Topic: aacPlus vs nero AAC (Read 13971 times) previous topic - next topic
  • lordraiden
aacPlus vs nero AAC
Coding Technology aacPlus Encoder 8.0.0 or latest nero AAC codec, which is better??
Any good cd ripper with nero aac codec??
What settings are god for aacplus? What is the diference between aacplus and aacplus v2
Thanks, and sorry for my english
  • Last Edit: 29 November, 2006, 02:37:27 PM by lordraiden
  • vitos
aacPlus vs nero AAC
Please use search function.
Not really a Signature.
  • lordraiden
aacPlus vs nero AAC
My english is very poor is very dificult for my search in the forum I try and finally i didn't find nothing
  • HotshotGG
aacPlus vs nero AAC
It depends on what circumstances you plan on using it for. I would go with the latest Nero AAC encoder.
budding I.T professional
  • lordraiden
aacPlus vs nero AAC
I want encode my cds to aac for my ipod at 160 or 128, What software do you use for encode cds and files with nero aac encoder??
I used easy cdda extractor with nero codec but the new versions of this soft haven't support for nero codec only for AACplus
  • HotshotGG
aacPlus vs nero AAC
If your encoding to your Ipod go with the Itunes AAC encoder then.  What you decide to rip with greatly depends on what OS you are on.
http://wiki.hydrogenaudio.org/index.php?title=AAC_encoders
  • Last Edit: 29 November, 2006, 04:42:24 PM by HotshotGG
  • lordraiden
aacPlus vs nero AAC
My OS is windows
Why is better for ipod use apple codec than nero codec?
Do you know any software for encode with nero aac codec?
  • Last Edit: 29 November, 2006, 05:06:56 PM by lordraiden
  • vitos
aacPlus vs nero AAC
If you are using iPod, then most probably you already must use iTunes to transfer songs. AAC encoder in iTunes is of good quality, so using it would be most convenient for you.
And BTW - iPods don't support aacPlus, so using this format would give you bad results.
  • lordraiden
aacPlus vs nero AAC
But i like more nero codec, Do you know any software that uses nero codec??
  • vitos
aacPlus vs nero AAC
Any software which accepts commandline encoders, for example Exact Audio Copy or Foobar2000. And Nero commandline AAC encoder can be dowloaded for free, you don't need to be full Nero Burning software owner (just if you don't know).
  • lordraiden
aacPlus vs nero AAC
Ok thaks i finally use eac with Ultimate EAC Pack r12
One more question, it is the same:
  aacenc32.dll  4.5.9.0
  neroAacDec.exe  1.0.0.2 (Nero Digital Audio Decoder)
Both encoders produces the same quality what is the diference, what is the best? , more new??
  • smok3
  • Moderator
aacPlus vs nero AAC
latest  version of the nero encoder and decoder can be found @
http://www.nero.com/nerodigital/eng/down-ndaudio.php
  • audiomars
aacPlus vs nero AAC
Be aware that there are issues with gapless playback on iPods when you use the Nero encoder.
audiomars
Reason is immortal, all else mortal
- Pythagoras
  • lordraiden
aacPlus vs nero AAC
>> aacenc32.dll 4.5.9.0  included in Nero 7 Premium
>> neroAacEnc.exe 1.0.0.2 (Nero Digital Audio encoder)
what is the diference?
What is the best?
aacenc32.dll is in the nero software it is more updated than neroAacEnc??
  • vitos
aacPlus vs nero AAC
Just use the latest neroAacEnc.exe - that's all.
  • Mangix
aacPlus vs nero AAC
both of them should be the same, so it shouldn't be a surprise that they give the same or similar results.
  • rootkit
aacPlus vs nero AAC
Where did you get the Coding Technology encoder?
aacPlus vs nero AAC
Isn't it part of Winamp?
  • Last Edit: 03 November, 2007, 03:10:14 PM by LaserSokrates
aacPlus vs nero AAC
I think it is part of Winamp.
  • lordraiden
aacPlus vs nero AAC
Also easy cdda extractor has AAC plus
http://www.codingtechnologies.com/products/aacPlus.htm
