Topic: aacPlus vs nero AAC (Read 16993 times) previous topic - next topic
aacPlus vs nero AAC
Coding Technology aacPlus Encoder 8.0.0 or latest nero AAC codec, which is better??
Any good cd ripper with nero aac codec??
What settings are god for aacplus? What is the diference between aacplus and aacplus v2
Thanks, and sorry for my english
aacPlus vs nero AAC
Please use search function.
Not really a Signature.
aacPlus vs nero AAC
It depends on what circumstances you plan on using it for. I would go with the latest Nero AAC encoder.
budding I.T professional
aacPlus vs nero AAC
I want encode my cds to aac for my ipod at 160 or 128, What software do you use for encode cds and files with nero aac encoder??
I used easy cdda extractor with nero codec but the new versions of this soft haven't support for nero codec only for AACplus
aacPlus vs nero AAC
If your encoding to your Ipod go with the Itunes AAC encoder then.  What you decide to rip with greatly depends on what OS you are on.
http://wiki.hydrogenaudio.org/index.php?title=AAC_encoders
aacPlus vs nero AAC
My OS is windows
Why is better for ipod use apple codec than nero codec?
Do you know any software for encode with nero aac codec?
aacPlus vs nero AAC
If you are using iPod, then most probably you already must use iTunes to transfer songs. AAC encoder in iTunes is of good quality, so using it would be most convenient for you.
And BTW - iPods don't support aacPlus, so using this format would give you bad results.
aacPlus vs nero AAC
But i like more nero codec, Do you know any software that uses nero codec??
aacPlus vs nero AAC
Any software which accepts commandline encoders, for example Exact Audio Copy or Foobar2000. And Nero commandline AAC encoder can be dowloaded for free, you don't need to be full Nero Burning software owner (just if you don't know).
aacPlus vs nero AAC
Ok thaks i finally use eac with Ultimate EAC Pack r12
One more question, it is the same:
  aacenc32.dll  4.5.9.0
  neroAacDec.exe  1.0.0.2 (Nero Digital Audio Decoder)
Both encoders produces the same quality what is the diference, what is the best? , more new??
aacPlus vs nero AAC
latest  version of the nero encoder and decoder can be found @
http://www.nero.com/nerodigital/eng/down-ndaudio.php
aacPlus vs nero AAC
Be aware that there are issues with gapless playback on iPods when you use the Nero encoder.
audiomars
Reason is immortal, all else mortal
- Pythagoras
aacPlus vs nero AAC
>> aacenc32.dll 4.5.9.0  included in Nero 7 Premium
>> neroAacEnc.exe 1.0.0.2 (Nero Digital Audio encoder)
what is the diference?
What is the best?
aacenc32.dll is in the nero software it is more updated than neroAacEnc??
aacPlus vs nero AAC
Just use the latest neroAacEnc.exe - that's all.
aacPlus vs nero AAC
both of them should be the same, so it shouldn't be a surprise that they give the same or similar results.
aacPlus vs nero AAC
Where did you get the Coding Technology encoder?
aacPlus vs nero AAC
Isn't it part of Winamp?
aacPlus vs nero AAC
I think it is part of Winamp.
