Topic: Setting up foobar with Flake (Read 8362 times) previous topic - next topic
I keep getting this error message when using -8 settings with the p3 of the newest r110.  Im using an athlon xp btw
Error flushing file (Object not found) : file://C:\Documents and Settings\Owner.YOUR-TOSC5ZH62C\Desktop\Alicia Keys - The Diary Of Alicia Keys If I Ain't Got You.flac
any help?
Removed, irrelevant.
Veni Vidi Vorbis.
Does it work with this:
-8 - -o %d
I use this commandline and never encounter any problem with it (but I maybe never used it with latest flake version). Could you try?
As guruboolez points out, later versions of Flake introduce the -o switch...
usage: flake [options] <input.wav> [-o output.flac]
I'm on a horse.
thanks you guys so much it works now
D'oh. Thanks for making me feel stupid everyone.
Edit: And thanks whoever deleted my reply in the flake thread.
Veni Vidi Vorbis.
