Topic: PCM, DSD - Trying to get my head round some basics (Read 44787 times) previous topic - next topic
Re: PCM, DSD - Trying to get my head round some basics
Reply #125
Before I am getting more replies, let me make a guess...
Since file conversion is a non-realtime process, so adjustment can always be made afterwards, and SoX made such a correction?
Seems so. izotope lately fixed the sample allignment also.
I wonder after all the posts about SoX at HA people still fiddle around with other half-baked resampler options!?
Reply #126
The point I don't understand is the SoX plugin can be easily downloaded and checked and by default (see the screenshot setting) it can already give a super beautiful sweep, why there is no delay?
Any resampler could compensate for the delay. It's just a matter of dropping the extra silent samples.
For plugins i guess the offset relates in big part to the host. Not sure the SoX plugin can work as proper as SoX standalone.
Reply #127
They are not necessarily silent, though - if the source doesn't start with silence, they are "pre-ringing" oscillations (albeit with small amplitude)
Reply #128
Because SoX is free and popular, it must be mediocre.
Reply #129
If you look at my short test you see that David's version has values varying all over the place too depending on the sample rate.
Nonsense:
Sample rateITUOriginal
352.8 kHz-3.99 dB-1.98 dB
192 kHz-0.96 dB-3.74 dB
48 kHz-1.47 dB-1.98 dB
44.1 kHz-1.47 dB-2.07 dB
The 192 kHz file gives entirely different results than the others.
True, but as you were so quick to point the finger at an implementation bug (44.1 vs 48), let's not rule this out as a possibility for 192.
It's weird how you are in such a disagreement with the new scanner. I have files from all genres except rap and jazz and I'm pleased with the volume leveling.
It's not weird at all.  I'm not at all pleased with the leveling for metal.  I suspect it is because metal has more prevalent HF content causing 1770 to over-compensate because it doesn't implement an effective equal loudness filter.  If you're trying to model the human perception of loudness I would think one should use a proper model of human frequency response and I suspect 1770 is lacking in this regard, if not inferior to the original algorithm at the very least.  That Peter needs to add an ultrasonic bandaid in order to get the new algorithm to spit out accurate results only stands to confirm my suspicions.
Edit: forgot to mention that you can still use the old ReplayGain scanner before libebur128 implementation by manually replacing the foo_rgscan.dll file. You can find the last version in foobar2000 v1.1.5
Thanks! YAY!!!!
Reply #130
Pffft.
What's the frequency of this pre-ringing again?!?
Please don't interpret this as my being critical of you, judd, rather I see pre-ringing as the new jitter; striking fear in the hearts of placebophiles.
Reply #131
Pffft.
why is that relevant ?
My point was about truncating non-zero samples.
It's probably not a big concern, but then neither is a sub-1ms delay.
Reply #132
You posted while I was in the midst of an edit, as I suspected you would take it the wrong way and get defensive.
My apologies for not having the foresight to initially include it prior to posting.
(EDIT: I decided to split the infinitive rather than put initially at the end.)
Reply #133
Ah, it's all good :-)
I was looking at it more from a mathematical PoV.
Just so you know, I'm not a "true believer" about ringing.
Personally, I've tried to ABX various filter "steepnesses" and I can't hear it.
But that's just me ...
Reply #134
No worries, I could tell.
But that's just me
...and just about everyone else who knows something about the nuts and bolts of audio including an understanding of the perception of sound which is something many (most?) computer scientists and engineers (both degreed and ceremoniously titled audio engineers, alike) woefully lack.
Reply #135
I thought this was a nice example from the 2L site of Cello harmonics popping out of the mix, extending up into the 30-40kHz range.
(It's a bit hard to see in a static screenshot; easier to spot on live display)
This is a nice change from the familiar 20kHz roll-off you see all-too-often in many other hi-re$ files.
image link
from the 96kHz version of "North Country II" at around 3:54.3 (unfortunately, DSD version is not available for comparison)
Of course, I don't claim to be able to hear any of the ultrasonic stuff, but it is interesting to see some actual (music-related) ultrasonic material in there - even though the high-frequency components are at pretty low amplitudes.
Reply #136
Just to play devil's advocate, are we sure the harmonics actually emanated from the cello or could they have been the result of non-linear distortion somewhere in the signal chain?
Reply #137
yeah, it could be distortion. Who knows ?
I think they are using some pretty nice mics, though, so i suspect it could be the real deal.
Some mics, (like an Earthworks QTC-50) can capture those frequencies.
It definitely correlates nicely with that particular Cello note, if you watch/listen at the same time.
I was looking for a solo example of one of the brighter-sounding instruments to isolate it, but so far I haven't come across a solo Cello passage yet.
Reply #138
Real or not, I can't hear that. But of course I can set the playback speed to 48k and listen to them in an octave lower and in half speed. ;)
Reply #139
Haha - I've done that too.
Sometimes I completely filter out the audible spectrum first, and slow down what's left :-)
Reply #140
So the stuff at 40k would then be at 20k but still well below your threshold of hearing at those frequencies, assuming you still have the hair cells to detect them. ;)
Reply #141
 Quarter-speed  ? :D
Reply #143
Only thing missing in this thread now is why to wurry about dsd and alike when the best ears in this world know only de-blurred MQA sounds right...
Reply #144
Well after all. everyone knows that MQA "delivers fuller, more tonally satisfying bass notes and a better sense of the space surrounding [Ella] Fitzgerald’s voice" :D
Reply #145
...and a fuller spectrogram
Reply #147
Lossy is fine as long as it's MQA certified ;)
Reply #148
In my book, careful examination of the files being ABX'd is a natural part of the work flow for preparing the experiment.
The basic influences that most often need to be controlled are:
(1) Level   goal: +/- 0.1 dB
(2) Frequency response: +/- 0.1 dB 20-20K
(3) Time offsets +/- 100 uSecc
Level and time offsets are easy enough to check and correct with any of a large number of audio editors.
Measuring and correcting frequency responsemay be non trivial. One shortcut is to run the Audio Rightmark test file and then evaluate it.  IOW. append the Rightmark test file to the beginning or end of the test file, run it through your test process, and then edit it out and test it with the Rightmark program.
These are what I would call "Best practices" numbers - goals that ensure very unambiguous results.
You may  need to compromise them, but then the compromise should be tested all by itself to ensure that it is not an audible influence in context.
Reply #149
Jumping back to my pressed/burned CD "anecdote", now that I know a (little) bit more about PCM, I am willing to accept that a digital data misread could not alter a soundwave (yay!).
Any difference could also have been in my imagination (shock horror!).
Out of curiosity, though, for those folk who know about such things, is there any way (perhaps a badly designed power supply?) that a laser head fighting to read a mistracked disc, or power fluctuations due to spin speed alteration for the same reason may have any effect on an outgoing analogue signal? (more so with 30-year old CD players?).
Yes, I'm clutching at straws in the hope that my youth wasn't quite as misguided as it looks like it might have been...  :-[
