Topic: foo_title, new version for 0.9 (Read 284527 times) previous topic - next topic
Reply #275
The documentation on making skins is at the home page http://foo-title.sourceforge.net/. There's also something on http://wiki.hydrogenaudio.org/index.php?ti...managedWrapper) but that is not complete.
Basically a skin is just a bunch of images and maybe some buttons and song titles. The description of a skin is written in XML, if you have no experience with it, just google any XML tutorial (you need only the absolute basics). It can be helpful to open someone else's skin to see how it is done and just copy-paste as needed
now i made 3 skins XD
they are in the skin thread
Reply #276
Did someone noticed a memory leakage when foo_title is active?
it's a great plugin, very flexible, i like it.  but this memory leak is really annoying
Reply #277
How much does it leak (MB per hour, approximately)?
Reply #278
something about 50-100KBps. depends on the skin used.
actually at some moments it seems that garbage collector frees unused memory and the amount of ram used by foobar decreases, but then keeps growing again.  Maybe u should explicitly dispose some unused objects before reusing them, instead of letting GC take care of it?
Reply #279
my images of song file are under the name of "jacket" folder...so
i hope can show the album art by like ".\jacket\"
dont care extensions and file name...
my english is poor, cant describe it clearly...sorry
Reply #280
Hi
Really enjoy this plugin. Wen't ahead and changed from winamp 2.x a month ago, and am now up and running with foobar2000 in a portable environment. Since installing foo_title, I sometimes run into problems.
It seems that foo_title stores/remembers absolute paths to skin files - so the following happens:
At my home computer my usb drive mounts as Z: - and everything runs fine.
At another computer the usb drive mounts as fx. Y: - and when I start foobar2000, foo_title gives an error, saying that expected skin files at "z:\...." are not present. As soon as I go into foobar2000 settings - select foo_title and apply the skin, it works fine.
(when I mount at home with Z: - the whole thing happens again of course (now the error just states that "Y:.." files are missing))
I know this is a very specific user case, but hope it's possible to correct.
TIA
Reply #281
OK, the next release (presumably during this summer) should handle it better (provided that the skin is loaded from foobar application directory).
As for the memory usage, if the GC clears it, then it does not leak  But 100 KB per second is quite a lot, that should not be happening..
Album art: I plan to use foobar2000's internal album art providing code, but I have to admit that I don't yet know what can it do
Reply #282
Hi.
I have download some skins to made one myself. But I dont know or see in those how to created a slider volume control, I have seen buttons but no slider control. Any idea how to do that?
Reply #283
It's not currently possible
Reply #284
Thanks Q - I really appreciate it.
Reply #285
I'm using fo_title for some time now.
I must say, it is a simple and great idea. I have one suggestion, tho.
Sometimes when I'm trying to change song, I accidentaly grab whole window and move it a bit.
It is possible to make bar locked (something like right click -> Lock/Unlock) so it won't be accidentaly moved, time by time? ;-s.
Thanks for making it, and cheers. :-)
Reply #286
Bug report:
If "foo_title is enabled when - Never" and "Z-order - Always on top" are selected, the title bar will not show up but the invisible play/stop/next/back buttons still work.  Using Windows 7 RC1 to produce this bug.
Reply #287
New foo_title release is here  But I'm afraid I'm not much motivated to do much more work on foo_title in the future. It works rather nicely now and is neat and simple
Changelog:
0.8
  • two new skins
  • buttons can enable/disable parts of the skin
  • buttons can use context menu commands
  • images are no longer locked - simplifies skin development
  • option to show foo_title when playback is stopped/paused (when not set to show always)
  • fixed show n seconds after song start when changing song
  • re-loading skin just by clicking Apply skin
  • rotated text
  • foo_managedWrapper supports creating mainmenu popups
  • foo_managedWrapper supports enumerating mainmenu commands, mainmenu groups and popups
  • fixed a problem that foo_title would not show when it is set to only show when foobar is minimized
  • on song start showing now takes stream title change into account
  • metadb_handle handling is probably done better this time
  • album art image is resized once and cached, this avoids high CPU usage with large album arts
Download
https://sourceforge.net/projects/foo-title/....8.zip/download
enjoy
Reply #288
I get this error messages;
Reply #289
Fortunately I know some German  The fixed version is now uploaded to sourceforge under the same file name.
Reply #290
Thanks for this update.  I love foo_title, use it every day extensively, love the ability to modify, just a brilliant implementation and idea.
Reply #291
Is possible to seekbar control?
If not - planned for the future?
Reply #292
A little feature request: Make it possible to show the foo_title's window for some time at beginning/ending of a song, even if it is setup to show itself only on mouse hover.
Reply #293
Two more requests:
1) Allow title formatting in image paths. For example if using 'milkplate' the appropriate rating star could light up if the song has already been rated.
2) Implement buttons showing texts instead of images
Reply #294
Sorry for the multiple postings… after a while the possibility to edit postings disappears
Another request: Add an option to fix the position of display (i.e. such that it cannot be moved with the mouse).
And a further note for the author: This addon is already really great! Many many thanks for programming that
Reply #295
I'd like to add a bit too )
complaints:
* seems like not all layers aligns right normally (I mean u can't put layer one by obe with right align, can you?)
* themes can't be changed when *.rar album is playing - smth with paths
wishes:
* cover arts mask like * or *.jpg, *front* would be nice
* seekbar, volume controls?
* playlist window, pls, somehow?
* why nxt layer is under <content> not in it?
* gestures like doubleclick, rightclick, slide left, up... would be nice enhancement
Reply #296
I'm glad you liked it. Unfortunately, as I wrote, I'm not currently planning further development of foo_title. Maybe I'll get back to it in a year or so  The plugin is opensource, but let's not be too naive - out of the thousands of users there is no other developer  (it seems that at least 2 people used the code for their purposes though).
This is one of the most requested features, so maybe I'll get to it at some time
  This is a really specific user case. And it's certainly not the first such request. I really don't know what to do with you guys  I was thinking about including some scripting support and let you do it yourself
Two more requests:
1) I'm not too much of a fan of the title formatting in the skins, so this is probably not what is going to happen. I would prefer the scripting approach or something.
2) Just insert a text layer inside the button layer (outside button's <content>, but inside the <layer>).
complaints:
When aligning a layer to the right, foo_title does not look if there is some other layer already there. So it will be placed on top of it. The layout code is really simple, it's not HTML  Maybe you could do it by nesting the layers.
Yeah, the album art searching code can't handle it.
That would mean a change of foo_title's concept. And a lot of work too.
The <content> tag belongs to the layer whereas the next layer is independent from it.
Basically I think that foo_title needs to have a greater degree of customizability. Either by using some scripting, or loading user C# code on runtime or something. I was also thinking about switching to XAML and WPF, which would free me from a lot of drawing requests, but on the other hand, not everybody can get Expression Blend and it's not practical to write XAML by hand. And CPU/mem usage may be an issue as well. But that's not something I'm planning to do in the near future. foo_title works nice for me...
Reply #297
Thanks. A really neat component.
John
Reply #298
When using something like <position x="258" y="$ifequal(%ispaused%,1,-100,11)" align="left" /> in a layer, foobar2000 is putting out a warning in the console every startup (or sometimes on reapplying the skin):
Warning: System.FormatException: Die Eingabezeichenfolge hat das falsche Format.
  bei System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
  bei System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
  bei System.Single.Parse(String s, NumberStyles style, NumberFormatInfo info)
  bei fooTitle.Extending.Element.GetNumberFromAttribute(XmlNode where, String name, String def)
Also it ignores the values (in this example "-100" or "11") and falls back to value "1".
Is there any way to avoid that?
Reply #299
That's because foo_title needs a currently playing song to evaluate title formatting (even when it's something like %ispaused%) and at start there is no such song. Therefore we get an exception. Unfortunately there is no way around this.
