Topic: Lame 3.100 has been released (Read 128812 times) previous topic - next topic
Re: Lame 3.100 has been released
Reply #100
Looks like Rarewares build is fastest without patches. But the problem is 32bit & 64bit versions don't null and three pops appear in beggining of one of the files (when null compared). I have no idea why if they use same Intel Compiler.
Maybe it should be recompiled again?
What program do you use for this comparison? Those pops are not audible for you?
I've re-compiled and uploaded the lame bundles. The 32 bit version appears unchanged, but there is a difference with the 64 bit version. Personally, I can't hear a difference, but maybe someone can do a more exhaustive check. :)
I have compared 4 files encoded with your 64-bit version compiled in October and in December. Binary comparator in foobar2000 says "no differences found".
BTW, I am converting using foobar2000 converter. Is it in any way important that I am inititating 64-bit LAME encoder from foobar2000 which is 32-bit program?
iRiver H10 20 GB - Rockbox
Reply #101
I didn't expect there to be any difference between the Oct and Dec compiles, I just re-checked the compile options just to be sure that I hadn't missed something the first time round. ;) I also usually convert using Foobar as you specify and, no, that isn't an issue.
Reply #102
"Slivka" was saying that your "32bit & 64bit versions don't null and three pops appear in beggining of one of the files (when null compared)" so I thought you are recompiling to check if this is eliminated :) Are those "pops" even confirmed? As I understand 32-bit and 64-bit compiled versions can produce slightly different files in encoding, but I don't know what he meant by "three pops in the beginning". Three pops that can be heard or just three bits with different values?
Reply #103
tmkk patch + fastcrc patch + clang 8.0 snapshot (Full LTO) + msvc2010 lib
nothing special, GOGO-no-coda ~256kbps VBR + mp3packer
Reply #104
I may be the sole user of lamedrop (xpd) . . .
+1
You are not alone :)
Me too. LameDropXPd has been my "go-to" Lame frontend for a long time.
New LamedropXPd compiles uploaded with the narrative corrected. :)
Thanks John. And for all the work you do for making our music enjoyment better.
Artie
Reply #105
Why when compressing to V0 there's 20kHz lowpass on 3.100 when in LAME 3.99 that lowpass was removed? I know I should listen with my ears not eyes and I'm not saying 3.99 sounds better because of this, but I'm just curious why it was removed in 3.99 and then added again in 3.100. Thank you for help.
Reply #106
lame.exe -V0 test.wav
LAME 3.100 32bits (http://lame.sf.net)
CPU features: MMX (ASM used), SSE (ASM used), SSE2
polyphase lowpass filter disabled
Encoding test.wav to test.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=0)
So no, there's no 20 kHz lowpass.
Reply #107
Maybe there's no lowpass filter, but comparing to 3.99r there's much less audio above 20kHz:
Spoiler (click to show/hide)
I'm using LAME 3.100 64bit build from RareWares if that matters.
Reply #109
I just tested 3.100-2 (-2 being a distribution second edition, -1 would be the first release of that version).
Top is original, bottom is 3.100 -V0.
Reply #110
It seems that there is some bug in original build from tmkk. On some files when encoding with -S --noreplaygain -V 0 encoder crashes with error and resulting mp3 file is corrupted.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Encoding D:\Music\I Love Disco Diamonds Collection\I Love Disco Diamonds Collection Vol. 14\02. Yeti.wav
      to D:\Music\I Love Disco Diamonds Collection\I Love Disco Diamonds Collection Vol. 14\02. Yeti.mp3
Assertion failed!
Program: D:\0__CODECS\Lossy\LAME\3.100\lame_tmkk.exe
File: ../../libmp3lame/vbrquantize.c, Line 948
Expression: vbrsf[sfb] >= vbrsfmin[sfb]
Windows 7 32 bit, core i3 3245
File is too long to share here, but if someone is interested, i can send link in PM. It is track #2 from CD #14 from compilation "I Love Disco Diamonds Collection"
Reply #112
tmkk already reported the bug and a fix is in SVN.
https://sourceforge.net/p/lame/bugs/496/
https://sourceforge.net/p/lame/svn/6438/tree//trunk/lame/libmp3lame/vector/xmm_quantize_sub.c?diff=59e1c885dab7b929b5817e2e:6437
Seems like you are running a debug version.
Is compiled binary with fix available somewhere? I used binary from tmkk's site dated 2017.10.14
Reply #114
tmkk patch + fastcrc patch + clang-cl 9.0 snapshot (Full LTO, SSE2 (ASM used) forcing, AMD procie target) + msvc2013 lib (WinXP SP3)
btw unstable
Reply #115
btw unstable
Hello friend, can you tell me how to compile Lame encoder?I like this small and easy-to-use coding scheme very much, so I want to delve into it.
Can you tell me?I look forward to your reply, best wishes.
Reply #116
Perhaps,
You can also record a video the next time you make it.
English is not very good, I'm sorry :)
Reply #117
btw unstable
compile lame via clang-cl?
in simplest (as example)
1st install msvc/visual studio 2017 x64
[or 2010/2013/2015 etc]
then...
1. download clang x64 snapshot or stable for windows
     open with 7zip (keep default msvc's config)
     (1) select file
          1. clang-cl.exe
          2. lld-link.exe
          3. llvm-lib.exe
          copy & paste into /bin/ in "VC folder" (/bin/HostX64/x64/)
          [in visual studio folder]
          rename llvm-lib.exe -> lib.exe
          [1st backup msvc's lib.exe]
     (2) select all folder in /lib/
          copy & paste into /lib/ in "VC folder" (/lib/x64)
2. download nasm for windows
     open with 7zip
     select file -> nasm.exe
     rename nasm.exe -> nasmw.exe
3. edit makefile.msvc (in /lame-svn-?-trunk/lame/)
     [in msvc config section]
     replace string
     cl -> clang-cl [flags]
     link -> lld-link /force [flags]
     link -> lld-link /force /DLL [flags] to combating lame_enc.dll
     then save
4. select file -> lame.h "lame header file"
     (in /lame-svn-?-trunk/lame/include/)
     copy & paste into /include/ in "VC folder"
5. open visual c++ command prompt
     cd /lame-svn-?-trunk/lame/
     nmake -f makefile.msvc lame_enc.dll
     cd output
6. if visual studio 2019 + clang-cl can create lame.exe
    but "no speed" in Win10
     (1) grab lib
          grab libmmt.lib & libirc.lib from intel compiler lib
          grab libucrtbase.a from mingw-w64 runtime 6.0
          rename libucrtbase.a -> libucrt.lib
          [1st backup msvc's libucrt.lib]
     (2) linking into libmmt.lib
          edit /frontend/main.obj
          replace string
          libcmt.lib -> libmmt.lib
     (3) _strnlen missing in parse.obj
          open msvc's libucrt.lib with 7zip
          search strnlen.obj
          convert strnlen.obj -> custom.lib
          edit /frontend/parse.obj
          replace string
          libcmt.lib -> custom.lib
Reply #118
tmkk patch + clang 9.0 snapshot (Full LTO, Intel procie target) + msvc2013 lib + icl17 lib
no fastcrc patch (contra with icl17 lib)
Reply #119
tmkk patch + clang 10.0 snapshot (Full LTO, psymodel w/ -fveclib=SVML (SVML exp2 forcing), Intel procie target) + msvc2010 lib + svml 15 lib
-V0 & -V1 "higher" bitrate testing
