Topic: Foobar2000 (Mobile Edition)  (Read 182277 times) previous topic - next topic
Re: Foobar2000 (Mobile Edition)
Reply #125
Thanks for all the feedback, all feature request have been noted.
I'd like to mention that this week's update for Windows - 1.0.25 - has just gone live. The output is now WASAPI, so all audio quality issues are hopefully gone.
Reply #126
Hi, I just noticed that when there is no "album artist" tag, the album grid looks like this:
Poweramp does not show this problem:
Thank you for your great work.
Edit: I forgot to mention that I'm on Huawei P8 Lite Android 6.0
Reply #127
Thanks. Now I don't need to manually enable the resampler anymore.
Reply #128
And does Lumia's DAC support 44.1 KHz through WASAPI at the same quality as 48 kHz? Or does it play through "WASAPI shared" to 48 kHz hardware sampling rate?
Reply #129
BTW I have it now installed and it works well, even with DSP resamping disabled. Thank you very much for good work!
Reply #130
@lido
If your tracks have no album artist, yet different artists, then you need to have the compilation tag set to 1, this will group all those tracks to the single album. Why does the player not do this automatically? because if you had 'Greatest Hits' (multiple albums) then they will correctly be listed separately, even without album artist set.
Reply #131
As you can see, the compilation tag is set to 1
Reply #132
Is there a feature request list? Would love if the bitrate could be shown.
Reply #133
I still don't get a widget on my Galaxy S3 (Android 4.1)
Reply #135
How do I get album art for my albums in an automatized way?
I converted a bunch of music. Only two have album art after I copied the folder to my phone. (On of them happens to have a folder.jpg or such, the other doesn't but I guess the m4a-s might have album art embedded)
I have album art for most of my music, which I have in a dedicated folder. Both default UI and columns UI is set to find them. So they're readily available. Apparently transfer attached pictures doesn't work in this case, for whatever reason.
I imagine that's what copied the album art for that single album. Although I have no idea where it was transferred. It's not in the folder of the album.
Reply #136
Adding the stuff from that I have set for album art (but replacing the line breaks with ";" of course) to the "copy other files to the destination folder" field doesn't seem to work either.
Reply #137
That is an option to transfer embedded art from the source file in to the destination file.
That only works on files in the source folder.
Reply #138
That's a really unfortunate limitation, in this case.
That's too bad also. I expected foobar to be able to transfer the album-art it's already able to load and show.
Unlike the desktop version there doesn't seem to be a feature to define where to load album art from. So nothing left but copying every single image file one-by one?
Reply #139
Well it's no accident your image files live in an entirely different folder structure away from your audio files. This is something you must have been very conscious of when doing it??? You can hardly bemoan foobar not being able to manage these non-audio files.
Anyway, you could batch attach the art to all files as the dialog supports the same patterns as the artwork preferences OR you could probably knock up a batch file using Copy names on the playlist right click menu. If you don't see it when right clicking, hold Shift first. You can configure the text generated for each playlist entry under File>Preferences>Advanced>Display>Legacy title formatting settings>Copy command. Here you could use the windows copy command with the artwork preferences as the source and the containing folder of the audio file as the destination - $directory_path(%path%).
edit: I'd test this on just a few entries first and limit the playlist to one track per album. A query using tracknumber IS 1 should do.
Reply #140
Naturally. It's the only practical way of having album art. (They're in a single folder though, not a structure)
And why is that? It's a built in feature. It could just as wall copy album art that it already knows where to find and how to load with the "transfer attached picture" option.
Or at least not make the "Copy other files" files feature so crippled to not support absolute paths. That way I could use the stuff I have set in the album art section separated by a ";". It's almost as if hindering copying album art was a goal... :)
Could you elaborate on this? How do you propose I do that? Which dialog? I found nothing in the converter setup that can do this.
I don't know what you mean.
I'll investigate this. Although the last part I don't understand. So I should add stuff to the "copy command" section. But doesn't that just copy text on the clipboard? Also how to handle multiple output folders for all the albums?
Reply #141
"only practical"? :)) Funny how I have zero issues with my album art inside each folder alongside my audio files and when I copy my entire collection to my android phone, it just works with any player app I've tried.
Sane people, like me, are not averse to putting album art in each folder alongside each album. Obviously that's what the current converter options for copying files are for. If you use file operations, you'll also notice it has options to move/copy all non-audio files in all folders that contain your music files. May I remind you of your "only practical" comment?
Highlight files>right click>Tagging>Batch attach pictures and follow the instructions.
Sorry I wasn't more clear. Yes, this puts text on the clipboard. It would be up to you to save it in notepad with a .bat/.cmd extension. You'd be looking at generating text for each entry something like...
copy "source" "destination"
Title formatting here is fully supported so "source" would be your album art pattern and "destination" would be $directory_path(%path%) - which always gives the full path to the containing folder for the current file. Whether this would work or not might depend on you not having an insane filing system which I dare not ask about...
Reply #142
This way I always have the AA appearing without needing to copy it into each and every folder...
Foremost it requires extra work, especially when you have multiple variants of the same album. This way any file, anywhere on the system will have it's album art showing if it's present in the album art folder.
Obviously. Also obviously this feature was ignored or forgotten.
I fail to see while copying couldn't work for an arbitrary folder. Also it could be problematic when you don't have all the albums in separate folders, for whatever reason.
Reply #143
This doesn't seem to work either. It claims the syntax is the same as "Display Preferences", but it isn't.
It won't even allow me to paste all the stuff, only one line. If have have to do this process for every line I'll die of old age (slight exaggeration) before I'm finished.
Enter just starts the process, which is also horrible since it claimed the same syntax one would expect to be able to start a new line in the text field.
There's no hint provided for adding multiple entries, if it's even possible.
My search patterns section is like this:
e:\Album Borítók\%artist% - %album%.png
e:\Album Borítók\%artist% - %album%.jpg
e:\Album Borítók\%artist% - %album%.jpeg
e:\Album Borítók\%album artist% - %album%.png
e:\Album Borítók\%album artist% - %album%.jpg
e:\Album Borítók\%album artist% - %album%.jpeg
Alright, it come to trying this, it seems. What do you mean by insane filing system?
Anyway It looks like something that should work, provided cmd doesn't fail me with non-latin characters as it usually does.
Edit:
On second thought... This would also require me to run it for every entry of the album art section. A new batch file for every one.
Damn. Just can't seem to find a feasible solution...
Reply #144
I've just written a script for the foo_jscript_panel component that could do what you want but it requires any version of windows vista or later. XP/2003 users need not apply.
The one requirement is that the output filename is a constant like cover/front/etc...
Follow the component installation instructions here and add a panel to your layout.
https://github.com/19379/foo-jscript-panel/wiki/Requirements-&-Installation
Now right click the panel>Configure and add this code.
var filename = "cover.jpg"; //Static filename only. Title formatting is NOT SUPPORTED. Must end .jpg
var folder = "$directory_path(%path%)\\";
var fso = new ActiveXObject("Scripting.FileSystemObject");
function on_mouse_lbtn_dblclk() {
var items = plman.GetPlaylistItems(plman.ActivePlaylist);
var count = items.Count;
if (count == 0)
return;
items.OrderByPath();
var current = "";
for (var i = 0; i < count; i++) {
var temp = fb.TitleFormat(folder).EvalWithMetadb(items.Item(i));
if (current != temp) {
current = temp;
var f = current + filename;
var img = utils.GetAlbumArtV2(items.Item(i), 0);
if (img && !fso.FileExists(f))
img.SaveAs(f, "image/jpeg");
fb.ShowPopupMessage("Done!");
It is blank white panel with no UI. Just double click to run and it should popup a message when done. Test on small subset of files first. It may appear foobar is not responding if testing with large collections so be patient and wait.
Because it uses the same core functions as the default artwork panel, you don't need to worry about configuring it with any of your patterns.
Assumptions:
all files you want to process are in the active playlist
one image per destination folder
you don't want to overwrite existing images
Reply #145
Thanks! I'll have a look. (Although some of the album art images are png, which might be a problem)
Reply #146
png files will be saved as jpg no problem. The only issue would be loss of transparency but I'd hope you don't have that in album covers.
edit: just realised the script wil save your stub image if you have one defined, You can prevent that by replacing this line of code...
with
var img = utils.GetAlbumArtV2(items.Item(i), 0, false);
Reply #147
How to sync play-count, rating between phone version and PC version?
Can it be integrated to Last.fm sync???
Thank you!!!!
Reply #148
Thanks for the app. I'm happy to go for a paid version when it comes to the Android/Play store.
I didn't find it at all obvious how to return to the "now playing" screen after backing out of it for any reason. I learned about the horizontal swipe only after reading Peter's usage tips on the foobar2000 forums. This may be a limitation to adoption.
God kills a kitten every time you encode with CBR 320
Reply #149
I just install the app on Win10, but I don't see albumart. On desktop foobar all my albums have albumart (usually cover.jpg) while here I don't see any setting for albumart nor it renders my cover.jpg images.
Any ideas how to get there?
