Topic: LAME -V 0 --vbr-new killer sample (Read 13943 times) previous topic - next topic
I found a problem sample on track last night and i find it transparent on 192 kpbs CBR by using --preset cbr 192 but its not transparent on -V 2, -V 1 and -V 0 --vbr-new on both LAME 3.97 and LAME 3.98b5.
LAME 3.98b5 -V 0
foo_abx 1.3.1 report
foobar2000 v0.9.4.4
2007/10/13 16:11:41
File A: F:\Listen Tests\Die In A Crash (Sample).wav
File B: F:\Listen Tests\Die In A Crash (Sample) LAME3.98b5 V0.mp3
16:11:41 : Test started.
16:12:09 : 01/01  50.0%
16:12:22 : 02/02  25.0%
16:12:30 : 03/03  12.5%
16:12:42 : 04/04  6.3%
16:13:20 : 05/05  3.1%
16:13:50 : 06/06  1.6%
16:14:08 : 07/07  0.8%
16:14:28 : 08/08  0.4%
16:14:42 : 09/09  0.2%
16:14:52 : 10/10  0.1%
16:15:16 : 11/11  0.0%
16:16:13 : 12/12  0.0%
16:16:16 : Test finished.
Total: 12/12 (0.0%)
A nasty precho at around 0:15 - 0:18
All the vbr encoded versions of that track produce a huge bitrate bloat at around 245 on V2 and 263 on V0 thanks to that awfull sfb21 bug while the 192 cbr encode is transparent.
I have uploaded the lossless sample and the LAME 3.98b5 encoded mp3.
Lossless Sample in FLAC:
http://www.sendspace.com/file/19f5s6
Lossy sample in LAME 3.98b5 -V 0:
http://www.sendspace.com/file/iapt6f
can you try also --vbr-old
If it is indeed a problem sample for 3.98b5...looks like there will be a 3.98b6...
Zune 80, Tak -p4 audio library, Lossless=Choice
I tried -V 0 --vbr-old on LAME 3.98b5 and i find it transparent unlike --vbr-new.
you should be hired by Lame devs to spot artifacts!!!
OT: Is there a Wiki Article with all samples? With links to download sources and relevant discussions? If not, would be nice to have a sample resource page...
Yeah that would be a neat job
Anyway I did a quick test with LAME 3.90.3 --alt-preset and its seems transparent to me, but its very easy to abx at LAME 3.97 and 3.98b5 at -V 0 --vbr-new and my hearing is not that great at all.
Wow, my hearing isn't as good as I thought.
I can't hear the flaw.
I'm not quite sure what pre echo is.
Pre-echo is the opposite of a very short normal echo: it happens before the trigger instead of afterwards. For example, a sharp percussion hit, may sound more soft and "smeared". Visually, you could imagine it like an added quick "fade-in" of a sound.
Spotting artifacts has less to do with hearing/equipment and more with training. It is a common myth, that recognizing mp3-artifacts is mainly an issue of hearing and equipment. However, some people are more sensitive to certain artifacts than to others. I for example dont care that much about pre-echo and instead more about other artifacts - mainly those which happen at high frequency ranges (10-14khz).
Woohoo, I could make it on CMI8738 chip and with TV background noise.
foobar2000 v0.9.4.5 beta 1
2007/10/14 00:10:18
File A: D:\Die_In_A_Crash.flac
File B: D:\Die_In_A_Crash_V0.mp3
00:10:18 : Test started.
00:12:28 : 01/01  50.0%
00:13:23 : 02/02  25.0%
00:13:54 : 03/03  12.5%
00:16:25 : 04/04  6.3%
00:17:06 : 04/05  18.8%
00:17:34 : 05/06  10.9%
00:20:10 : 06/07  6.3%
00:22:19 : 07/08  3.5%
00:22:21 : Test finished.
Total: 7/8 (3.5%)
stimulating the audio nerve directly
I have never favored VBR at very high bitrate, but until today I did not think that CBR 192 is better than -V0 towards pre-echo on a sample, especially as 3.98b5 so far seems to have improved on pre-echo behavior.
Good to see that 3.98b5 --vbr-old is fine, as well as that  cbr is fine which I guess is valid for the more interesting abr mode as well.
lame3995o -Q1.7 --lowpass 17
ATM i recken -V 1 would be a good setting then -V0 since -V0 is only abit or not better then the -V1 and a 1mb bigger, most of time sticks upto 260 on most tracks i tried while V2 tracks go to 240 like 260 was max but I did get a track 300kbps    on V0 which is a sbf21 bug though. And i could have picked up artifacts on a 192 encode if I was trained to spot artifacts and I still belive that VBR is still better then 192 CBR and this sample is a bug on --vbr-new and the other tracks i abxed this week.
2007/10/14 00:10:18
Total: 7/8 (3.5%)
Kinda glad to see someone else to abx that with background noise, like when my little brother was pestering me when i was abxing that track
My impression is that CBR / ABR is inferior to VBR with preecho based on past tests.
Hi i am a new here, so i keep me offside. But if someone finds a new sample that lame doesnt convert good without transparancy, do you guys want to know about it. Or do you have enough samples already?
There is no such thing as an ever increasing collection of samples where Lame behaves badly.
The contrary is true: the Lame devs do a hard job improving on the issues found, and they do succeed - though perfection is not possible.
Any new sample that shows weaknesses of a specific encoder is welcome here, so there is a chance the encoder can be improved.
A few years back i did some testing how high my vbr should be before i could not heard the difference. I used the first  10 seconds from dayton - the sound of music. It has a very sparkling and high beginning. I listened with a headphone and i  had to up the bits (VBR HQ) each run, it sounded better each time, but i still could hear the difference between 320 cbr and the original cd. So thats why i remembered it. That was an older encoder dont know how it sounds now.
I tried to find the cd, but could not find it to test. If i find it, i come back on it. It must be somewhere.
If not then i hope someone else has it lying and some spare time  :-)
