Topic: Software to verify EAC log CRC's (Read 23021 times) previous topic - next topic
Is there any software capable of checking CRC's of lossless data (mostly FLAC, but would be nice if wv would be supported also) with the checksums contained in EAC log?
I've been wondering about this for a while, too.
A simple command line tool that accepts stdin WAV data would be enough for my needs.
Gl.tter's CheckWavpackFiles app does exactly what it says, though I believe it uses MD5.  Check out this thread.  I don't use flac so I'm not sure if a similar tool exists for it.
AFAIK the CRCs in EAC log files are for the ripped wav (pre-compression), so the lossless file would have to first be decoded before comparing CRCs.
Spoon will soon have a tool to check crc accuraterip values against the file and the accurterip db for files ripped to lossless formats w/ dbpoweramp. I know it doesnt help w/ EAC but I am not aware of a solution there.
So far I found only this tool:
http://www.cdtag.com/
However, there is some bug in this function so it doesnt work.
I tried also doing such a compare manually:
-decoding flac to wav
-calculating CRC value of wav
-comparing it with CRC sorted in log file
and they all the time were different! Why is that? How exactly EAC CRC is calculated?
You definetly should decode to raw pcm or cut wave header. That's how they usually calculate checksums for audio.
Thanks ak, now it worked.
Now I will play a little, maybe it will be possible to make a simple batch file which would decode each flac file to stdout, calculate crc and save to txt file.
Comparing could be done manually, not a big problem. However, parsing log file shouldnt be hard to do as well.
Uh, yeah.  It works with every tool that calculates CRC32... thanks, that's all I need to know.
So for decoding a FLAC to RAW PCM one can simply use this "flac -d --force-raw-format --endian=little --sign=signed <infile.flac> <outfile.raw>" and then a tool like fsum to get the CRC. It should be the same as the one in EAC's logs, unless EAC uses some sort of derivate of CRC32 like eDonkey2000 did with MD4.
Only problem now is to optimise checking the CRCs with as little temp files as possible, ideally none and using pipes instead. And of course accepting all major lossless input formats.
To optimise using -c option in flac would be the best, but it looks like fsum cant calc crc from stdin. Will have to find some other tool.
So it would be like:
flac.exe -d -c --force-raw-format --endian=little --sign=signed <file.flac> | sum.exe > crc.txt
found unix tool cksum, but it outputs crc in decimal format, what a hell :>
Triza already implemented the same CRC calculation of EAC to check files against the log.
You can pipe the wav file into standard input and get the EAC CRC at the standard output. See here.
WavPack 4.3 -mfx5
LAME 3.97 -V5 --vbr-new --athaa-sensitivity 1
The same can be easy done with flac returning raw data to stdio (already accomplished). We just need some crc calculation program returning data in hex and being able to operate on stdin.
Anyway, can someone compile it? I have only borland free command line tools
Oh wait, Triza's post mentions the fact that EAC knows two ways to calculate the CRC, it's either based on audio with silence or without silence.
I think a proper tool for checking the CRCs should take this into account. Luckily he already did most of the work for us. All you have to do is change his code, for instance so that both CRCs are written to stdout or implement a command line switch to choose which CRC to use.
Tried to port it for borland:
#include <stdio.h>
#include <io.h>
#include <assert.h>
#define BUFFERSIZE 65536  /* (64k) buffer size for reading from the file */
static const unsigned long crctable[256] = {
 0x00000000, 0x77073096, 0xee0e612c, 0x990951ba,
 0x076dc419, 0x706af48f, 0xe963a535, 0x9e6495a3,
 0x0edb8832, 0x79dcb8a4, 0xe0d5e91e, 0x97d2d988,
 0x09b64c2b, 0x7eb17cbd, 0xe7b82d07, 0x90bf1d91,
 0x1db71064, 0x6ab020f2, 0xf3b97148, 0x84be41de,
 0x1adad47d, 0x6ddde4eb, 0xf4d4b551, 0x83d385c7,
 0x136c9856, 0x646ba8c0, 0xfd62f97a, 0x8a65c9ec,
 0x14015c4f, 0x63066cd9, 0xfa0f3d63, 0x8d080df5,
 0x3b6e20c8, 0x4c69105e, 0xd56041e4, 0xa2677172,
 0x3c03e4d1, 0x4b04d447, 0xd20d85fd, 0xa50ab56b,
 0x35b5a8fa, 0x42b2986c, 0xdbbbc9d6, 0xacbcf940,
 0x32d86ce3, 0x45df5c75, 0xdcd60dcf, 0xabd13d59,
 0x26d930ac, 0x51de003a, 0xc8d75180, 0xbfd06116,
 0x21b4f4b5, 0x56b3c423, 0xcfba9599, 0xb8bda50f,
 0x2802b89e, 0x5f058808, 0xc60cd9b2, 0xb10be924,
 0x2f6f7c87, 0x58684c11, 0xc1611dab, 0xb6662d3d,
 0x76dc4190, 0x01db7106, 0x98d220bc, 0xefd5102a,
 0x71b18589, 0x06b6b51f, 0x9fbfe4a5, 0xe8b8d433,
 0x7807c9a2, 0x0f00f934, 0x9609a88e, 0xe10e9818,
 0x7f6a0dbb, 0x086d3d2d, 0x91646c97, 0xe6635c01,
 0x6b6b51f4, 0x1c6c6162, 0x856530d8, 0xf262004e,
 0x6c0695ed, 0x1b01a57b, 0x8208f4c1, 0xf50fc457,
 0x65b0d9c6, 0x12b7e950, 0x8bbeb8ea, 0xfcb9887c,
 0x62dd1ddf, 0x15da2d49, 0x8cd37cf3, 0xfbd44c65,
 0x4db26158, 0x3ab551ce, 0xa3bc0074, 0xd4bb30e2,
 0x4adfa541, 0x3dd895d7, 0xa4d1c46d, 0xd3d6f4fb,
 0x4369e96a, 0x346ed9fc, 0xad678846, 0xda60b8d0,
 0x44042d73, 0x33031de5, 0xaa0a4c5f, 0xdd0d7cc9,
 0x5005713c, 0x270241aa, 0xbe0b1010, 0xc90c2086,
 0x5768b525, 0x206f85b3, 0xb966d409, 0xce61e49f,
 0x5edef90e, 0x29d9c998, 0xb0d09822, 0xc7d7a8b4,
 0x59b33d17, 0x2eb40d81, 0xb7bd5c3b, 0xc0ba6cad,
 0xedb88320, 0x9abfb3b6, 0x03b6e20c, 0x74b1d29a,
 0xead54739, 0x9dd277af, 0x04db2615, 0x73dc1683,
 0xe3630b12, 0x94643b84, 0x0d6d6a3e, 0x7a6a5aa8,
 0xe40ecf0b, 0x9309ff9d, 0x0a00ae27, 0x7d079eb1,
 0xf00f9344, 0x8708a3d2, 0x1e01f268, 0x6906c2fe,
 0xf762575d, 0x806567cb, 0x196c3671, 0x6e6b06e7,
 0xfed41b76, 0x89d32be0, 0x10da7a5a, 0x67dd4acc,
 0xf9b9df6f, 0x8ebeeff9, 0x17b7be43, 0x60b08ed5,
 0xd6d6a3e8, 0xa1d1937e, 0x38d8c2c4, 0x4fdff252,
 0xd1bb67f1, 0xa6bc5767, 0x3fb506dd, 0x48b2364b,
 0xd80d2bda, 0xaf0a1b4c, 0x36034af6, 0x41047a60,
 0xdf60efc3, 0xa867df55, 0x316e8eef, 0x4669be79,
 0xcb61b38c, 0xbc66831a, 0x256fd2a0, 0x5268e236,
 0xcc0c7795, 0xbb0b4703, 0x220216b9, 0x5505262f,
 0xc5ba3bbe, 0xb2bd0b28, 0x2bb45a92, 0x5cb36a04,
 0xc2d7ffa7, 0xb5d0cf31, 0x2cd99e8b, 0x5bdeae1d,
 0x9b64c2b0, 0xec63f226, 0x756aa39c, 0x026d930a,
 0x9c0906a9, 0xeb0e363f, 0x72076785, 0x05005713,
 0x95bf4a82, 0xe2b87a14, 0x7bb12bae, 0x0cb61b38,
 0x92d28e9b, 0xe5d5be0d, 0x7cdcefb7, 0x0bdbdf21,
 0x86d3d2d4, 0xf1d4e242, 0x68ddb3f8, 0x1fda836e,
 0x81be16cd, 0xf6b9265b, 0x6fb077e1, 0x18b74777,
 0x88085ae6, 0xff0f6a70, 0x66063bca, 0x11010b5c,
 0x8f659eff, 0xf862ae69, 0x616bffd3, 0x166ccf45,
 0xa00ae278, 0xd70dd2ee, 0x4e048354, 0x3903b3c2,
 0xa7672661, 0xd06016f7, 0x4969474d, 0x3e6e77db,
 0xaed16a4a, 0xd9d65adc, 0x40df0b66, 0x37d83bf0,
 0xa9bcae53, 0xdebb9ec5, 0x47b2cf7f, 0x30b5ffe9,
 0xbdbdf21c, 0xcabac28a, 0x53b39330, 0x24b4a3a6,
 0xbad03605, 0xcdd70693, 0x54de5729, 0x23d967bf,
 0xb3667a2e, 0xc4614ab8, 0x5d681b02, 0x2a6f2b94,
 0xb40bbe37, 0xc30c8ea1, 0x5a05df1b, 0x2d02ef8d,
void crc32(register int fd, unsigned long *main_val)
 char   buf[BUFFERSIZE], *p;
 int   len = 0, nr;
 unsigned long crc = ~0, crc32_total = ~0;
 while ((nr = read(fd, buf, sizeof(buf))) > 0){
  assert(nr % 2 == 0);
  for (len += nr, p = buf; nr--; ++p) {
// Skip silence when calculate CRC. If EAC is set so that it
// does not skip silence when CRC is calculated, remove this if
// statement, or change its condition to non-zero, so it is always
// true.
if(*((__int16*)p) != 0){
  crc = (crc >> 8) ^ crctable[(crc ^ *p) & 0xff];
  crc32_total = (crc >> 8) ^ crctable[(crc32_total ^ *p) & 0xff];
  nr--;
  ++p;
else{
  nr--;
  ++p;
 assert(nr >= 0);
 *main_val = ~crc;
int main()
  unsigned long Crc;
  // Skip the WAV header.
  const int Ret = lseek(fileno(stdin), 44, SEEK_SET);
  assert(Ret >= 0);
  crc32(fileno(stdin), &Crc);
  printf("%0X\n", Crc);
Compiles, but gives wrong crc when used like that:
flac.exe -d -c --totally-silent 1.flac | crc.exe
Thats probably because I suck at c programming  Just googled the errors and changed a little bit code. I have no idea how to do it in Cygwin, and now I dont really want to mess with it
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]moderation: CODE => CODEBOX[/size]
     // true.
As I said in my previous post, EAC knows two ways of calculating the CRC and unfortunately it's not mentioned in the EAC log which one was used, so you have to try both ways when you're not sure. That's what I was talking about in my previous post... so try this:
     nr--;
     ++p;
Yeah, I am aware of that, been doing this by changing 0 to other digit in if statement. Same result as your code (tested to be 100% sure).
This program gives 4969EC84 or 23DCDBC3 (depends on that silence), while it should return 8875EB97 (value in log as well as when calculating crc of: flac.exe -d -c -f --totally-silent --force-raw-format --endian=little --sign=signed 1.flac >out.raw )
I always thought an Accuraterip lookup plugin for Foobar2000, similar to its freedb plugin, would be an absolute godsend.
If someone tells me how to attach something I have a EAC log checker (including bad read mode) not made by me but a friend in xls
its an excel spreadsheet that I soon hope one day will be coded into C# and released as a standalone program that can evetually check the logs, verify CRC's, make sure its not a transcode etc etc.
Would be nice to see it
You can upload it here.
Finally found proper tool
http://www.mirkes.de/en/freeware/batch.php
flac.exe -d -c -f --totally-silent --force-raw-format --endian=little --sign=signed 1.flac | crc1632 /m32
Doing batch tomorrow
I tried about two years ago to compile it with MinGW but the binary provide a different CRC.
Cygwin compiled binaries (cygwin1.dll needed) work perfect here.
WavPack 4.3 -mfx5
How do you compile it?
"gcc -o crc.exe crc.c"  with cygwin1.dll gives error when using pipe
error:
assertion "Ret >= 0" failed: file "crc.c", line 120
   4530 [sig] a 3868 open_stackdumpfile: Dumping stack trace to a.exe.stackdump
  27749 [sig] a 3868 E:\TEST\a.exe: *** fatal error - called with threadlist_ix -1
and returns bad checksum when used like that:
crc.exe<1.wav
When changed source for win and compiled with "gcc -mno-cygwin crc3.c" I get the same results as with borland which is wrong :/
Here is temporary solution (works for most logs):
@echo off
rem crc1632 - [url=http://www.mirkes.de/en/freeware/batch.php]http://www.mirkes.de/en/freeware/batch.php[/url]
set flac="E:\TEST\flac.exe"
set crc1632="E:\TEST\crc1632.exe"
rem takes first parameter as path to log and flac files
cd "%1"
%~d1
for %%f in (*.flac) do (
echo %%f
%flac% -d -c -f --totally-silent --force-raw-format --endian=little --sign=signed "%%f" | %crc1632% /m32
IF errorlevel=1 GOTO fail
for %%f in (*.log) do (
rem opens .log in notepad, to open in default app for .log files chage next line to: "%%f"
notepad.exe "%%f"
GOTO end
:fail
echo.
echo Sth is wrong.
echo.
pause
:end
rem uncomment next line to prevent cmd window from closing
rem pause
Save as .bat and use in foo_run, total commander, windows explorer or any other tool
Could be 100% effective if I would know some way to compile Triza code. Maybe I will make own tool for this in c, for now this must be enough
Edit: small fix - added %~d1 to change drive.
