Topic: EAC and track number with leading zero in ID3 (Read 2669 times) previous topic - next topic
I have got one question about EAC.
When making MP3 with EAC + lame in ID3 v2 is track number without leading zero for example 1 and not 01.
Files are named correctly.
Does anybody knows what do I wrong?
It's because the track# is stored as a numeric value, as opposed to a string in an APE tag. In a number there is obviously no difference between 1 and 01, but in a string there is. Switch to APE tags if you can.
seany
Well I understand what you mean, but when I use CDEX I have a choice which track number format should be written into ID3tag. Somtehing like this:
0x
0x/0x
etc.
In Tag&Rename there is also a function to rename x to 0x format.
BTW: what are APE Tags?
APE-tags are the tagging system of MPC/MusePack but it can be used for mp3 too...it can cause gaps if the player doesn't support it though (so will id3)...foobar is the only player ATM that I know of that support ape-tags with mp3.
Possibly of interest:
http://www.hydrogenaudio.org/forums/index....5&t=4907&hl=ape
http://www.hydrogenaudio.org/forums/index....1&t=4215&hl=ape
