Topic: This is why VST adaptor/ VST Wrapper cant handle VST plugins  (Read 2452 times) previous topic - next topic
You need set all VST plugins to same BUFFER SAMPLES.
I spend more than 4 hours to figure out how to solve this problem
1. Even if you run your favorite VS Ts plugins with F2K wrappers, F2K sound is still stuttering.
I mean even if i adjust all my  VS Ts plugins to same buffer - 1152 samples, which FX Teleport set.
Is was optimal settings for VST F2K adapters (VST adaptor and VST Wrapper).
2. So solution is run your VST host soft with Virtual Cable programs, but first thing, you need prepare your favorite VS Ts plugins to same buffer samples value.
So you need download FX Teleport - its freeware and wrap with this program your favorite VS Ts plugins.
After you finished this - you can upload VS Ts plugins that were wrapped by FX Teleport to your VST Host.
FX Teleport start perform automatic buffer sample adjustment.
This program working on 32 system.
FX Teleport - http://www.fx-max.com/fxt/download.html
You dont need to buy this software - they give you serial number - http://www.fx-max.com/fxt/purchase.html
MultuFXVST - https://www.kvraudio.com/product/multifxvst-by-ctaf
SAVIhost - https://www.hermannseib.com/english/savihost.htm
Virtual Cable - https://www.vb-audio.com/Cable/
Spoiler (click to show/hide)
Re: This is why VST adaptor/ VST Wrapper cant handle VST plugins
FX Teleport is running only on 32 bit Windows OS.
I don't need any of this and my foobar2000 runs VSTs without stuttering with both components...
VST HOST KIT:
LINKS:
1. FX TELEPORT -  - http://www.fx-max.com/fxt/download.html
2. VIRTUAL CABLE - BREAKAWAY PIPELINE - http://www.breakawayone.com/downloads/
3. VST HOST:
                       MULTIFXVST BY CTAF -  https://www.kvraudio.com/product/multifxvst-by-ctaf
                       SAVIHOST  -  https://www.hermannseib.com/english/savihost.htm
Or download attachment.
What are VSTs plugins that you use? What is your F2K dsp chain order?
At various occasions I have used TLS Maximizer, ACON Equalize, the ACON Denoiser and De-Clicker, Toneboosters Barricade 4, Melda AutoDynamicEQ, Valhalla Vintage Verb and some more I don't remember anymore. No particular dsp chain order but I generally don't have much in there except when I use a VST.
I've used VST plugins daily with the Yegor Petrov wrapper for years, with no audio problems. The only problem I have always had with that one, is that if I try to enter figures into text fields, instead of using the mouse, it always crashed FB2K. The other wrapper was even more buggy for me, when I last tried it.
I'm using plugins from Valhalla DSP, Klanghelm, DMG, TDR etc. all work fine if you only use the mouse to edit things. RME ASIO drivers.
I'm hoping for native FB2K VST support at some stage.
I am not musical engineer like you but sound (I use Direct Stream Virtual Cable output) and is much more better if i use FX Teleport wrapped plugins with VST Host. It can handle big buffer samples value it also bring you always output 32 bit.
Foer example: I measure optimal buffer value with F2K was 1152 samples with VST plugins  and with VST Host with wrapped VST plugins it was 4800 samples.
Man, you can say that again!!  That would be the REAL answer to all the workarounds/flakiness currently associated with using VST plugins in Foobar.
