Ogg chained streams are supported by foobar2000.
These FLAC streams are sending shoutcast StreamTitle metadata , IIRC foobar2000 does not support Shoutcast metadata with Ogg streams.
ffplay -v debug -hide_banner http://stream.radioparadise.com/flacm
Initialized direct3d renderer.
[NULL @ 00000177d8416000] Opening 'http://stream.radioparadise.com/flacm' for reading
[http @ 00000177d84166c0] Setting default whitelist 'http,https,tls,rtp,tcp,udp,crypto,httpproxy'
[tcp @ 00000177d8419d00] Original list of addresses:
[tcp @ 00000177d8419d00] Address 93.190.141.46 port 80
[tcp @ 00000177d8419d00] Interleaved list of addresses:
[tcp @ 00000177d8419d00] Starting connection attempt to 93.190.141.46 port 80
[tcp @ 00000177d8419d00] Successfully connected to 93.190.141.46 port 80
[http @ 00000177d84166c0] request: GET /flacm HTTP/1.1
User-Agent: Lavf/58.29.100
Accept: */*
Range: bytes=0-
Connection: close
Host: stream.radioparadise.com
Icy-MetaData: 1
[tcp @ 00000177d8419d00] Original list of addresses:= 0B f=0/0
[tcp @ 00000177d8419d00] Address 93.190.141.46 port 8022
[tcp @ 00000177d8419d00] Starting connection attempt to 93.190.141.46 port 8022
[tcp @ 00000177d8419d00] Successfully connected to 93.190.141.46 port 8022
[http @ 00000177d84166c0] request: GET /p/flacm HTTP/1.1
Accept: */*
Range: bytes=0-
Connection: close
Host: stream.radioparadise.com:8022
Icy-MetaData: 1
[ogg @ 00000177d8416000] Format ogg probed with size=2048 and score=100
[ogg @ 00000177d8416000] Before avformat_find_stream_info() pos: 45336 bytes read:63983 seeks:0 nb_streams:1 [ogg @ 00000177d8416000] All info found
[ogg @ 00000177d8416000] After avformat_find_stream_info() pos: 45336 bytes read:63983 seeks:0 frames:1
Input #0, ogg, from 'http://stream.radioparadise.com/flacm':
Metadata:
icy-br : 128
icy-description : DJ-mixed blend of modern and classic rock, electronica, world music, and more. Always 100% commercial-free
icy-genre : Eclectic
icy-name : Radio Paradise Main Mix (flac) - playlist: radioparadise.com
icy-pub : 1
icy-samplerate : 44100
icy-url : https://radioparadise.com
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0, 1, 1/44100: Audio: flac, 44100 Hz, stereo, s16
detected 4 logical cores
[ffplay_abuffer @ 00000177d8474a80] Setting 'sample_rate' to value '44100'
[ffplay_abuffer @ 00000177d8474a80] Setting 'sample_fmt' to value 's16'
[ffplay_abuffer @ 00000177d8474a80] Setting 'channels' to value '2'
[ffplay_abuffer @ 00000177d8474a80] Setting 'time_base' to value '1/44100'
[ffplay_abuffer @ 00000177d8474a80] Setting 'channel_layout' to value '0x3'
[ffplay_abuffer @ 00000177d8474a80] tb:1/44100 samplefmt:s16 samplerate:44100 chlayout:0x3
[AVFilterGraph @ 00000177d846b800] query_formats: 2 queried, 3 merged, 0 already done, 0 delayed
Created 640x480 texture with SDL_PIXELFORMAT_ARGB8888.
Created 640x480 texture with SDL_PIXELFORMAT_ARGB8888. 0B f=0/0
Audio frame changed from rate:44100 ch:2 fmt:s16 layout:stereo serial:-1 to rate:44100 ch:2 fmt:s16 layout:stereo serial:1
[ffplay_abuffer @ 00000177d846b800] Setting 'sample_rate' to value '44100'
[ffplay_abuffer @ 00000177d846b800] Setting 'sample_fmt' to value 's16'
[ffplay_abuffer @ 00000177d846b800] Setting 'channels' to value '2'
[ffplay_abuffer @ 00000177d846b800] Setting 'time_base' to value '1/44100'
[ffplay_abuffer @ 00000177d846b800] Setting 'channel_layout' to value '0x3'
[ffplay_abuffer @ 00000177d846b800] tb:1/44100 samplefmt:s16 samplerate:44100 chlayout:0x3
[AVFilterGraph @ 00000177d84b8100] query_formats: 2 queried, 3 merged, 0 already done, 0 delayed
[http @ 00000177d84166c0] Metadata update for StreamTitle: Neil Finn - Driving Me Mad
