Topic: Can't Connect From Home (Read 12745 times) previous topic - next topic
Today it happened to me too. I get timeout when trying to connect to HA. Ping results in timeout too, so according to indybrett it's my ISP or similar. In case it's something HA related: My IPs (dynamic) are in 80.133.*.* range - I haven't tried anything 1337, but since my provider is one of the biggest German DSL providers, someone else might have.
Invision Power Board Database Error
Warning: mysql_connect(): Too many connections in mySQL.php on line 67
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in mySQL.php on line 70
ERROR: Cannot find database hydrogen_ipb
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in mySQL.php on line 103
There appears to be an error with the Hydrogenaudio Forums database.
You can try to refresh the page by clicking here, if this does not fix the error, you can contact the board administrator by clicking here
Error Returned
mySQL query error: DELETE FROM ibf_sessions WHERE running_time < 1080756856 or ip_address='63.###.##.###'
mySQL error: Too many connections
mySQL error code:
Date: Wednesday 31st of March 2004 11:14:16 AM
We apologise for any inconvenience
The time of 11:14:16 AM was Pacific Time.
Is this what some of the above posts are also talking about?
I've received similiar messages as what is quoted above on more than a few occassions. The error however, is not repeatable if I disconnect my dial-up connection, and then re-connect to the Internet.
In my case it is not. This message is displayed because server is overloaded.
No. Completely different problem.
flac > schiit modi > schiit magni > hd650
I also can't connect to ha since I changed to German provider MSN, which uses 83.x.x.x IPs. Got this from them:
Vereinzelt treten noch Probleme mit Webseiten auf, die den 83er Adressbereich blockieren, da eine IP-Adress-Ankündigung der RIPE - in welcher der IP-Adresshorizont des neuen Backbone angegeben war - von einigen Sitebetreibern nicht beachtet wurde. Dies sollte aber innerhalb kürzester Zeit von Seiten der betroffenen Betreiber behoben werden.
Leider ist diese Behebung nur von seiten der jeweiligen Betreiber moeglich, wir selber haben keinen Einfluss darauf.
Der Betrieber der genannten Seite, respektive der Admin des Routings zu diesen Servern verweigern den Zugriff. Nicht wir, sondern der Betreiber ist somit in der Pflicht. Angemahnt haben wir es bereits 5 mal.
I now loggied in via university account and lynx, so please forgive me if this post looks strange stylewise.
According to MSN the problem is the site owner, so either Dibrom or his hoster, which seems to have blacklisted 83.x.x.x IP range. I would highly appreciate if this could be resolved.
In another FOrum I asked other Germans to tell me whether they can reach ha. Here is the link: http://www.dvdboard.de/forum/showthread.ph...8386#post548386
Exactly the same issue (still) here! My provider (Tiscali) also seems to use 83.x.x.x IPs. I can only access HA via a proxy since some weeks now.
Regards,
The Link
I've quadtriple checked, and we don't block 83.anything in either forum or server -level. So it must be that either Tiscali blocks us or our host blocks Tiscali.
Juha Laaksonheimo
Reply #32
So, if you are sure that HA doesn't block 83.x it would be a good idea to ask your hoster what they are doing, I guess.
PLEASE, could some of you admins contact HA's internet provider and do something with 83. problem? I'm getting this IP range from few days on my home connection (DSL) so I can't view HA at all. I can only visit HA on  Dial-Up at work, which is quite expensive here (Poland).
When I get this IP range only HA is blocked, other sites I visit work are viewed without problem. Please....
Reply #34
Maybe consider investigating the use of a proxy with your web browser, it's fairly straight forward thing todo.
daefeatures.co.uk
Reply #35
Well, I won't search for a proxy just for connecting ha. If they (and it is ha's hoster doing it wrong) can't fix it, I simply won't visit it anymore.
Reply #36
After few days I finally connected yesterday via my DSL connection. Just set my browser (MyIE2) to use proxy server.
To polish users of this forum: set proxy in config of your browser at:
w3cache.tpnet.pl:8080
So I have one question: is there any disadventage in connecting via proxy?
