On another forum a member made the claim that LAME encoded MP3s can create clipping where non-exists in the FLAC. This seemed pretty dubious to me, but he was able to back it up with some evidence. I was curious if this was common knowledge, or if anyone else had replicated this before. This was in a metal discussion forum, so we're talking about recordings that are pretty badly brickwalled to begin with, but according to DR don't clip. Here's his post:
Depending on the mastering of course modern recordings will sound better on LP than a lossy format; they preserve the soundstage and don't clip. A record like the FDR reissue of Bolt Thrower's Realm of Chaos which sounds great on CD and LP (same mastering) is way worse on MP3 as it causes clipping in every track. It's not completely clipped but it's still there and you can still tell if you know the record like the back of your hand. Not even going to get into soundstage and instrument separation. The quantization noise (distortion) caused by any codec randomly changes the peaks which can cause clipping if they are close to the limit. Thus you can master a release that sounds excellent lossless and like shit lossy. Modern recordings are much worse.
Here is an experiment I did this afternoon:
Bolt Thrower's Realm of Chaos, 2012 FDR CD
Not the best recorded album but decently mixed and mastered. The remastered 2012 CD is the best sounding version.
CD/FLAC DR meter results:
foobar2000 1.3.7 / Dynamic Range Meter 1.1.1
log date: 2015-03-25 01:02:08
Analyzed: Bolt Thrower / Realm of Chaos
DR Peak RMS Duration Track
DR9 -2.27 dB -15.03 dB 1:18 01-Intro
DR10 -0.10 dB -11.31 dB 2:07 02-Eternal War
DR11 -0.10 dB -12.28 dB 4:21 03-Through The Eye Of Terror
DR10 -0.10 dB -10.68 dB 2:58 04-Dark Millenium
DR10 -0.10 dB -10.92 dB 4:36 05-All That Remains
DR11 -0.10 dB -11.66 dB 4:11 06-Lost Souls Domain
DR10 -0.10 dB -11.20 dB 2:52 07-Plague Bearer
DR11 -0.10 dB -11.71 dB 4:55 08-World Eater
DR10 -0.10 dB -11.40 dB 3:03 09-Drowned In Torment
DR9 -0.10 dB -10.64 dB 2:49 10-Realm Of Chaos
DR9 -0.10 dB -10.57 dB 3:52 11-Prophet Of Hatred
DR9 -2.56 dB -18.25 dB 1:00 12-Outro
Number of tracks: 12
Official DR value: DR10
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 16
Bitrate: 457 kbps
Codec: FLAC
V0:foobar2000 1.3.8 / Dynamic Range Meter 1.1.1
log date: 2015-04-04 13:47:44
DR9 -2.29 dB -15.03 dB 1:18 01-Intro
DR10 0.00 dB -11.30 dB 2:07 02-Eternal War
DR11 0.00 dB -12.28 dB 4:21 03-Through The Eye Of Terror
DR10 0.00 dB -10.68 dB 2:58 04-Dark Millenium
DR10 0.00 dB -10.92 dB 4:36 05-All That Remains
DR11 0.00 dB -11.66 dB 4:11 06-Lost Souls Domain
DR10 0.00 dB -11.20 dB 2:52 07-Plague Bearer
DR11 0.00 dB -11.71 dB 4:55 08-World Eater
DR10 0.00 dB -11.40 dB 3:03 09-Drowned In Torment
DR9 0.00 dB -10.63 dB 2:49 10-Realm Of Chaos
DR9 0.00 dB -10.57 dB 3:52 11-Prophet Of Hatred
Channels: 2
Bitrate: 213 kbps
Codec: MP3
As we can see the codec clips every track but lets take a look at the waveform.
CD/FLAC lossless waveform of Plague Bearer
![](http://i.imgur.com/objWFzW.png)
MP3 V0
![](http://i.imgur.com/ouYTUOq.png)
Some clipped samples and it sounds worse of course but not the complete end of the world.
Now lets look at a more modern recording, Dead Congregation's Promulgation of the Fall. It was well recorded but undermixed and poorly mastered but thankfully not clipped. This isn't even close to the worst for modern metal; it's no Death Magnetic or The Flesh Prevails.
log date: 2015-04-04 14:36:10
Analyzed: Dead Congregation / Promulgation of the Fall
DR5 -0.10 dB -6.12 dB 5:13 01-Only Ashes Remain
DR6 -0.10 dB -7.32 dB 3:40 02-Promulgation of the Fall
DR6 -0.10 dB -6.25 dB 5:33 03-Serpentskin
DR6 -0.10 dB -6.65 dB 4:15 04-Quintessence Maligned
DR5 -0.10 dB -6.17 dB 5:08 05-Immaculate Poison
DR5 -0.10 dB -6.15 dB 5:00 06-Nigredo
DR5 -0.10 dB -6.40 dB 7:18 07-Schisma
DR5 -0.10 dB -6.28 dB 3:57 08-From a Wretched Womb
Number of tracks: 8
Official DR value: DR5
Channels: 2
Bits per sample: 16
Bitrate: 975 kbps
Codec: FLAC
MP3 V0:
log date: 2015-04-04 15:13:13
DR6 0.00 dB -6.12 dB 5:13 01-Only Ashes Remain
DR6 0.00 dB -7.32 dB 3:40 02-Promulgation of the Fall
DR6 0.00 dB -6.19 dB 5:33 03-Serpentskin
DR6 0.00 dB -6.65 dB 4:15 04-Quintessence Maligned
DR6 0.00 dB -6.17 dB 5:08 05-Immaculate Poison
DR5 0.00 dB -6.14 dB 5:00 06-Nigredo
DR5 0.00 dB -6.40 dB 7:18 07-Schisma
DR6 0.00 dB -6.28 dB 3:57 08-From a Wretched Womb
Number of tracks: 8
Official DR value: DR6
Channels: 2
Bitrate: 265 kbps
Codec: MP3
Once again the codec clips every track. Onto an example waveform.
CD/FLAC lossless waveform of Only Ashes Remain
![](http://i.imgur.com/HBp8xUw.png)
MP3 V0 lossy
![](http://i.imgur.com/Fu2GKGv.png)
LAME TOOK A DUMP ALL OVER THE RECORDING'S FACE.
[a href="http://imgur.com/a/tknik" rel="nofollow"]Link to imgur album.[/a]
Now, to me that seems like pretty compelling evidence but it's possible I'm missing something. The only piece of information I'm really curious about is what LAME encoder he's using, but I'm pretty sure it's going to be at least 3.98r.
Has anyone seen anything like this before? What would account for the massive clipping that's going on and the changes in Dynamic Range peaks? If the peak changes, why wouldn't the RMS as well?
