I'm trying to use foo_run for setting keyboard shortcuts to apply ratings with foo_quicktag but I don't know what the parameters are. Here's what doesn't work:
(keep in mind i'm using linux, hence the wine; as this is the only way to set global shortcuts)
wine "/home/jj/.wine/drive_c/Program Files (x86)/foobar2000/foobar2000.exe" /runcmd="1"
wine "/home/jj/.wine/drive_c/Program Files (x86)/foobar2000/foobar2000.exe" /runcmd="/1"
wine "/home/jj/.wine/drive_c/Program Files (x86)/foobar2000/foobar2000.exe" /runcmd="//1"
wine "/home/jj/.wine/drive_c/Program Files (x86)/foobar2000/foobar2000.exe" /runcmd="///1"
through Foobar2000's keyboard it's nested under:
[context] / Tagging / Quick Tagger / Set <Rating> to / 1
here's an image, from thsi I can't even tell what's the parameters to set a specific rating #
![](http://s4.postimg.org/h5zmq8971/foobarkeyboard.jpg)
**UPDATE**
The proper way to find out the command parameters for foo_run is through "Right-Click Selection(s) > Run Command... Dialog Window" like so:
![](http://s8.postimg.org/ijsn7opvp/foobarkeyboard2.jpg)
