Topic: foo_flv (Read 35944 times) previous topic - next topic
foo_flv
Thanks for thr update.
I wrote that it doesn't work correctly with HE-AAC but probably it was wrong: I cannot reproduce an issue.
foo_flv
Is it possible to stream audio from youtube videos by adding link with add location? If not, would it be possible to implement?
foo_flv
No this is not possible with foo_flv i I tried this.
I think that we don't need to watch the video in foobar, but just listen. And to have some preview with images in Playlist. And search option.
I think that this is not dificult to implement in foobar, at all.. , try this script on your browser:
<script src="http://www.yvoschaap.com/ytpage/ytembed.js" type="text/javascript"></script>
<div id="ytThumbs"></div>
<script type="text/javascript">
   ytEmbed.init({'block':'ytThumbs','q':'madonna','type':'search','results':10,'order':'most_relevance','player':'embed','layout':'full'});
</script>
*save this as ''html'' and run.
or try to type this adress in browser(this is a small youtube player):
http://1nltui3li1cdki8kde21baj1igs7ekjc.ig...l&hl=en-GB#
This shows how work youtube html. But now you have youtube API, and all you need to run video in aplication. This work perfect.
All this can be added in foobar with some WSH script or simmilar...
Problem is sound, maybe foo_flv can be modified to support online stream, and sound....
But no one is interested for this, some developer?
I wonder why?
foo_flv
Is it possible to see video? Or audio only?
foo_flv
Audio only. No video preview.
Re: foo_flv
Reply #30
Hello,
any place where I can still get foo_flv from ?
Please let me know, I really need it for my sweet Foobar.
Thank you.
Re: foo_flv
If the component is no longer available you should be able to play the same formats with FFmpeg input.
Re: foo_flv
Thx Case, but it does not work with .flv files Foobar still keeps skipping them, it does play .mp4 files.
I would appreciate if someone who uses foo_flv.dll would upload it.
Re: foo_flv
Reply #33
You have to manually add extensions to the FFmpeg input, and install a copy of FFmpeg. If it still doesn't work, dunno what to tell you.
Re: foo_flv
Reply #34
I am not sure what you are trying to tell me, I installed the component and it plays .mp4 files now, .flv is not compatible with mpeg if I am not wrong.
I have the ffmpeg.exe and ffprobe.exe folder specified and added .flv as format (Playback > Decoding > FFmpeg Decoder Wrapper) but it fails to play it.
Re: foo_flv
Reply #35
FFmpeg supports a whole mess of formats. You'll need to add the extension to the FFmpeg input settings manually.
Re: foo_flv
Reply #36
Now that I checked "Show codec names from FFmpeg" it works, thank you very much.
