Topic: foo_audioscrobbler 1.4.7 (Read 929318 times) previous topic - next topic
Reply #726
It would be even better this way IMHO:
Listening now using foobar2000 (without any version numbers)
Also, it would be good to replace the generic last.fm icon: LINK with foobar icon.
But these are just small details..as long as it scrobbles - i don't mind anything
Disregard the constabulary.
Reply #727
it's a minor annoyance indeed, but I would really love to see just foobar2000 with an icon
Reply #728
foobar is crashing every time I play a song with any sort of foreign character in it (tildes, accent marks), and I've isolated the problem to foo_audioscrobbler.  I'm using v1.4.3.  Does anyone else have a similar problem?
Reply #729
Have you submitted a crash report through the crash reporter?
Reply #730
does the "50% of the song = track scrobbled" rule apply to this component as well?
Reply #732
If I'm understanding this component correctly, once a track begins playing it is submitted to "currently playing", then is fully-scrobbled once the file completes.
Reply #733
shure, both components don´t interfere with each other...
edit: forget about my comment ...
Reply #735
This message show up in the console when I play a track
Audioscrobbler: Handshake failed: The system time is far off. Please correct your system time.
Audioscrobbler: Handshake failed.
Does this mean I have to change the time in my bios?
I'm using foobar v0.9.6.9
Reply #736
Setting (more) correct time (and/or time zone?) in Windows should be enough, I presume.
Reply #737
i would like to use a remapping feature of audioscrobbler, but it doesn't look to work properly for me.
I listen to radio and the words in track titles there are separated with underscores, so I've tried to use something like
 [$replace(%title%,'_', )]
but audioscrobbler still sends the title with underscores.
I have even tried to put some constant string in mapping field, like "aa" but audioscrobbler still sends the original  title to last.fm.
Maybe someone have ideas how such remapping could be done?
Reply #738
Any chance we'll see a "tag as favorite" option in this plugin soon?  It's basically the only thing I'm missing right now.
Reply #739
you mean love a track? there is another component that already does this.
foo_softplaylists
Reply #741
did you enter your username/password in the preferences? you can also check the foobar console (on the view menu) for any success/error messages.
Reply #742
Thanks, works now.  First time I installed it, I used the shortcut from the playlist to go to some preference screen and add my credentials, apparently I should have gone through foobar options and find the component settings instead.
Reply #743
my audioscrobbler 1.4.3 with foobar2000 1.0 beta 5 is not submiting tracks. I checked the console for status information, and it says: "Audioscrobbler: Previous submission still in progress". What should I do?
Reply #744
This happens when foobar2000 is running and another method of scrobbling is used at the same time. The new scrobble, for me this is usually via blip.fm or the last.fm site track player itself, handshakes and takes over, scrobbles its track, and disconnects. However, the audioscrobbler component doesn't know it needs to reinitiate the handshake, doesn't realize it has been superseded and hangs. A restart of foobar2000 will make it do so.
Once you restart, the handshake occurs normally and you can go to the File menu > Preferences > Tools > Audioscrobbler and press the submit button. This will scrobble those tracks in the buffer. The console should report the submitting process.
Reply #745
OK!
After some "submit", watch it go "connection error", then closing preferences, open it again and submit again, I was able to submit all 188 songs that were hung inside foobar. Thanks for the tip
I take this opportunity to leave here my suggestion to add some automated handshake and submitting in the component.
Moderation: Removed unnecessary full quote of the preceding post.
Reply #746
yeah this bug should be fixed... since this functionality was already there in some old version.
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #747
Seems scrobbling doesn't work with foobar 1.0 and foo_audioscrobbler 1.4.3 for me .
I can't submit my cache for some reason.
"Your cache contains 354 tracks. Check the console for status information."
After clicking on Submit, console tells me this:
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 354 cached tracks...
Audioscrobbler: Connection error
Ok, i thought let's try a restart of foobar - same error.
Someone else have this problem?
Reply #748
I have the same problem every once in a while.
I suggest to simply wait as the data doesn't get lost. Usually it fixes itself after some time. My guess is that the problem is on last.fm's end, not on yours.
Reply #749
Allright, will try again in some days
thanks mate!
