Topic: Newbie question : LAME 3.xx.xx ? (Read 50997 times) previous topic - next topic
Hello, this is my first post
Sorry to ask a typical newbie question :
I use EAC to encode my CDs, with LAME encoder. I usually use --alt preset extreme or --alt preset insane (mostly). Encoding time doesn't matter, quality is very important.
I couldn't find out from reading the topics about LAME, which version I shoud use...
How will I get the best quality :
- with 3.90.3 ? (official ?)
- with 3.96.1 ? (better ?)
- with 3.97 alpha 10 ? (best so far, but alpha = issues ?)
I don't want to wait for "3.97 final", because I have a lot of CDs to encode in the next weeks...
So what is the best choice ?
Thank you for your help
There is a recommended settings and recommended compile thread for a reason...
[a href="index.php?act=findpost&pid=301675"][{POST_SNAPBACK}][/a]
Yes, but the latest update is august 2004 !.. so it won't help me to decide if I should use 3.97 alpha 10 or better 3.96.1 or better 3.90.3...
What would be your advice ?
I already gave you my advice!
Did you even read it? The posts I referred to do have comments about 3.96.1 and when it should or should not be used.
If you want "the best quality" go with lossless like FLAC. If you insist on using MP3 rip some tracks with 3.90.3 then with 3.96.1 on API, if you can't hear the difference use which ever one is faster.
[span style=\'font-size:8pt;line-height:100%\']"We will restore chaos"-Bush on Iraq[/span]
I cannot give an advice, but here's what I am doing:
lossless: wavpack (..if you've got the space..; in the past I used Ape and Flac (chronical ordered))
mp3: lame 3.96.1 --alt-preset standard
I only use mp3 for not changing the CD all the time and it fits fine to my needs (hifi here, not PC-speakers)
Don't give too much on 'quality', if there's are real mentionable difference there's the next question if you (or the average-guest at your party) are able to hear it, this also depends on your playing-setup.
If you are paranoiac maybe use '--alt-preset extreme/insane', but I have never done this.
It's about music and this is mostly also fine if it is played a nuance more worst than possible - if you are sitting in the kitchen with friends you won't give sth. on quality, otherwise it will be an idea worth to recalibrate yourself
edit: typos
[a href="index.php?act=findpost&pid=301692"][{POST_SNAPBACK}][/a]
Of course, but I didn't find if 3.97 alpha10 is better for quality than 3.90.3 or 3.96.1 (sorry if the answer is obvious - I'm newbie in MP3 world) ?
Sorry but maybe I didn't search the right place or did not understand all : could you please give the link ?
Thank you.
So just one question left : using --alt-preset insane and sometimes --alt-preset extreme, is 3.97 alpha10 better than 3.90.3, or is there no noticeable difference ?
You should try by yourself. There are few people on this board able to compare two different encoders at this bitrate, and nobody did it in the past as far as I can remember.
Oh my...
Use --preset standard with 3.90.3 or 3.96.1. The results should be equal, but 3.90.3 is slower. I doubt you can hear a difference with extreme/insane.
3.97 is alpha so if you want to use it for archiving, you better wait for the final.
OK, thank you all
My, some snippy replies in this thread. The choice is actually a little difficult at this point....
LAME 3.90.3 --alt-preset standard (recommended, but conservatively, by HA)
LAME 3.96.1 --preset standard (faster, quality is sometimes better and sometimes worse than 3.90.3, smaller files, not as well tested though.)
LAME 3.97 (alpha 10) --preset fast standard (faster still, probably better quality, but still alpha so bugs are possible.)
I am personally using 3.97 at this time, since it seems to me that, alpha or not, a lot of listening tests went into it and it seems to be the highest quality at the fastest speed.
If you are really conservative, and want to be absolutely positive nothing really bad happens in some weird cases (instead of mostly sure), use 3.90.3.
Jebus: It has nothing to do with conservatism. It has everything to do with sensibility and thorough testing. Currently, 3.90.3 is the best tested and has delivered proven results. This is why it is the current recommended encoder. Unless you can prove why you need a different version, use 3.90.3. Using anything else will give suboptimal results in terms of quality. Every other choice is a decision to trade off quality for speed.
If you are looking to get the best quality from MPEG Layer 3 audio (which was ostensibly never designed for true perceptual transparency anyhow), use LAME v3.90.3.
Thank you for this answer, it's clearer for me now.
things are going slow in the mp3 world nowadays
the poineer work for LAME 3.x was done 1999 to 2001, now it's mostly unattractive (but still important) tunings
[a href="index.php?act=findpost&pid=301877"][{POST_SNAPBACK}][/a]
Between 3.97 and 4.0, the LAME team (however populated it is these days) is busy working on making the world's best MP3 encoder even better. Worry not.
I am glad that xp_98's questions have now been answered. It helps not only xp_98 but other newbies who pop in here from time to time to try to learn something about encoding. xp_98, thank you for asking your questions and to the many who gave helpful answers, thank you too
Well even assuming you are right on the first point (and i'm not convinced... there was a LOT of testing on both 3.96 final and 3.97 alphas... and a year of heavy use with 3.96.1 by the majority of readers here), I'm not sure why that means that 3.90.3 is in fact for SURE better than the later ones, as you imply. If anything, 3.97 tested clearly better according to Guruboolez's recent tests (primarily), and frankly I trust his ears more than your opinion. But I did warn that there is a slightly higher chance of unknown problems with the more recent versions.
I certainly did NOT mean conservativism in the negative (neo-con?) sense. I meant conservative as in safer.
As for conservatism, in the past I have always held out for stable versions, but in the case of 3.97a10 I make an exception.
My usage history has been:
replaced by
3.96.1 -V2 --scale x.xxxx
replaced by
3.97a10 -V2 --vbr-new --scale x.xxxx
Regards,
Madrigal
[a href="index.php?act=findpost&pid=301922"][{POST_SNAPBACK}][/a]
So if I'm not misreading you here, you acknowledge that it is safer, yet do not use it? That seems to be an exceptionally odd juxtaposition of beliefs.
[a href="index.php?act=findpost&pid=302004"][{POST_SNAPBACK}][/a]
If everybody only used what is considered "safer" because it is the most tested there would never be any progress. Innovation would come to a halt.
3.90.3 is great, but LAME continues to improve. In my opinion, Jebus has hit the nail on the head in his expanation of the current state of affairs.
[a href="index.php?act=findpost&pid=301872"][{POST_SNAPBACK}][/a]
That's just wrong. Lame 3.90.3 was tested in 2001-2002, and the fresh-builded --alt-preset standard appeared to work better than 3.89 --r3mix for similar bitrate. That's all. Claims based on very old tests have no validity anymore. All we know is that 3.90 is better than 3.89. Point. It's like saying that DivX 3.11 is the best MPEG-4 ASP encoder over DivX6 or Xvid 1.1, or that PsyTel 2.15 is the most pertinent AAC solution. Yes, it was true three years ago. But it doesn't mean that such statements are still true, just because a band of lazy people prefered to parrot blindly some recommendations rather than spending some of their free time to submit any feedback to active developers.
Did you ever tested 3.90.3 over 3.97, as it was requested by lame developers? I can't find any results. It's simply very rare to find feedback on HA.org these days... Then how could you prove that encoder x is superior to encoder y when you don't perform any blind test? I have tested several alphas of 3.97 and also 3.96.1 on many aspect and a big variety of sample. And based on my experience, following HA rules, I can say that 3.90.3 is not only slower but also have quality issues partially corrected by 3.97 alphas which makes latest alpha preferable (but maybe unsecure) for people looking for the best possible quality to any older lame versions.
Don't spread wrong information on this board please, or submit your test results if you have interesting things to reveal about 3.97 possible flaws. Gabriel & Robert are still working on lame, and that's the moment to submit all known issues.
replaced by
replaced by
Regards,
Madrigal
[a href="index.php?act=findpost&pid=301935"][{POST_SNAPBACK}][/a]
what is --scale x.xxxx?
if one has the disk space why not use --alt preset extreme? by being conservative do you mean that extreme might not work as smoothly as standard?
also how does one prevent EAC from crashing if the ID3 tags are not fully populated (freedb.org).
i am using....
--alt-preset extreme --id3v2-only --pad-id3v2 --ta "%a" --tt "%t" --tl "%g" --ty %y --tc "EAC LAME 3.90.3 Extreme" --tn %n --tg "%m" %s %d
BTW what is the advantage of using wapet? with say the following command line.
%d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" lame.exe --alt-preset extreme %s %d
sorry for being a diffcult but i want to archive 600 CDs and want a setting that is future proof (when bigger 4GB Ipod shuffle come out for example) or when playback systems can diffrentiate between APS and APE.
[a href="index.php?act=findpost&pid=302032"][{POST_SNAPBACK}][/a]
Then, by your standards, the administration itself is spreading wrong information.
3.97 Alphas and ALL future alpha versions -> ALPHA versions are for testing only! These include new code and are not tested or tuned at all. Many things are usually seriously broken or changed! DO NOT USE for anything, except for testing!
The currently recommended LAME version:
Download LAME 3.90.3
I'm merely attempting to help a new user figure things out, and reiterating the standard Hydrogenaudio position on these things. I suggest you take up your quarrel with the administration, not me. I've yet to hear from anyone whose opinions and ears I respected (other than yourself) that stated 3.97 is to be preferred over 3.90.3. The artifacting at those bitrates is beyond my ears; I acknowledge this fact, and have ABX results that show that I very likely can't hear a difference.
