Topic: Song fingerprinting tools (Read 68702 times) previous topic - next topic
Reply #50
It crashes hard, not with the crash-handler. I figured that your tool correctly ignores regular streams, but the problem I experience is while using foo_mslive to stream wma-audio. foo_biometrics don't see these as streams and tries to fingerprint them. Taking one at a time doesn't make foobar2000 crash, it just waits until it times out or something like that. However, take 5 streams or so at the same time, it will crash after a while.
Did you fix the FLAC-problem?
Reply #51
Not sure if you mean it hangs, or just exits with no error. If it hangs, you can create a dump using Task Manager.
Possibly foo_mslive doesn't handle decoding multiple streams at the same time properly. Don't think I have any special handling for streams etc., I'll try and have a look as you are probably right that it shouldn't bother scanning them.
As far as I could see, it seemed like the floating-point output of the FLAC decoder was different in the two cases. fb2k normally decodes to floating-point, and FooID takes floats as input so I'm not sure that I'm doing anything inherently wrong, unless anyone else has any input.. foo_bitcompare is happy though but I don't know exactly what it does.
Reply #53
I'm a little puzzled about the results (and/or the threshold levels).
Often it finds a similar track (which it should imho) like the instrumental track (from a cdm), a different cut or slightly different version, but at the same time completely ignores some tracks that should be the exact same track just on a different album. Now I tried to lower the threshold to min 50% and the results are mostly the same, except I now get some large groups with completely different songs in them - It seems to easily confuse especially electronic tracks and club mixes that mostly begin with a simple beat.
Can someone clarify?
Reply #54
Can I revive this a bit?
I realize that developer is unavailable, but maybe someone else may shred some light
I downloaded Garf's source library, although C illiterate but out of curiosity
From what I can guess browsing it, I assume that track is downsampled and sliced on fixed number of parts then dominant harmonic is extracted for each part?
I then converted fingerprint hex string:
dec = array([int('0x' + d['FINGERPRINT_FOOID'][x:x+2], 16) for x in xrange(0, 424, 2)])
So splitting the string on every 2nd char, and converting to decimal I get an array. However I can't get any matching between similar tracks, doing standard correlation tests.
I then made histograms of tested arrays with 10 and then 16 bins, doing same simple correlation tests (Pearson, Spearman, Kendall ... ) on histogram values, but again no luck
Any tips from more knowledgeable?
Reply #55
Check the definition of the t_fingerprint structure in common.h:
    fingerprint storage
struct t_fingerprint
        fingerprint version
    short version;
        length in centiseconds
    int length;
        average line fit, times 1000
    short avg_fit;
        average dominant line, times 100
    short avg_dom;
        spectral fits, 4 bits times 16 bands = 32 times 87 frames
        -> 348 bytes
    unsigned char r[348];
        spectral doms, 6 bits times 87 frames = 65.25
    unsigned char dom[66];
The content of this structure is packed into a byte array in fp_calculate function in fooid.c:
    memcpy(buff, &(fi->fp.version), sizeof(short));
    buff += sizeof(short);
    memcpy(buff, &(fi->fp.length), sizeof(int));
    buff += sizeof(int);
    memcpy(buff, &(fi->fp.avg_fit), sizeof(short));
    memcpy(buff, &(fi->fp.avg_dom), sizeof(short));
    memcpy(buff, &(fi->fp.r), sizeof(unsigned char) * 348);
    buff += sizeof(unsigned char) * 348;
    memcpy(buff, &(fi->fp.dom), sizeof(unsigned char) * 66);
    buff += sizeof(unsigned char) * 66;
As you can see different parts of the fingerprint contain different values. If you need more details about the algorithm, you could try to contact Garf. Since he developed FooID during his time at university, he might have written a paper about it.
Reply #56
Thanks foosion  I did so naive...
Can I ask further assistance, as how to decode this structure?
For example, variable `r`, if I convert each "unsigned char" [10:358] to ordinal integer, I don't get expected results (doing correlation), so I assume it's not how it should be done.
In common.h (as quoted nicely) there is equation like: "4 bits times 16 bands = 32 times 87 frames -> 348 bytes" which I can't make sense.
4*87 is 348, so if I divide it (`r`) on 87 frames, I'll get 4 byte values, or?
Reply #57
OK, I get that I should group each 4 bytes in this subsequence, then convert each char to bits, slice in 2 and convert this 4 bits to integer, so that I get 16 bins from each 4bytes. Results aren't satisfactory, still
Nevermind
Reply #58
My previous post is not correct. It may make sense if we decode each character in FOOID tag, but that's just wrong of course, as we have string that actually represent byte stream.
I assume there are 8 (4bit) bands in 4 bytes. There must be a type in the code.
Here is my notebook, which I cleaned a bit now, in case anyone gets similar idea: http://nbviewer.ipython.org/url/dl.dropbox...nb/foo_id.ipynb
Reply #59
According to the code in spectrum.c the r field contains 16 bands per frame, but only 2 bits are used per band.
Reply #60
Thanks foosion. I discarded that idea, because of 2bit capacity
I did again now, and with what I initially thought - cross correlate not values, but histograms - here is for example plot for all 16 bands (same playlist as in example): http://i.imgur.com/9Q3tc.png
It was just silly idea. Things can't work that way.
Coincidentally, just yesterday, I had a tweet about Mel Cepstral Coefficients (MFC). Used for voice recognition, could provide also genre classification. Computing MFC is relatively easy, especially in Python: `import mfcc` , and searching further I found some papers, but related to classification (machine learning), not about track to track comparison, which should be much easier and deduced just by these coefficients, but not there yet.
Reply #61
I remember that Garf talked on IRC about the fingerprint matching algorithm he used on foosic.org. What I don't remember is how he did the matching.
Reply #62
I uploaded some Python source that reads and matches fingerprints here:
http://sjeng.org/ftp/fooid.py
If you have specific questions, I'll try to answer.
The fits data reprents how "flat" or "spiky" the band is, quantized to a value from 0..3.
Reply #63
Thanks Garf.
I tried your suggestion, and here is example result: http://nbviewer.ipython.org/url/dl.dropbox...ynb/fooid.ipynb
It's same playlist as in my previous post. Decoding is done differently, without `struct` module, but results are same which I checked, just in case.
So I assume you know I'm looking for similar tracks, but result doesn't show any candidates. Do you perhaps have further suggestions?
foosion mentioned you may have some paper written for your fingerprinting - is it so, and is it public?
Reply #64
I would say that it's working as intended. Only the exact same song, possibly after having gone through lossy compression etc, should match with high confidence.
If you want to search for similar songs, drop the confidence, investigate a large sample, and have a look at the mutual closest matching ones. But in my experience the songs that are judged close won't really sound so much to a human listener. I think we use different criteria to judge that compared to the ones libfooid measures - even if they're psycho-acoustically very robust.
There are exceptions - you will likely see "live" recordings match the studio ones fairly well.
I have a PowerPoint presentation, but it doesn't go in depth, and it's in Dutch.
Reply #65
romor, are you using Garf's (?) fooid library as is or are you trying to rewrite it in another language? If you're using it as is then you might have run into the same problem I had when I messed around with fooid. It's been nearly a year since I touched the project last time so the details are a bit fuzzy.
The short version
As far as I can tell, fooid has a problem with detecting the start of some songs. This throws off the analysis and the resulting fingerprints are too different to indicate a good match, even when two songs sound the same. In some cases the fingerprints have 0% match even though the songs sound identical. So, it could be that your fingerprint comparison algorithm is actually OK but the fingerprints coming from fooid are bad.
fooid will allways produce fingerprints with 100% match if you compare two identical file-copies of the same song though.
The long version
Line 101 in fooid.c, downloadable from the Google project page, says:
if (fabs(data[(pos * fid->channels) + c]) >= (1.0f/32768.0f - EPSILON))
and as far as I can remember this detects when the intro silence ends and the song starts. As written, that detection threshold is a just single LSB above absolute silence!
In my case this was waaay to sensitive. Most duplicates in my song collection were detected properly but alot of songs were detected as being 0% similiar, even though they were perfectly identical sound-wise. The reason being that the sampling of the song data had started at differnet points in time due to noise exceeding one LSB before the songs started. I worked with nearly noise-less MP3 and FLAC files but I suspect that if one tries to compare let's say recordings of vinyl records with static noise before the song starts, then it's probably quite likely that one would end up with alot more 0% matches.
When I replaced the '1.0f/32768.0f' part with a much higher value (can't remember how much, I tried several different values, the threshold is a value between 0.0 and 1.0) the results were significantly improved: Identical versions of songs (regardless of encoding method) were detected as 95% similiar or better, off-vocal versions of songs compared to their on-vocal versions were detected with around 75% similiarity and everything else fell below 50% similiarity. Don't quote me on the exact numbers but I remember seeing very well defined groups of similiarity values.
After changing the threshold I ran into another problem though: Identical versions of songs with gradually increasing sound level at the intro rather than a well defined start beat would still be detected as 0% identical if the rate of sound level change at the intro was different between the two songs being compared.
I suspect that the threshold detection is the culprit here too. If the volume level change rate during the intro is different, then the song start level is detected at different points in time and the sampling of the song thus starts at different points in time.
Reply #66
Thanks ncmaothvez for you input
I'm not rewriting fooid. I just thought to play with the data provided by foo_biometric, and maybe extract other feature then same song matching. In case I find something interesting I'll be able to provide general script so that any foobar user can use it (in VBS perhaps).
Garf provided some formulas and I haven't tried anything other than that, but will try one of these days
Also MFCC approach should be interesting, and I'll back on that too, as I won't need to scan whole song to calculate MFCC and extract song features, but just couple of samples.
Re: Song fingerprinting tools
Reply #67
Installed Foobar2000 v1.3.11 beta 4 - Failed to load DLL: foo_biometric.dll / Reason: This component is missing a required dependency, or was made for different version of foobar2000.
Reply #68
You need FooID.dll in your foobar2000 program folder. See 1st posting in this thread.
Edit
Um, did you already have the component installed and working before updating foobar2000?
Reply #69
Hmmm, forgot to do that, thanks!
Reply #70
Does anything similar exist today? I'd like to fingerprint all my files and look for albums that are completely duplicated elsewhere (usually in a boxset). If the files can be tagged with a fingerprint I can export to R and do the checking for duplicates there.
I am aware that there are de-duplication programs that can do it but from what I have seen they focus on finding duplicate files. That makes answering the question if the whole album is duplicated difficult...
Reply #71
Playlist tools (my sig) contains tools to calculate FooID or chromaprint for files on batch. Binaries included for both. You can find duplicates with Fooid within foobar with the tools, for Chromaprint in 32 bit there is not enough memory for large libraries.
Anyway once you tag your library if you know how to export the tags and do the checks yourself that would do.
Reply #72
Thanks! I thought fooid was dead but I managed to get it going with the files from your SMP scripts.
