Topic: foo_uie_single_column_playlist (Read 743631 times) previous topic - next topic
Reply #475
bozo950:
Reply #476
thx
Reply #477
My singleplaylist.
Thanks to all guys to inspire me for this config.
Font: Link providing illegal download of "Arial Unicode MS" font removed by moderation (necessary for playing songs blinking arrow)
Row Height: 30
Group Row:3
Group by:
%album%
Item Display:
$if($strcmp($mod(%_playlist_number%,2),1),
$drawrect(,,,,brushcolor-50-50-50 pencolor-null))
$padding(3,1)
$font(calibri,9,bold,210-210-210)
$if(%_isplaying%,
$select($add(1,$mod(%_time_elapsed_seconds%,2)),$rgb(255,255,255),$rgb(72,72,255)))%title%
$font(Arial Unicode MS,9,,210-210-210)
$if(%_isplaying%,
$select($add(1,$mod(%_time_elapsed_seconds%,2)),$rgb(255,255,255)'➨',$rgb(72,72,255)'➨'))
$alignabs(3,15,%_width%,%_height%,,)
$font(calibri,8,cleartype,210-210-210)
[%length% | ]
[%bitrate% kbps]
$alignabs(-3,3,$sub(%_width%,2),%_height%,right,)
$font(Wingdings,9,glow-72-72-255 glowexpand-1,250-250-250)
$repeat(«,%rating%)
$alignabs(-3,15,$sub(%_width%,2),%_height%,right,)
[%play_counter%x]
$if(%cwb_queueindex%, '['%cwb_queueindexes%/%cwb_queuelength%']')
Group Display:
$drawrect(0,0,0,0,brushcolor-160-160-160 pencolor-null)
$imageabs2(86,86,,,,,2,2,'default.jpg',)
$imageabs2(86,86,,,,,2,2,$replace(%path%,%filename_ext%,)folder.jpg,)
$font(Tahoma,12,glow-72-72-255 glowexpand-0,255-255-255)
$alignabs(100,2,$add(%_width%,-107),20,left,top)
$if2(%album artist%,%artist)
$alignabs(100,22,$add(%_width%,-107),20,left,top)
$upper(%album%)
$alignabs(100,44,$add(%_width%,-107),20,left,top)
$font(,10,glow-72-72-255 glowexpand-0,)'('%date%')'
Looks like so:
((((( Strictly4me )))))
Reply #478
I managed to substitute Arial Unicode MS with Deja Vu Sans for some things, it might be good for this purpose too. And it's free.
Life is Real...
(But not in audio :) )
Reply #480
Is this a bug? :
When I'm scrolling upwards through my playlist with the keyboard cursors and there is a group header I have to go through the whole group header, i.e. through all the specified group rows.
When I'm doing the same downwards everything works fine.
Reply #481
I've noticed that myself. Not sure if this is intended or a bug.
Reply #482
Is it possible to add %_grouplength% or something like that ? It may allow to  show the length of an album in the Group Display.
I believe if your files are marked right then %totaltracks%  is your friend. But you need all your albums marked that way.
Hope that helps,
Cheers.
Reply #483
If you want the number of items in a group to be displayed in the header you can use %_itemcount%. However I thought moe was trying to put the total time of the items in the header, which I do not think is currently possible
EDIT: Unless you want to go and tag all your files with something like %albumlength% or some other custom tag. The header inherits the tags of the first item in the group so if you tag track 1 of an album with a custom tag containing the album's total length, you should be able to display it in the header.  This is not a very good solution imo.
Reply #484
Well, %totaltracks% is not necessary because %_itemcount% return the number of items which are grouped by %album%. %_grouplength% should return the length of the group of items as a length in seconds or minutes and seconds (ex : 46:53).
Yep, so I request %_grouplength% or something like that.
Reply #485
I have another request to make:
Setting the line height dynamicaly, per example...
$if(%isplaying%,$lineheight(30),$lineheight(15))
There's a storm on the loose, there's sirens in my head...
Reply #486
Houston, we got a problem..
Some images wont show using imageabs2() combined with $replace(%path%,%filename_ext%,)folder.jpg as a relative path to each cover.
Ive done some testing and found that if the '#' char is in the folderpath to the actual image it wont display at all. But if change # to something else it works..
wtf??
Reply #487
Even the latest versions still crash when double-clicking on anywhere that isnt an item\header. It really shouldn't take foobar down.
For example, make a new playlist and put one song into it. click anywhere in the playlist outside of that song's item rectangle.
Reply #488
Yep, I can confirm it on my end too.  Also, when I do this, ZoneAlarm says that foobar2000.exe is trying to access dwwin.exe (error reporting), but does not produce a failure.txt file in the fb2k directory.
Reply #489
can foo_uie_single_column_playlist use album art from matroska file (like in the foo_uie_albumart_mka -> matroska:front.jpg) ?
Reply #490
i don't think it reads images from tags.. might be wrong.
Reply #491
Does anyone know what I should add to this code in order to have Foobar ignore a song's tags.  I want Foobar to ignore all tags on my "Single Tracks -s-" folder.  Here's the code im using now along with foo_cwb_hooks:
$if($strchr(%playlist_name%,-s-),!noheader!,
$if(%tracknumber%,%album%%discnumber%,!noheader!)
So far this code has been great with removing headers from my Single Tracks -s- folder, but I really want it to ignore the songs' tags too.  Thanks for the help!
Reply #493
Sorry if I'm confusing.  If the song is labeled as a single, I don't want the song's tag displayed, I just want the filename shown.  Does that make any sense?
Reply #494
That would be done from your item display box. Something like:
$if(%tracknumber%,
%tracknumber%. [%artist% - ]%title%
%filename_ext%
But it all really depends on (1) How do you "label a song as a single" and (2) What other code do you use in the item display box.
Reply #495
Well I'm using foo_cwb_hooks and the folder which all my single tracks are located in is called "Single Tracks -s-".  Using that along with the code from my earlier post, the headers are removed from songs in the "Single Tracks -s-" folder.
This is the code being used in my Item Display Box:
$drawrect(,,,,brushcolor-231-235-239 pencolor-null))
$if(%_selected%,$drawrect(0,0,0,0,brushcolor-null pencolor-SYSCOL-6))
$padding(6,0)
$font(calibri bold,9,,120-120-120)[$num(%tracknumber%,2)'. ']
$font(calibri bold,9,$if(%isplaying%,underline,),120-120-120)
$replace(%title%,'(',$font(,,bold italic,204-204-204)'(')
$alignabs(6,13,%_width%,%_height%,,)
$font(CubicFive10,6,nocleartype,170-170-170)
[%length% | ]
[%bitrate% kbps]
$align(right,bottom)['('%comment%')']
Reply #496
i got a question about code:
for exemple the code %path%\cover.jpg give me:
E:\Mes Documents\Ma musique\Blues Brothers\19 - Think.mp3\cover.jpg
how can i remove the 19 - Think.mp3
what's the code i should use to get this:
E:\Mes Documents\Ma musique\Blues Brothers\cover.jpg
If you have all your music in "Ma musique" folder the try this code:
E:\Mes documents\Ma musique\%artist%\cover.jpg
Reply #497
bagj629:
You need to add an $if() statement to switch between different text display layouts based on wether or not the track is a single. Something like this:
$padding(6,0)
$if(%tracknumber%,
[%length% | ]
[%bitrate% kbps]
%filename_ext%
In this example I used %tracknumber% to determine if the track is the single, if you something else like $strstr(%directoryname%,-s-) then you'll need to change line 5
Reply #498
Is there anyway to display in the header "various artist" when having multiple artists all under the same abum, like in a soundtrack for example?  For me it shows as the name of the album but dispays the first artist name only.
Reply #499
Well, you could make it easy on yourself and just mark those albums with a tag and then check for that tag in the "Group by" section.
