Topic: Ogg Vorbis 1.2.0 is out (Read 79007 times) previous topic - next topic
Reply #51
anyway, when will OggDropXPed with Vorbis 1.2 be released?
It's been on Rarewares since 27 July!!
Wow! Didn't Realise that I was ignoring the version number
and does it include multichannel support?
oggdropXPd and oggenc2 have both had correct multi-channel support since March 2006. ie., a correctly formed multi-channel input file will be encoded into the correct channel order according to the vorbis spec, and oggdropXPD and my own oggdec (from Rarewares) will decode generating the correct channel order and wave header on output.
Reply #52
Did we not use the correct channel order patch in our oggdec, as well?  I cannot remember.
Join //spreadopenmedia.com to promote Opus, Vorbis, FLAC, etc
Reply #53
The principle problem is that the output wave file does not contain a WAVEFORMATEXTENSIBLE header so that the channel order can only be assumed rather than known.
Reply #54
then is it possible to transcode AC3 to either another 5.1 or a 2.1 or a 2 channel or a mono?
Reply #56
Is it(Oggenc2.83 using libVorbis v1.2.0) better than aoTuV b5?
A bit different question: does someone be able to merge vorbis 1.2.0 with aoTuV b5 tunings ?
Aoyumi!
I don't have the plan to merge beta5 and libvorbis 1.2.0.
It will happen by the upcoming version of aoTuV.
A new version of aoTuV would be much bigger news to me than a new version of Vorbis
