Topic: Problem in 1.3.9 beta 4: fhgaacenc doesn't work in some cases (Read 7847 times) previous topic - next topic
After updating to 1.3.9b4, I found a problem when converting my files to aac like below.
1 out of 1 tracks converted with major problems.
Source: "D:\Music\일음콜렉션\Onmyouza music\2002 - KOUJIN-RASETSU\09. 組曲 『黒塚』 鬼哭啾々.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\Rip\陰陽座 - 煌神羅刹\09. 組曲 『黒塚』 鬼哭啾々.m4a"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 32bps
  Command line: "C:\Program Files (x86)\foobar2000\encoders\fhgaacenc.exe" --ignorelength --quiet --vbr 2 - "temp-90CAB31026AF876C8A5D5389E95604E1.m4a"
  Working folder: D:\Music\Rip\陰陽座 - 煌神羅刹\
  Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
This problem occurs only when any pre-processing is employed (e.g. replaygain, resampler, etc.).
Presumably no problems with other encoders.
I couldn't replicate the issue. I tried using both ReplayGain processing and Resampler at the same time. Could you see what error code you get with this newer test version of fhgaacenc:
Edit: obsolete attachment removed.
What version of fhgaacenc do you use? Made by tmkk or from fb2k encoder pack?
|vqc|: I use one made by tmkk. After I encountered this issue, I also tested that included in the fb2k encoder pack, but the same result. The test version uploaded by Case works very well.
Case: The newer test version does not produce any problem in 1.3.9b4. Thx for uploading.
Hi, I seem to have the same code error as Joungmin. I have been using the foobar2000 free encoder pack 2015-10-14 and foobar 1.3.8. I also did not use any post processing, though I have tried after and the code still shows.  The test version supplied by Case has worked but I thought I'd mention the problem with the encoder pack. Here is the foobar output after the conversion.
10 out of 12 tracks converted with major problems.
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\01 Vicarious.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\01 Vicarious.m4a"
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "01 Vicarious.m4a"
  Working folder: D:\Music\fhgtest\Tool\10,000 Days\
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\02 Jambi.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\02 Jambi.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "02 Jambi.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\03 Wings for Marie (Pt 1).flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\03 Wings for Marie (Pt 1).m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "03 Wings for Marie (Pt 1).m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\04 10,000 Days (Wings Pt 2).flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\04 10,000 Days (Wings Pt 2).m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "04 10,000 Days (Wings Pt 2).m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\05 The Pot.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\05 The Pot.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "05 The Pot.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\06 Lipan Conjuring.flac"
  Track converted successfully.
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\07 Lost Keys (Blame Hofmann).flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\07 Lost Keys (Blame Hofmann).m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "07 Lost Keys (Blame Hofmann).m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\08 Rosetta Stoned.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\08 Rosetta Stoned.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "08 Rosetta Stoned.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\09 Intension.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\09 Intension.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "09 Intension.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\10 Right in Two.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\10 Right in Two.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "10 Right in Two.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\11 Viginti Tres.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\Music\fhgtest\Tool\10,000 Days\11 Viginti Tres.m4a"
  Command line: "C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe" --ignorelength --quiet --vbr 5 - "11 Viginti Tres.m4a"
Source: "D:\Music\Lossless\Personal\Tool\10,000 Days\Folder.jpg"
  Copied to: D:\Music\fhgtest\Tool\10,000 Days\Folder.jpg
Are you sure you are using the encoder from the latest Free Encoder Pack? It was installed in foobar2000\encoders dir and your path is something else. Also it will return error code 0 only if encoding worked succesfully or it's started without parameters where it prints help text.
You can check the fhgaacenc version by running it in command prompt without parameters. It will print the version string on top of the usage info. The latest and greatest will print "fhgaacenc version 20120624 by tmkk. Modified by Case 20151011." A quick check of the size of C:\Users\Phil\Music\Tools\fhgaacenc-fooenc\fhgaacenc.exe will also be enough. If the file isn't 22 KB in size it isn't from the latest pack.
Note that if you do copy the encoder binaries around please copy the nsutil.dll file too. It allows the FhG encoder to get 32-bit floating point data so you don't have to worry about source files clipping.
I have extracted the fhgaacenc.exe and nsutil.dll from the pack.exe to my own directory using 7-zip so I can keep track of all the encoders I have. I thought this might have been a problem so I installed it to the default foobar dir and same error came up. I have checked the file size, it is 22 KB. Oh i also copied libmp4v2.dll and enc_fhgaac.dll as normal. I have noticed I did not have this problem with the previous encoder pack.
I can't replicate scenario where encoding would fail. I have tested Windows versions from XP to 10 and both installed Winamp instance and putting the required dlls in the encoder dir. Would you be so kind to generate a Process Monitor log of this problem? Please compress the log with zip, 7-zip or rar before uploading to make it smaller. It should be enough to limit the log to foobar2000 and all its sub-processes.
Thanks for the log. Unfortunately it has info only from foobar2000, not from any of the child processes. Easiest way to include all that info is to use Tools menu, click Process Tree, select foobar2000 and click Include Subtree.
Thanks for the log and the bug report. I believe I tracked down the problem and would appreciate if you could test the attached version.
I am pleased to say that your new build has fixed the errors that I have experienced before! However I am getting a new error, it seems to only happen every other third or fourth conversion and would only happen to a couple songs. It is the "Object not found" error. I have pasted the log that shows the 27th silent track being affected, while the other time the 60th silent track was affected.
1 out of 112 tracks converted with major problems.
Source: "D:\Music\Lossless\Personal\Tool\Undertow\01 Intolerance.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\02 Prison Sex.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\03 Sober.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\04 Bottom.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\05 Crawl Away.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\06 Swamp Song.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\07 Undertow.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\08 4°.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\09 Flood.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\10 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\11 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\12 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\13 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\14 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\15 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\16 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\17 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\18 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\19 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\20 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\21 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\22 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\23 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\24 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\25 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\26 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\27 Silent Track.flac"
  An error occurred while finalizing the encoding process (Object not found) : "D:\Music\fhgtest\Tool\Tool\Undertow\27 Silent Track.m4a"
  Conversion failed: Object not found
Source: "D:\Music\Lossless\Personal\Tool\Undertow\28 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\29 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\30 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\31 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\32 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\33 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\34 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\35 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\36 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\37 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\38 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\39 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\40 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\41 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\42 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\43 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\44 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\45 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\46 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\47 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\48 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\49 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\50 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\51 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\52 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\53 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\54 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\55 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\56 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\57 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\58 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\59 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\60 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\61 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\62 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\63 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\64 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\65 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\66 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\67 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\68 Silent Track.flac"
Source: "D:\Music\Lossless\Personal\Tool\Undertow\69 Disgustipated.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\01 Stinkfist.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\02 Eulogy.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\03 H..flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\04 Useful Idiot.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\05 Forty Six & 2.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\06 Message to Harry Manback.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\07 Hooker with a Penis.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\08 Intermission.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\09 jimmy.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\10 Die Eier von Satan.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\11 Pushit.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\12 Cesaro Summability.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\13 Ænema.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\14 (-) Ions.flac"
Source: "D:\Music\Lossless\Personal\Tool\Ænima\15 Third Eye.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\01 The Grudge.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\02 Eon Blue Apocalypse.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\03 The Patient.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\04 Mantra.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\05 Schism.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\06 Parabol.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\07 Parabola.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\08 Ticks & Leeches.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\09 Lateralus.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\10 Disposition.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\11 Reflection.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\12 Triad.flac"
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\13 Faaip de Oiad.flac"
  Copied to: D:\Music\fhgtest\Tool\Tool\10,000 Days\Folder.jpg
Source: "D:\Music\Lossless\Personal\Tool\Lateralus\Folder.jpg"
  Copied to: D:\Music\fhgtest\Tool\Tool\Lateralus\Folder.jpg
Source: "D:\Music\Lossless\Personal\Tool\Undertow\Folder.png"
  Copied to: D:\Music\fhgtest\Tool\Tool\Undertow\Folder.png
Source: "D:\Music\Lossless\Personal\Tool\Ænima\Folder.jpg"
  Copied to: D:\Music\fhgtest\Tool\Tool\Ænima\Folder.jpg
Interesting find. Those one second long tracks get encoded so fast that the temporary file used with enc_fhgaac.dll gets taken by another encoder instance when the first one deletes it temporarily. Attached version is free from this problem.
[attachment=8445:fhgaacen...51024_v2.zip]
No more errors, thank you very much Case!
[attachment:fhgaacen...51024_v2.zip]
Hello Case,
First I want to thank you for maintaining the fhgaacencoder. Would it be possible to make your version of fhgaacenc available at RareWares ?. I assume you have posted the latest version in this thread. There is also another thread where you have posted several version of fhgaacenc.
Hosting fhgaacenc at RareWares would simplify getting the latest version instead of searching through multiple threads.
Greetz
Hello Case,
Greetz
Thanks again Case.
His version is maintained and updated here: https://www.foobar2000.org/encoderpack
I have a question on fhgaacenc and did not want to start a new topic, so I've piggy-backed onto this one.
fhgaacenc adds two tags to an encoded file: 'object description' and 'scene description'.  Is there a command line
switch to suppress these two tags, which don't get generated with either qaac or fdkaac?  Here is the MediaInfo info
text.  Thanks.
General
Complete name                            : C:\mp3temp\8½ Souvenirs - After You've Gone.m4a
Format                                  : MPEG-4
Format profile                          : Base Media / Version 2
Codec ID                                : mp42 (mp42/isom)
File size                                : 3.61 MiB
Duration                                : 3mn 52s
Overall bit rate mode                    : Variable
Overall bit rate                        : 130 Kbps
Album                                    : Happy Feet
Track name                              : After You've Gone
Track name/Position                      : 9
Performer                                : 8½ Souvenirs
Recorded date                            : 1998
Encoded date                            : UTC 2015-12-02 17:17:05
Tagged date                              : UTC 2015-12-02 17:17:10
Writing application                      : fhgaac v03.02.16;VBR=4
Cover                                    : Yes
Audio
Format                                  : AAC
Format/Info                              : Advanced Audio Codec
Format profile                          : LC
Codec ID                                : 40
Duration                                : 3mn 52s
Bit rate mode                            : Variable
Bit rate                                : 128 Kbps
Maximum bit rate                        : 154 Kbps
Channel(s)                              : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Frame rate                              : 43.066 fps (1024 spf)
Compression mode                        : Lossy
Stream size                              : 3.56 MiB (98%)
Language                                : English
Other #1
Type                                    : Object description
Format                                  : System
Codec ID                                : 1
Duration                                : 3mn 52s
Language                                : English
Encoded date                            : UTC 2015-12-02 17:17:10
Other #2
Type                                    : Scene description
Format                                  : System Core
Codec ID                                : 2
Duration                                : 3mn 52s
Language                                : English
Menu
00:00:00.036                            : After You've Gone
fhgaacenc is just a frontend to the FhG encoder bundled with Winamp. The MP4 file and any tags in it are created by enc_fhgaac.dll. What is the problem with the extra information in the file?
