Topic: QAAC stream encoding (Read 3346 times) previous topic - next topic
I used custom encoding with ffmpeg and following params:
ffmpeg.exe -f s16le -ac 2 -ar 44100 -i - -f adts -c:a libfdk_aac -b:a 256k -cutoff 20000 -
So input is raw and output is encoded AAC stream.
How can I do the same using qaac?
Re: QAAC stream encoding
qaac --raw --adts --cbr 256 --lowpass 20000 -o - -
gold plated toslink fan
Incidentally, if you're curious about what macOS does for AAC supporting Bluetooth A2DP devices, at least in Big Sur:
At least for AirPods (original) and the Sony WH-1000XM4, it seems to use the same profile, where it sets the Apple AAC encoder to an average bitrate of 192000 bps, with a minimum packet size enforcing ~12.5kbps, and a maximum enforcing just under 256kbps.
Continuing my off-topic musing, it would be really neato if someone could implement third party A2DP codecs into Windows. I'd settle for just AAC, but LDAC would be lovely too, and there's a freely available encoder, including source code, it seems Sony only enforces licensing for decoders.
