Topic: Possible to Have Custom Column With DSP Resampled Bitrate Instead of Source? (Read 2015 times) previous topic - next topic
I have seen I can use %samplerate% to get the sample rate of the source file, but I would also like to show the DSP resampled rate (so I don't forget I left the resampler on for the next source I play).  Is that possible?
Re: Possible to Have Custom Column With DSP Resampled Bitrate Instead of Source?
If you show the DSP Switcher on the main interface, you can always see what DSP preset you have loaded, I have things like "Sox 96" or "None", so easy to see if SRC is on or off. Just a suggestion. Not sure how you'd implement seeing it in the custom column though...
Thanks for the suggestion.  I was hoping I could configure a custom variable.  Set the custom variable as the configured resample rate and reference the custom variable in the custom column but I could not get that to work.
A different approach perhaps: try the dynamic dsp plugin. With that, you would be able to turn the resampler or any other dsp on if needed, based on a custom tag value in your source files.
That's an interesting suggestion.  That's a bit more work tagging all the files, but worth considering for sure.  Thanks.
Keep in mind that this is not a one trick pony: I use it to convert 5.1 down to stereo, skip silence, remove pre-emphasis and a few other things. Worth the effort!
