Topic: Linux: using multiple compilers (Read 2860 times) previous topic - next topic
Ok, i'm going to see if i can get some kind of responce here, i failed with google ...
anyway, let's say i have GCC 2.95.3 installed and want to install 3.1.1 as well, i when by doing this by ./configure --prefix=/usr/local/gcc311;make install
nice, took a while to compile, but now what ?
how do i tell the ./configure script to actually use THAT gcc instead of the normal 2.95.3 one ???
i hope someone here knows
EDIT: I'm not sure it's ok to post it under general so here it is ... any moderator is free to move it if they feel like it
Usually it goes something like:
export CC=/path/to/compiler
./configure
Hope this helps,
Carsten Haese.
so i should do:
export CC=/usr/local/gcc311/gcc
./configure
or is it
./configure
and what's the difference between set and export ?
You should do the first, pointing the CC environment variable to the executable you wish to use.
Note that the instructions are for the bash shell. If you use a different shell, do whatever is necessary to set an environment variable in that shell. (E.g. something like 'setenv CC /usr/local/gcc311/gcc' for csh-like shells.)
The difference between set and export (in bash) is that 'export' sets environment variables, 'set' does not. I've never used set, but from what I gather from the info page, it seems to sets various options that control general shell behavior.
Maybe this helps now
Carsten Haese.
