Topic: Biography Discussion (Read 241836 times) previous topic - next topic
Re: Biography Discussion
Reply #400
2) Artist image crop function (autofill). The JS Smooth Browser image handling would need changing, but the script isn't mine, and so I am reluctant to post or pm modifications without it being OK'd by marc2k3. Have you asked marc2k3 to add the option anyway? I do already pretty much have the required code written since I added the feature, for personal use, to another falstaff script with essentially the same image code.
Marc2k3 has updated the JS Smooth Browser with the Auto-fill function as part of the latest foo_jscript update V2.2.0.2, see here. Works perfect, gives the JS Smooth Browser in grid mode a perfect look - big thanks to Marc !!
Reply #401
@seongbin I could not reproduce your issue (even with Chinese locale enabled on Win10). Could you please PM me one of the problematic mp3's with corresponding art image?
Or you can simply changing any mp3 file's artist name filed as 수상한 커튼
For Biography view, it remained as default setting.
Update:
The problem does not occur in English system locale(utf-8 support turned off),
for my case, it happened in Chinese simplified system locale(utf-8 supported turned off).
Reply #402
Update:
Yea, I've tried manually renamed mp3 (including fields) and img files on Win10 with Chinese Simplified locale (utf8 was turned off), but still could not reproduce :\
That's why I want to at least have the same file (in case it somehow matters)...
Reply #403
I made a zip for regarding files(audio & image) for your diagnostic.
Reply #405
@seongbin , hm, filenames inside your zip appear to be mangled for me (both with En and Simplified Chinese locales). Are they displayed properly on your system (i.e. inside the zip)?
Image:
Spoiler (click to show/hide)
Reply #406
I printed out the file infos as below.
수상한 커튼 - 이방인.mp3
Reply #407
The Unarchiver knows how to handle whatever encoding was used.
Reply #408
Thanks for the suggestion, but it seems that this is Mac only application =(
Reply #409
Or Unix. I don't know off-hand any Windows applications that have automatic code page detection for ZIP files, one of the few frequently used archive formats that usually get encoded in whatever the client machine is using.
Reply #410
@TheQwertiest
I had the same issue as you when I tried to unzip the file.
So I tried adding the zip (without unzipping) to a folder monitored by foobar2000 media library. At least on my device and locale that worked: the metadata seemed to display and work correctly in media library viewers, playlists, properties & biography. In fact the metadata was OK even if the unzipped folder was monitored. File names and paths were still garbled in both cases in properties etc, though.
HTH
Reply #411
I report an error:
Error: Spider Monkey Panel v1.1.5 (Biography v1.0.1 by WilB)
CheckMenuRadioItem failed:
Index is out of bounds
File: <main>
Line: 1491, Column: 587
Stack trace:
  sourceHeadTypeMenu@<main>:1491:587
  MenuItems/this.rbtn_up@<main>:1537:17
  on_mouse_rbtn_up@<main>:2823:34
Reply #412
I'm using fb2k v1.320 with SPM 1.1.5 and Biography 1.0.1 on W7 x64. Since a few days I realized that that I'm getting no more Biography Infos and Album Reviews from allmusic (only "Nothing found"), but last.fm as source for biography and album reviews is working perfectly. Even tried a few times to reinstall biography 1.0.1 after deleting folder yttm completely. I tried installing JScript 2.2.02 with Biograhy 0.9.03 (again after deleting yttm) buw with no results. If I chase allmusic as source or force source to allmusic the only answer I get is "Nothing found". Checking the allmusic website shows that allmusic isn't offline and also that biography or album reviews for the artists are present. By deleting yttm folder for reinstalling Biograhy script I realized "foo_lastfm_img.vbs" there. Wonder if no "foo_allmusic_img.vbs" is needed?
Forgot to say that I did a Windows Update for W7 and updated some components in my fb2k skin.
Any suggestions to solve this problem?
Reply #413
@ApacheReal
Reproduced & fixed for the next version.
@WebSkater
Initially just to confirm that the site is working for me as expected (fb2k 1.4.2 Win 10) and that only "foo_lastfm_img.vbs" is required. It's rather perplexing if one is working & not the other. It sounds as though it was working and then you made changes to your set-up such that it isn't working any longer. Confirm you have Biography.ini version A0002 (it's in the yttm folder; open with a text editor). To get there press shift & use" foobar2000\File menu\Browse Configuration folder" to be sure you're in the right location. Ensure server settings in "biography.ini" are valid, e.g. Album Review [Allmusic] or Biography [Allmusic] Auto-Fetch are enabled (set to 1 to enable), search title-format is valid and save paths are valid. Try deleting biography.ini (or renaming if you want to keep it) to reset to default. You could try clearing panel properties. Free disc space is also required to save the data, but I doubt if that's the issue. Check the save locations to see whether or not the data is actually being obtained and saved. You could try a fresh minimal portable install as a quick test. SMP doesn't have any special requirements to work on W7, as far as I know, that could have been effected by the W7 update.
Reply #414
@WebSkater
Please also ensure your system complies with the installation requirements for Spider Monkey Panel, in particular, since it looks like you're using 1.3.20, that Visual Studio 2017 Redistributable is installed / hasn't been effected by the W7 update.
Reply #415
@WilB
many thx for your quick reply. I'll test all your sugestions and report after the weekend.
Reply #416
@WilB
after hours ofter reinstalling, testing, reading, ... I finally got at least a few biograhys from allmusic. May be I found a reason for that strange behaviour not to show allmusic biographys, and it could be related to tagging.
A very huge part of my music library consists of SAMPLERS, COLLECTIONS and SINGLES:
- the tagging for %artist% is always the correct artist name.
- the tagging there for %album artist% always is "VA" or it is not set.
- the tagging for %album% in SAMPLERS is the name of the sampler ("Bravo Hits 101", "Bravo Hits Vol. 101" or "VA - Bravo Hits 101" for example"). In COLLECTIONS the tag %album% is 'misused' being a description like "Top 100 Single Charts". Concerning SINGLES %album% is not set or set to the same as %title% (as single releases or single tracks having no official album name).
The other part of my music library is ARTISTS ALBUMS:
- the tagging for %artist% is always the correct artist name, %album artist% for being the same as %artist" is empty.
- %album% tagging depends: if having more than one release %album% has a release desciption apended in brackets, for example "Greatest Hits (Jap. Edition)" or "Live at Wembley Stadium (Deluxe Edition)". If many cases in my 'audiophile albums' %album% is similar tagged as for example "Hotels & Dreamers  (Stockfish SFR 357.6028.2)" for one of my Allan Taylor albums.
On the "tenth reading" of your description I got aware that album tags could have to do with allmusic biograhys, but for only looking after biograhy (as biograhy seemed to me to be there more common thing compared to albums reviews, and I wanted to first have one thing to function properly) I completely overlooked this part of the description. Alltough it is not completely clear to me what to do to get satisfying results.
Beside your "Biography Script" I used 'foo_run' and 'Wsh.Shell run' to validate that allmusic has a biograhy for the choosen artist and in most instances I got to the correct biography, so that "album% could have to do something to do with finding a bio came not into my mind. But I remember I spent a lot of time with try and error to  set up foo_run for allmusic artist search before I found a satisfying result for me with "$replace(%artist%,' ','_','&','and')").Eval(true)". If I tried to use "...' ','_'...) in for searching allmusic artist albums I only got errors or nothing of value for me. But as you can see I'm not really very experienced when it comes down to programming or skinning - for me the most important thing is to have a fine looking and perfect funtionating foobar and to have lots of beautiful music.
As the problem is not solved for me, any suggestions to get satisfying biograhy results without %album% ?
PS: best thing of weekend and all the time researching my "bio-problem" was I accidentally found your "style function". And I have to say I'm much much more than impressed by it. It would have lasted for sure quite some time before I would have tried to figure out the "style fUnction" doing it all my normal way. May be it could be a good idea to post a video @youtube to show your beautiful biography script with all it's possibilities to the whole foobar community and link it al your avatar. A picture or a video says more than thousand words, and for many people doing a "how to video" is much easier than to write a detailed description.
Reply #417
I just found a very litle bug :
1: Activate Image+Text mode
2: play an album with a bio/review long enough to activate the scrollbar
2: With a mouse-wheel clic over the image, switch to the "image only" mode
3: Resize the window horizontally
4: Switch back to the image+Text mode
The scrollbar horizontal position will then be wrong. Hidden if you have made the panel thinner while in Image only mode, or overlapping the text if you have made it larger
Reply #418
@Ottodix
Reproduced & should be fixed in the next version. Thanks for reporting.
@WebSkater. Thanks for the feedback.
AM biographies
To discern artists of the same name, AM searches require and match the album + album artist. So the behaviour you see is by design (see documentation).
Where there is no album name or its not matched, AM biographies can be obtained through "Show More Items" menu. Here top albums of an artist can be searched at AM (& also LFM). The AM look-up checks the AM biography.
I re-examined the possibility of searching by artist name alone
It works well in many cases.
Problem cases: different artists with same name. No way of identifying correct artist in returned list. First match would be used, i.e. most popular artist.
A quick test showed that this method resulted in 2-3% of all AM biographies being for the wrong artist. I'm reluctant to add methods that aren't robust, especially since LFM biographies are available. It would also require some sort of manual interaction to deal with incorrect ones, which is cumbersome in itself, and which doesn't work well with auto-updating of biographies.
Note that loading of AM biography text files uses the artist name only, & assumes the correct one has been obtained by this stage. This maximises flexibility since it means existing AM biographies should work for singles, streams, artists on compilations, etc. It also means that only one matching album per artist is required to obtain the biography.
LFM biographies
These usually include all artists with the same name and so searching / loading can just use the artist.
Album reviews
A sufficiently close match between the search album name & that used by the site is required. Including "release desciption" type info as part of the name may break the look-up. It can be better to put that info in a separate tag; likely you won't want to do that though. The script does have an optional "Album Name Auto-Clean" option in server settings that will handle some common scenarios. One user found it helpful to truncate search album names at the first "("  [see here for how to do it].
Reply #419
@WilB
many thanks for your detailed reply. I'll test your sugestions the next days, and think it will help me a lot to understand the working of your beautiful script in detail. For the AM biography: what about searching for %artist% + %title% as a alternative option. I think it could help in most cases to find artists bios for single releases. Did you research this item too?
Reply #421
@WebSkater I tested your idea & it seems to work fine. It should be in the next version.
@huggy020
AFAIK it's not possible to auto-detect the artist - title order in streams, and so remapping would need to be applied on a stream by stream basis.
Artist stuff: this is fairly straightforward, and can already be done.
In server settings (biography.ini) you would need to remap %BIO_ARTIST%. Two examples are below. Adjust comparison string(s) as required.
%BIO_ARTIST%=$if($strstr(%path%,edge-bauermz),%title%,$if3($meta(artist,0),$meta(album artist,0),$meta(composer,0),$meta(performer,0)))
// Use $or for more than 1 stream. Example below has two streams but more could be added.
%BIO_ARTIST%=$if($or($strstr(%path%,sharp-stream.com/magicsoul),$strstr(%path%,sharp-stream.com/planetrock)),%title%,$if3($meta(artist,0),$meta(album artist,0),$meta(composer,0),$meta(performer,0)))
In panel properties one of the headings would need adjusting: "Heading Title Format Track Review..."
Within the heading change %title% to e.g.,
$if($strstr(%path%,edge-bauermz),%artist%,%title%)
If you display track reviews, that's currently more complicated as the title definition is hard coded, and changing it would require editing the script.
I might consider adding %BIO_TITLE% to server settings for the next version to make this easier. %BIO_ARTIST% and %BIO_TITLE% definitions in the server settings could then simply be remapped, but its only worth it if the remapping method is a satisfactory solution. It wouldn't then be necessary to edit the script at all + headings & subheadings would be handled automatically as well.
If you currently want to get track reviews working and don't mind editing the script then:
Shift+right click > configure
Locate:
this.title definition on ~line 995. Within it change $meta(title,0) to e.g.
$if($strstr(%path%,edge-bauermz),%artist%,$meta(title,0))
this.trackID definition on line ~996. Replace the whole line with e.g.,
this.trackID = focus => p.eval(p.tf.a + "$if($strstr(%path%,edge-bauermz),%artist%,%title%)", focus);
You would also need to similarly change one of the subheadings in panel properties: "Subheading Track Review Title Format..."
Reply #422
You'll also likely need to remap %BIO_ALBUMARTIST% in a similar way to %BIO_ARTIST%
Since it may be generally useful, I went ahead and added %BIO_TITLE% to server setting in my copy. This should help with remapping etc.  It should be in the next version.
HTH
Reply #423
@WilB Thanks. I think I will go on and try it
Reply #424
I tried the artist stuff and its good. I will stop there and wait for the next version
