Topic: How to encode FLAC without any compression? (Read 6564 times) previous topic - next topic
I bought a FLAC from a Hi-Res music website
Sample rate : 96000 Hz
Channels : 2
Bits per sample : 24
Bitrate : 4616 kbps
The original FLAC file is
185 293 054 bytes
This file only embedded one jpg, this size is
151 601 bytes
I decode this file
flac -d *.flac
But the size of wav file is
184 813 928 bytes
I tried to use -0 to encode the wav again
flac -V -0 *.wav
But the size of output FLAC is
138 330 934 bytes
I also checked Audio MD5 of original flac and new flac, their MD5 are same
Why the website can encode a no compression FLAC file? How can I do that?
Re: How to encode FLAC without any compression?
maybe website use ffmpeg or some else "flake"? in general, it is strange that the encoder compresses worse than the source...
Ah no.  FFMPEG shouldn't cause a problem like that.  I think the problem is with the source itself or the original poster could be making it up.
To check if it is really uncompressed you could try a general file compressor like 7zip or rar to compress the file and see if it gets a bit smaller. If it does not, i could also be there is a lot of hidden meta info in the file.
You can create uncompressed FLAC with parameters
-0 --disable-fixed-subframes --disable-constant-subframes
But it is a pointless thing to do. Uncompressed files are typically needed only during editing for fast loading and random access. But this type of FLAC stream is still treated as compressed by all software, and cause a delay on load and possibly a decoded proxy file to be built. Uncompressed PNG images are equally pointless.
You can detect uncompressed multimedia data (sound and picture) by looking at a byte frequency histogram in a hex editor. Any significant fraction of uncompressed bytes will show smooth curves.
Thank you, now I can reproduce similar FLAC
I will not keep uncompressed FLAC, I just want to know why.
This is definitely one of those things that make me wonder how on earth I'd never given it a second thought before.
União e reconstrução
