It changes the settings of the Filename in the EAC Options and gets rid of all references to '\' and replaces them with '-'. This stops me creating the sub-directories under the headings 'CD Artist\CD Title' etc. For example in EAC I use "%D\%C\%N - %T - %A" and "Various Artists\%C\%N - %T - %A". It changes them to "%D - %C - %N - %T" and "%D - %C - %N - %T (%A)" and then saves the files in the main folder as specified in the 'Directories' option without letting me create the sub-directories. Can I get round this way of naming the converted music files so that it is the same as EAC used to be? REACT does this so that it can use the filename to detirmine whether the album is Various Artist or not. When using REACT, these values are irrelevant to how the tracks will finally be named. To specify the file naming scheme for your images and/or tracks you need to look at the REACT.ini file, and amend the values in the "UserOutputNames" section. As an example, using your preferred scheme, you may use the following:[UserOutputNames] OutRoot=C:\Path\To\My\Music ... TrackDir_MP3=@OutRoot@\$cdartist$\$album$ ... TrackName_SA=$tracknumber$ - $title$ - $artist$ TrackName_VA=$tracknumber$ - $title$ - $artist$ TrackName_SA_acdir=$n - $~t - $~a TrackName_VA_acdir=$n - $~t - $~a This:Sets a base folder (OutRoot) of "C:\Path\To\My\Music". Specifies that MP3s should be stored in OutRoot filed under CD Artist and then Album - for VA albums, CD Artist will be set to the value of the "VA" value in the "Settings" section of the INI (at the top), which defaults to "Various Artists" - so you can just leave it alone. Sets the track naming scheme as $tracknumber$ - $title$ - $artist$ for standard albums. Sets the track naming scheme as $tracknumber$ - $title$ - $artist$ for VA albums. Have a look at the default values to try to get an understanding of what is being done. Note that the "TrackName_*A_acdir" variables are for use with ACDIR in the REACT-image.cfg, and match the "TrackName_*A" variables in format , but use ACDIR's own syntax .Also I've had a play with the Cover Art Downloader but it also puts the .jpg in the main folder (with the correct Album title though). Can I change the settings to put the jpg into the associated album sub-directories. I've tried adding all different combinations of '%' '$' and '&' followed by 'Artist' and 'Album' in the 'save as' box but to no avail. Can anyone help me on this I'm not overly familiar with this, as I don't use it; however, if it's no working as it should, it may be that you need to edit your CFG to deal with the file as you wish. You shouldn't really need touch the GUI's Save As dialogue text - let REACT deal with it. Edit: Just spotted, and deleted, your thread on this issue. Easiest to keep discusion here, and no cross-posting please.
