Topic: foo_title, new version for 0.9 (Read 284523 times) previous topic - next topic
Reply #225
Yes, it could be certainly fixed somehow, but just as the vista bug, I'm afraid I wont' be able to get to it in the near future.
No problem, just saying so that if you ever get to it, you'll have something to do.
Reply #227
I know you can't get to it, but wanted to report it anyway. It appears that foo_title makes my Windows XP shut down cancel: http://www.hydrogenaudio.org/forums/index....showtopic=60824
If I have the component set to always display in combination with 'only when new song starts', shutting down windows will cause the plugin to switch to display 'never'. And then I can't shut down windows, unless I manually exit foobar.
Reply #228
Yes, something like this happened to me as well.
Reply #229
Hi, I'm using foo_custominfo to rate my music.
Is there any possibility to update the %rating% with foo_title?
eg in <action>
RATE 1
RATE=1
RATING 1
RATING=1
doesn't work at all.
Is it possible? and so yes, what am I doing wrong?
Reply #230
The stuff in <action> must be a menu item, therefore this is not possible.
Reply #231
Thanks for the info!
Reply #232
@Quiark:
First off, thanks for this great plugin, yeeaaaaahh!!!
Now, when i minimize foobar to tray without foo_title he only 'eat' 10MB of RAM, then with foo_title enabled consumed RAM stays the same as it be on window maximized (from 40MB to 120MB ~).
Why this behavior?
Can you fix it?
Thanks in advance.
(sorry my bad english...its like growing from my ass..., i know this..)
p.d: Still you develops this component?? Some new features??
Reply #233
I was never really concerned about memory usage. After all, it's .NET, which just eats a little bit more memory. On the other hand, I don't think there is any memory leak either, because most of the code is managed. As for minimized/maximized foobar, there should be no difference, because foo_title is only working with it's own window and is completely independent from the main window. You may have measured the memory before a garbage collecting was done or you maybe didn't consider the memory that was currently on the swap.
I don't currently develop this component, so there is nothing new. However, the code is open, so anybody can do something  And because it's mostly in C#, I think it should be pretty easy
Reply #234
mmm...i don't think so...
I have measured the memory at every step.
I have the swap file disabled in my O.S..., i don't have swap file at all.., i have 2 GB of RAM on XP.., i don't need swap file...
well..:
Foobar maximized: from 40MB to 120MB ~ (with a lot of coverflows, obviously...)
Foobar minimized to tray: 10MB ~
now..:
Foobar maximized with foo_title: from 40MB to 120MB ~ (nothing changes...)
but...:
Foobar minimized to tray with foo_title: from 40MB to 120MB ~ (the same....)
As you'll see, RAM still charged when foo_title is enabled and send foobar to tray.
Why?
Understand me?
I like foo_title, but i want to minimize foobar to tray like without foo_title with only 10MB in RAM too.
Greetngs.
EDIT: Problem solved. Perhaps, cause' I had done the change between foo_ui_panels component from the 'buggy' from 14,2 version to 14,9...i don't know...
Sorry for waste your time...
Reply #235
with album art what formate dose it read?
i know .png works because thats what my no cover art is,
but i have many files that are mixed between .jpg and .jpeg and some are not showing up.
Reply #236
For image reading the .NET framework is used. However, when looking for an album art image, only the following extensions are tried: jpg, png, bmp, gif.
So the solution is to rename the jpeg files to jpg.
Reply #237
Thanks Quiark
Reply #238
I got a new machine and switched to Vista. I really miss foo_title!
the "now playing" gadget is nice stuff, but I prefer by far foo_title.
any chance to have a fix for foo_title on Vista ?
Reply #239
Not exactly what you want.
But CD Art Display is a nice little program.
(Yes, it's an external program, but on the other side I think it's running more smoothly and "just working")
Reply #240
Is possible for foo_title to show cover images from a folder inside the folder of the musics, like Artwork/*.*?
I use this in Album Art Panel and work.
Ok, I found in this thread the answer.
Reply #241
Great find dude. That is much better than the other one. best Alt to foo_title on Vista yet
--"If ignorance is bliss...then knock the smile of my face!"
Reply #242
I'm pretty sure that this may already have been answered, but is there a way to have two instances of this running? If not I would like to request it.
Reply #243
Not possible at the moment. I was thinking about it too.
Reply #244
Ok, I just installed Windows Vista and have been able to reproduce the problem. Now the difficult part - to fix it:)
Its interesting that it ran just fine in Vista RC1.
Reply #245
i hope you can get this nice plugin working good in vista. i too miss ths plugin. Good news you have vista installed now
Reply #246
Waoh, I never thought that this moment could become true
Glad to hear!
Reply #247
Quiark is still working on a release, but if you get the latest source from SourceForge, you can compile foo_title to work on Vista!  This is great news, and soon we will all be using foo_title again.  Thanks to Quiark for the updates.
Note: I can't say when a new release would be available... please be patient.
Reply #248
So the problem with Vista turned out to be a small one. So grab your foo_title 0.7.1 from sourceforge
0.7.1
    - foo_managedWrapper works on Vista again
    - auto restoring on top position every now and then
    - foo_title no longer prevents Windows from shutting down
    - skins are now also loaded from the user profile directory (if enabled in foobar)
foobar2000 0.9.5 required
Reply #249
Thanks Quiark for the Vista port
However, i have an issue with option "foo_title enabled only when foobar is minimized"
I tried hard to reproduce :
1. If I close foobar when it is minimized (from systray) then, at next start, it will restart minimized. foo_title behaves as it should : foo_title shows or hides when i further minimize/maximize foobar
2. If I close foobar when it's maximized, at the next start foobar will start maximized, but foo_title will not behave properly : never show when i minimize foobar
I run foobar 0.9.5.2 on vista.
EDIT : oops. Even when i do 1 above, after a minimize/maximize/minimize, foo_title will not show anymore. It works only once actually.
