstag                      loaded at 017B0000h - 01800000h
foo_navigator                    loaded at 01810000h - 01841000h
foo_playcount_mod                loaded at 01850000h - 01865000h
MSVCR80                          loaded at 6AB40000h - 6ABDB000h
foo_playlist_manager            loaded at 01990000h - 019D4000h
foo_rgscan                      loaded at 01A50000h - 01A98000h
foo_run                          loaded at 01A10000h - 01A3B000h
foo_scrobblecharts              loaded at 01D60000h - 01D93000h
WININET                          loaded at 76270000h - 7633F000h
Normaliz                        loaded at 77730000h - 77733000h
iertutil                        loaded at 776E0000h - 77725000h
foo_sendtodevice                loaded at 01DA0000h - 01DDD000h
foo_uie_albumlist                loaded at 01DE0000h - 01E23000h
foo_uie_explorer                loaded at 01E30000h - 01E6C000h
foo_uie_lyrics                  loaded at 01F90000h - 01FF1000h
WINMM                            loaded at 73D60000h - 73D93000h
OLEACC                          loaded at 73D20000h - 73D58000h
foo_uie_powerpanels              loaded at 01EE0000h - 01F03000h
foo_uie_quicksearch              loaded at 01F30000h - 01F76000h
foo_uie_vis_channel_spectrum    loaded at 02000000h - 02039000h
MSIMG32                          loaded at 74310000h - 74315000h
foo_ui_columns                  loaded at 02520000h - 025BB000h
foo_ui_panels                    loaded at 02700000h - 027C6000h
foo_ui_std                      loaded at 02180000h - 021D6000h
foo_unpack                      loaded at 022F0000h - 0231E000h
foo_utils                        loaded at 02320000h - 02359000h
foo_vis_shpeck                  loaded at 02380000h - 023C0000h
CLBCatQ                          loaded at 77750000h - 777D4000h
WindowsCodecs                    loaded at 73730000h - 737E2000h
DSOUND                          loaded at 6D2F0000h - 6D361000h
POWRPROF                        loaded at 751E0000h - 751FA000h
MMDevApi                        loaded at 74F10000h - 74F37000h
WINTRUST                        loaded at 75000000h - 7502D000h
CRYPT32                          loaded at 757C0000h - 758B1000h
MSASN1                          loaded at 75910000h - 75922000h
USERENV                          loaded at 75D10000h - 75D2E000h
Secur32                          loaded at 75CF0000h - 75D04000h
imagehlp                        loaded at 76410000h - 76439000h
audioses                        loaded at 739F0000h - 73A11000h
audioeng                        loaded at 738C0000h - 73926000h
AVRT                            loaded at 75100000h - 75107000h
PSAPI                            loaded at 75DC0000h - 75DC7000h
nvoglv32                        loaded at 69500000h - 69BD7000h
dbghelp                          loaded at 715A0000h - 7167C000h
Address: 027B4FD4h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0005F99Bh)
Address: 02000002h, location: "foo_uie_vis_channel_spectrum", loaded at 02000000h - 02039000h
Address: 775DB071h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlPcToFileHeader" (+000001F8h)
Address: 0276468Dh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0000F054h)
Address: 027646F9h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0000F0C0h)
Address: 027709C1h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0001B388h)
Address: 0278C29Ah, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00036C61h)
Address: 027746ABh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0001F072h)
Address: 0277B070h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00025A37h)
Address: 0276C7EAh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+000171B1h)
Address: 02770998h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0001B35Fh)
Address: 0278C0FEh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00036AC5h)
Address: 0275C98Ah, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00007351h)
Address: 0278BC57h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0003661Eh)
Address: 02767E2Ch, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+000127F3h)
Address: 0278BF1Fh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+000368E6h)
Address: 0275568Ah, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00000051h)
Address: 02755A82h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00000449h)
Address: 0278B9D0h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00036397h)
Address: 76851A10h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 76853123h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "GetWindow" (+0000010Fh)
Address: 027559FFh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+000003C6h)
Address: 76851A91h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "GetMessageW" (+000000EFh)
Address: 768976CCh, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "AlignRects" (+00001926h)
Address: 76851C03h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "GetMessageW" (+00000261h)
Address: 76834E8Bh, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "PrivateRegisterICSProc" (+000000B4h)
Address: 76848C01h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "UpdateWindow" (+00000061h)
Address: 77600E6Eh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77600E20h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 76851BB8h, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "GetMessageW" (+00000216h)
Address: 76848C3Ah, location: "USER32", loaded at 76830000h - 768CE000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 02710ED4h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 00A435F8h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 02721E32h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 009C8057h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A13910h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 0098C3A7h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0BBA7h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A43560h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0B036h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A14728h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 009FAFC0h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0BB04h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0A741h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 77601039h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlRaiseStatus" (+000000B4h)
Address: 77601074h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlRaiseStatus" (+000000EFh)
Address: 7760100Bh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlRaiseStatus" (+00000086h)
Address: 00A14766h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 775C2C4Bh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlUnwind" (+000000E3h)
Address: 00A43E50h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 776069A4h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlUnicodeToMultiByteN" (+000004FDh)
Address: 00A0A6F2h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 77601843h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 775A8BF2h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 775E23DEh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "wcscmp" (+00001322h)
Address: 776016DCh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlAllocateHeap" (+000000AFh)
Address: 77602EBBh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlInitializeCriticalSectionEx" (+000000E2h)
Address: 776651CCh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlFreeMemoryBlockLookaside" (+0000109Ch)
Address: 77602F2Fh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlInitializeCriticalSection" (+00000012h)
Address: 76094EAAh, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "FindFirstFileW" (+00000080h)
Address: 76094E0Ch, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "FindFirstFileExW" (+0000034Ch)
Address: 76094E21h, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "FindFirstFileExW" (+00000361h)
Address: 00A0B53Ch, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0B578h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0B5C1h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0B5FEh, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0B984h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A43E78h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 00A0BB70h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 7760104Dh, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlRaiseStatus" (+000000C8h)
Address: 00A14B73h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 775C29D7h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlGetAce" (+0000013Eh)
Address: 009F8E01h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 77600E97h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "KiUserExceptionDispatcher" (+0000000Fh)
Address: 7606B09Eh, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "RaiseException" (+00000058h)
Address: 011A13E2h, location: "foo_bubble_coverflow", loaded at 011A0000h - 011E3000h
Address: 775FF400h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "NtCreateEvent" (+0000000Ch)
Address: 76097AE6h, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "CreateEventExW" (+0000005Ch)
Address: 02777940h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00022307h)
Address: 0274791Dh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "foobar2000_get_interface" (+00003BFDh)
Address: 0279B1B8h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00045B7Fh)
Address: 0279B190h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00045B57h)
Address: 011A3819h, location: "foo_bubble_coverflow", loaded at 011A0000h - 011E3000h
Address: 011C4620h, location: "foo_bubble_coverflow", loaded at 011A0000h - 011E3000h
Symbol: "foobar2000_get_interface" (+00018C40h)
Address: 0271FC1Ah, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 0279808Ch, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00042A53h)
Address: 02798098h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00042A5Fh)
Address: 02790018h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0003A9DFh)
Address: 0271FEFBh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 011D11C8h, location: "foo_bubble_coverflow", loaded at 011A0000h - 011E3000h
Symbol: "foobar2000_get_interface" (+000257E8h)
Address: 0271F334h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 100065C3h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "stricmp_utf8_ex" (+00000000h)
Address: 0279803Ch, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+00042A03h)
Address: 0279086Ch, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0003B233h)
Address: 0271E33Ah, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 02706584h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Address: 1000776Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetLongPathName" (+00000046h)
Address: 7760162Dh, location: "ntdll", loaded at 775A0000h - 776BE000h
Address: 776018C3h, location: "ntdll", loaded at 775A0000h - 776BE000h
Symbol: "RtlFreeHeap" (+0000007Ah)
Address: 76097A7Eh, location: "kernel32", loaded at 76050000h - 76128000h
Symbol: "HeapFree" (+00000014h)
Address: 009F8D19h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 009F8D38h, location: "foobar2000", loaded at 00960000h - 00A7E000h
Address: 02790920h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "Scintilla_DirectFunction" (+0003B2E7h)
Address: 027475E2h, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "foobar2000_get_interface" (+000038C2h)
Address: 0274760Fh, location: "foo_ui_panels", loaded at 02700000h - 027C6000h
Symbol: "foobar2000_get_interface" (+000038EFh)
Version info:
foobar2000 v0.9.5
UNICODE
Windows 6.0
Additional info:
Navigator 0.6  (foo_navigator)
Play Count Mod 1.0.2  (foo_playcount_mod)
Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55]  (foo_ui_panels)
COM Automation server 0.7 alpha 6  (foo_comserver2)
Playlist Manager 1.0.2  (foo_playlist_manager)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Shpeck - Winamp vis plugins wrapper 0.1.1  (foo_vis_shpeck)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Playlist tools 0.5.7  (foo_utils)
Volume Panel 0.1  (foo_uie_powerpanels)
WMA Decoder 1.1  (foo_input_std)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Album List 3.2.0  (foo_albumlist)
freedb Tagger 0.5.2a  (foo_freedb2)
FLAC Decoder 1.1.0  (foo_input_std)
Converter 1.0.1  (foo_converter)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Standard DSP array 1.0  (foo_dsp_std)
Special file info box v2.0.0  (foo_infobox)
Channel Spectrum panel 0.13  (foo_uie_vis_channel_spectrum)
cwbowron's title format hooks 1.0.14 [Nov  1 2006 - 10:20:44]  (foo_cwb_hooks)
Default User Interface 0.9acc  (foo_ui_std)
Seek Panel 0.1  (foo_uie_powerpanels)
CD Audio Decoder 2.1.1  (foo_cdda)
Run services 0.3.2  (foo_run)
Lyric Show Panels 0.3.1.1b8 DEV [Sep 16 2007 - 08:44:03]  (foo_uie_lyrics)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Send to Device 1.1.2 [Nov 28 2007 - 10:13:31]  (foo_sendtodevice)
i hope that it will help you
