Topic: Ask for 2 plugins. (Read 4458 times) previous topic - next topic
Ask for 2 plugins.
I don't know the exactly name of this two plugins. They are used for encoding.
The foo_lame plugin is used for encoding lame mp3. I want the version of based on 3.90.3 lame.dll's library.
And the foo_mpc is used for encoding .mpc files. Hope the plugin is based on 1.14 mppenc.exe library.
I don't like foo_clienc, it includes some encode configs that I don't need. It need the lame.exe and mppenc.exe, that is another reason I don't like use it.
More simple. That's what I like.
Thanks!~
Ask for 2 plugins.
The musepack encoder is not publicly available in library or even source code form. foo_musepack (I think that was the plugin was called) was just a frontend specifically for the muspack command line encoder.
I don't like foo_clienc, it includes some encode configs that I don't need. It need the lame.exe and mppenc.exe, that is another reason I don't like use it.[a href="index.php?act=findpost&pid=238984"][{POST_SNAPBACK}][/a]
Like I said above, you do need mppenc for foo_musepack. You can simply delete the foo_clienc presets you don't use. Since foo_clienc can be used with almost any encoder, there is little reason to create and maintain frontends for specific encoders, some of which would even duplicate code from foo_clienc to interface with a command line encoder.
Ask for 2 plugins.
Just as a sidenode: There never was a foo_lame, which was built on liblame. It was a frontend for lame.exe just like foo_clienc (and hence is deprecated nowadays).
Ask for 2 plugins.
For the sake of completeness: Musepack encoder source was not available when foo_musepack was created; it is now.
Ask for 2 plugins.
[snip]
Encoder sources are readily available for SV7/1.15r.
I'm unsure if the encoder has been rebuilt from sources by anyone for use as a plugin for foobar2000.  It could be an interesting project.
Edited per foosion's correction.
Ask for 2 plugins.
Where can one get one's hands on this so-called "foo_clienc"?
Ask for 2 plugins.
It's included in the normal and special installer.
Ask for 2 plugins.
I am sorry for offer the wrong name of this two plugins.
They should be foo_lamenc and foo_mpcenc, and the ogg encoder named foo_vorbicenc which I still can find it.
Please take a look at this:
http://www.hydrogenaudio.org/forums/index....topic=14961&hl=
and this:
http://www.hydrogenaudio.org/forums/index....topic=14309&hl=
Does this two plugins being abandoned???
Ask for 2 plugins.
Did you even bother reading the replies?
