Topic: replay gain and loudness... (Read 3763 times) previous topic - next topic
Is there a way to adjust the loudness when using replay gain? If I apply replay gain the default way the overall loudness is rather low for outdoor use.
Use ReplayGain preamp under Playback section in Preferences.
found it
thanks
Is replaygain pream modify sound exactly as original preamp and volume control dsp ? Or may be it use another algoritm.
A preamp is a preamp, it makes the sound louder. the only diff between the old preamp and the RG preamp is that the later only works on files with RG info.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
I love having this Preamp. Just love not having to remember it under the DSP.
P.S. The Preamp does have a slider for files w/o RG info too.
You don't understand me  I mean that (by my ear) preamp and replaygain may be use different algoritm to change loudness of music. E.g. when I volume down music (or preamp-down), it modify all frequences proportional. But when volume of music changed by replaygain, low frequences disappear more.
Or only I hear it ?
Or only I hear it ?
you only hear it.
