Topic: [fb2k v2] Random Pools (foo_random_pools) (Read 187521 times) previous topic - next topic
foo_random_pools
Reply #175
Can't update to version 0.1.4: Could not load component "c663b5e2c5857822a8d97aafe925ce52a35a354d.zip": Unsupported format or corrupted file
foo_random_pools
Reply #177
I'm not sure if this component is still actively being developed, but if so, is there any chance of getting a setting on the main page that would trigger the generation of new pools by length of the playlist rather than size or position? This was an option that used to exist on the original playlist tree component. I.e., I want the component to add new pools when the playlist length is, for example, under 60 minutes. My library contains wildly varying track lengths so the same number of tracks can be 45 minutes or 90 minutes depending on luck.
On the other hand if there's already a way to do this through clever queries then I would appreciate if someone could give me a hint. If not, no big deal, I have been happily using this component for several years and am very thankful to the developer, it's the best "auto DJ"-type code I've ever seen in any program.
foo_random_pools
Reply #178
Since some years I have plans to extend the component with some functionalities, but due to a lack of time, I couldn't realize them so far. However, I found some spare time and added the feature you requested. Just update the component with the update function of foobar2000.
Re: foo_random_pools
Reply #179
So I'm trying my hand on this component for the first time and I'm sure there's something I'm doing wrong here but it doesn't seem to do anything even with the most basic of terms I use.
So I have this;
Group: %album%
Number of tracks to add: 50
Number of minutes to add: 200
Number of MBs to add: 0
Filter: %genre% IS Progressive Rock
Sort: %path_sort%
Filter with the content of the target playlist: unchecked
Sort / Limit each group: unchekced
Priority: 1
Autoadd
Playlist patterns: test
Add. when playlist has X items or less: 10
Add. when the playlist duration is X minutes or less: 0
Add. when the playback positions is X items or less from the end: 0
I would expect for the Test playlist to be filled with a random number of albums filtered on Progressive Rock but the result is nothing. It doesn't fill the playlist at all. Can someone give some hints as to what I'm doing wrong here.
Reply #180
Hi.
Is your profile working when you try it manually via File/Random Pools/Progressive Rock when Test playlist is active ?
If yes, try to delete some items to have 10 or less in order to see if autoadd is working.
If no you'll have to dig a little more...  ::)
So I have this;
Group: %album%
Sort: %path_sort%
Priority: 1
Autoadd
Reply #181
Yes, if I do that that it seems to fill the playlist. However, I can see no automatic adding (or removal) of tracks. I played around a bit and I would expect if the filter indicates %play_counter% IS 0 that as soon as it's changed to 1 it would automatically remove it from the playlist. Not happening, in fact the way it functions now I would have to manually remove the played tracks and then fill the playlist again by manually filling it by clicking file - random pools.
Reply #182
This plugin won't remove any played track from your playlist.
What you seem to want is a rolling playlist with its content changing while playing. I have this working in my foobar for years now.
To achieve that you must use the Playlist Attributes plugin (another great plugin from fbuser) which has the option to remove tracks after it has been played (or skipped).
Look at the documentation to discover other features.
To avoid playing the same tracks (it depends on the size of your library) you can add an additional condition in your filter like : %genre% IS "Progressive Rock" AND NOT %last_played% DURING LAST 1 HOURS
Hope this will help you.
Reply #183
Thanks, will check out your suggestion.
Reply #184
Hi guys, I'm attempting to follow the documentation, but I honestly find it very confusing and unclear. I simply am trying to get a playlist that grabs 5 albums at random from my library at a time. What I mean by this is that everytime I click onto the playlist, I would like for it to have a new set of 5 random albums (preferably with no duplicates. I'm not sure if foo_random_pools is capable of this).
So I created a new Playlist called 'Random Albums', went into the foo_random_pools options and did this. Can someone let me know what I'm doing wrong, or the right way to get what I'm trying to achieve? For the record, the playlist seems to not populate at all. Thanks.
Reply #185
Go to Random Albums and add a track and play it. You'll find your albums are added.
Or from main menu: File > Random Pools > Album
This will populate any playlist with your criteria. You may want to add something like:
%album% - %tracknumber%
To the sort box and tick sort limit each group.
Also filter with the content of the target playlist will get rid of duplicates AFAIK.
You realise you can do the same thing pretty much, just by choosing Shuffle Albums from the drop down and playing a playlist of your entire library.
C.
Reply #186
fbuser,
Thank you for your efforts, I love this plugin. I know this has been requested before (replies 60 & 80) - the ability to assign pools to different playlists - any chance???
Reply #187
fbuser,
I guess what would be ideal (for me anyway) is to have a check box labeled "Create one playlist per pool". If unchecked, foo_random pools would operate the way it is currently. If checked, foo_random_pools would create one playlist per pool. The name of the playlist could be the name of the pool.
I would be interested in any feedback on the idea: good, dumb, not worth the time to implement, too hard to implement, etc.
Reply #188
Is there a way to schedule random pools to activate every so often?  Basically a way to have it work with the Scheduler plugin?
Reply #189
Basically the idea is not bad and I might implement this in some way in the more or less far future. However, you can at least partially get what you want by using foo_scheduler as described below in combination with the "Set active playlist" action. Also, you can get what you want by utilizing foo_jscript_panel with the a piece of code similar to this (not tested, no error handling):
function getPlaylistIndex(name) {
  var idx=-1;
  for(var i=0;i<plman.PlaylistCount;i++)  {
    if(plman.GetPlaylistName(i)===name)  {
      idx=i;
      break;
  return idx;
function poolToPlaylist(poolName,playlistName) {
  var playlistIndex=getPlaylistIndex(playlistName);
  plman.ActivePlaylist=playlistIndex;
  plman.ClearPlaylist(playlistIndex);
  fb.RunMainMenuCommand("Random pools/"+poolName);
poolToPlaylist("Pool1","Playlist1");
poolToPlaylist("Pool2","Playlist2");
Of course, you need to either create a button or a main menu entry to run this code.
Yes, just use the "Launch application" action with foobar2000.exe /command:"<pool name>". You might need to supply the full path to foobar2000.exe
For the restrictions for the /command parameter and how to overcome them, see here.
Reply #190
fbuser,
Appreciate your reply, and I see what you are saying. I don't think that will work for what I am trying to accomplish.
I run fb2k on a pc that sits in a closet and streams music throughout my house. I can control some functions (play control, playlist selection/editing) of f2bk from an app on my phone.  90% of the time I listen to autoplaylists on shuffle mode; these playlists are generally based on combinations of genre and rating. Autoplaylists can't be modified (individual songs deleted, moved, etc). I can't determine which song will play next, but I can hit the skip button if I don't want to hear a particular song at that moment.
What I really like about foo_random_pools and foo_playlist_attributes is that, together, they allow me to create a playlist which contains ~25 (or any number) randomly selected songs that will be played next. (foo_playlist_attributes removes songs that have been played/skipped and foo_random_pools adds songs to keep the playlist at ~25 songs.) For this one playlist, using my phone app, I can look at the list of 25 songs coming up and get rid of the ones I don't feel like listening to at the moment. I can let this playlist run indefinitely and I can also manage the next ~hour's worth of music at any time.  I would love to have this capability for all my playlists. Being able to assign a random_pool for each playlist would accomplish this. There may be other ways???
Reply #191
For the devs! Please consider to implement a sort descending... thanks! random pools is awesome!
Reply #192
as a new user of random pools i create 2 pools in my random pools
each one works correctly by itself
However when i choose to add "All pools" only one is added in the playlist...
Here a screenshort of my random pools :
Reply #193
This is correct. If you choose "All pools" one of the pools with a priority greater zero is randomly choosen by considering the priority of each pool. For example, if you have two pools defined, A (with priority 9) and B (with priority 1), then pool A will be selected with a probability of 90% and pool B with a probability of 10%.
Reply #194
ok, tx
Reply #195
So it's not possible to use Random Pools to create a playlist that select a random song of Reggae for example then select a random song of Rocksteady then again and again?
And i can't understand what "Group" is.
It's always all my librairy or can i select a part of my librairy here?
Then in filters if i want to use several filters is it possible? (i tried with "%Rate% GREATER 2 AND %Genre% IS Reggae" but it doesn't work)
Reply #196
Only manually, but not automatically. However, it would be possible to create a script in JScriptPanel to automate this up to a certain extent.
A group is a set of tracks with the same attributes defined by a title format expression, i.e. if you set the group to %artist%, set the number of groups to 2 and don't set a limit for adding tracks, all tracks for 2 randomly chosen artists are added. Filtering the library can be done by entering a filter expression in the Filter field.
If your library is tagged accordingly this will work. Is %Rate% spelled correctly? Normally the tag %Rating% is used in such cases. You can easily test a filter by going to the menu "Library -> Search" and enter the filter expression there.
Reply #197
Hello,
is it possible to get a playlist composed of 25%Funk, 25%Rock, 25%Electro, 25%World with tracks sorted randomly?
If yes, can someone explain me how please? (I already use Foobar, foo_random_pools is installed, my flac library is tagged)
Thank you in advance, I read twice thre 8 pages but I couldn't understand the way to give instructions to foo_random_pools (but I guess a big potential!).
Re: foo_random_pools: some preset button?
Reply #198
I have seen this component in different occassions but never found it of interest, basically because of lack of an intuitive interface. Certainly I would like to have special playlist, but my mental hard disk does not feel attracted to learning code, even in the most elemental ways. We, general users, want buttons. Buttons are for that, you do a clic and then you got some results that somebody -the programmer- experienced before and that you can tell are wonderful and use every day. As it is right now is an incomplete component very few persons can use.
Ys
Rozzo
Reply #199
Yes, but it cannot be done automatically. You can get the desired result as follows:
Create 4 pools Funk, Rock, Electro, World with the following settings (all other settings can be kept as they are):
Funk:
Group: %genre%
Filter: genre IS Funk
Number of tracks to add: 10
Rock:
Group: %genre%
Filter: genre IS Rock
Electro:
Group: %genre%
Filter: genre IS Electro
World:
Group: %genre%
Filter: genre IS World
Choose or create an empty playlist with your playlist manager
Execute the following main menu entries:
File -> Random pools -> Funk
File -> Random pools -> Rock
File -> Random pools -> Electro
File -> Random pools -> World
Edit -> Sort -> Randomize
This will create a playlist with 40 entries, 10 randomly selected tracks from each genre, with a random track order
