Topic: EAC Unhandled exception at ASPI32.4152 -> ASSIGN-RANGE (Read 30440 times) previous topic - next topic
Re: EAC Unhandled exception at ASPI32.4152 -> ASSIGN-RANGE
Reply #125
How will the information be wrong, if those will be the settings used.
Don't you even read replies?
my inquiry, which was specifically "how to get rid of the error
... no, you don't.
Reply #126
What is with the AR database? Would this crap enter when pseudo ripped from a virtual drive?
Reply #127
There would need to be 2 or more people with, eh, the same workflow.
Not gonna happen.
Reply #128
And even if that happened twice, nobody else would you ever encounter those AR hits in this particular case.
Worse are those cases where you buy files that are ripped with errors from an actual CD. At least dBpoweramp tries to protect against submitting from virtual drives that mis-identify as actual drives - I don't know what EAC does, but in the very least it is possible to take some such measures. Also if a virtual drive identifies as such, the AccurateRip database will know, and results from doubtful drives are purged every now and then. Not saying it is fool-proof.
Reply #129
Thanks. One rip done with EAC and one in CUETools may be enough then.
Reply #130
Maybe for the CUETools database. I don't know about AccurateRip:
* Does CUETools even submit to the AccurateRip database? Anyway, just repeat the question with "EAC and dBpoweramp" instead.
* For that, I don't know: but IIRC dBpoweramp (the application) identifies the system configuration, so if you have a computer with two drives, use the first to rip with dBp, uninstall dBp completely and reinstall it and rip with the other drive, two identical won't count.
I don't know if EAC uses the same. (I'd be mildly surprised if they don't.)
Reply #131
Virtual drives are presented as suc in the EAC log. It's also unlikely that enyone else will have the same workflow, so in worst case scenario there will be an unusable entry in the database that will veryfy against itself in case I need to reprocess anything in the future, but if the records are purged periodically then there won't be anything to verify against.
Reply #132
IIRC CUETools can only compare your rip to existing AR entries. It cannot submit new results.
Reply #133
Still CUETools db may store some from EAC with plugin or CUETools itself.
Reply #134
Because you're converting your downloaded files from one format to another, not ripping a CD.
You need a new workflow for your downloaded files that does not involve EAC or any virtual CDs. You refuse to use any new workflow that doesn't produce a log file. So, what information do you need to see in a log file to be convinced that the new workflow without EAC is working correctly?
Reply #135
In fairness to the OP he's never stated that the convoluted act of taking downloaded files, mounting them as an image to then just turn them back into individual files offers any benefit, it just silences the voices in his head from his OCD; he literally just wants a text file that looks similar to all the other text files (from actual CD rips) to sit alongside the music. Please stop trying to understand his "logic" and workflow, we all know it makes no sense but that doesn't matter to him.
With regards to AccurateRip submissions, virtual drive submissions are excluded as are any real submissions from that user as noted here, that's why they recommended CUETools for splitting/verifying from anything other than actual CDs.
Reply #136
This pretty much sums up my approach.
So you can exclude submissions from certain computer addresses including real CDs so that rips done by specific computer's owner are not stored in the db?
Reply #137
I have no idea what level they block at but would assume it's either machine or EAC/dBpoweramp instance. I've never tried to look at the traffic going back to AccurateRip but I don't think it's secure so you can probably see what's being sent, although looking at the EAC AccurateRip submission screen it contains a string at the bottom labelled Computer, so I assume it's that, although I don't know what it's derived from.
Reply #138
Yeah, if it's useful to them.
Reply #139
I'll be straight: there is another possible reason, but the poster is not being obsessive, but just is exceptionally careful of not violating the TOS. And the mere fact of wanting to falsify EAC/AccurateRip results to facilitate is just...disappointing. Though not unexpected especially with todays standards...
I thought cred was earnt, not stolen. I'll just leave at that.  ::)
Reply #140
Believe me, I am not excepttionally careful, in fact I had been temporarily banned on multiple occasions on various databases and fb groups for being very OCD and some admins thought wat you were thinking, but after explaining my condition they would usually understand that they assumed incorrectly.
What today standards?
AR will be purging the results either way, so it's only for my othereise useless to anyone else 1s and 0s encoded in an artificial log file.
What would I possibly gain, if I was operating under your assumed pretenses?
Reply #141
OK, problem solved, the latest CueTools works fine, the option that must be turned off to not trigger the "Invalid stride" is "Verify using CTDB". The TOC is written to separate file however.
