Topic: Discussion of "Default UI Gallery" (Read 388363 times) previous topic - next topic
Reply #575
Damn that sucks.
possible only if all the panels were WSH Panel Mod  but not only selection and highlight colors are to change, because what happen if the main album color is similar to the other panel background ? you won't se anymore the selection or highlight...
True, but you could just make it use hue with full saturation. If you have a dark background like mine it would work.
Reply #576
Hey there! I like the looks of this UI: http://customize.org/foobar/skins/65153. But am new to this foobar "skinning". Can you guys/girls please advise whether or not downloading that skin is safe or perhaps not. Because I haven't got the slightest clue what is mainstream to fb2k skinning and what is considered balancing on edge. I do understand foo is customizable because of it's core modular setup. But he only piece of software I can write and understand is a DOS batch-file.
(oh and english not my native, sorry for sounding stupid - I do try my best)
Reply #578
Not a very fancy design, but well suited for my needs. I just love the flexibility of foobar2000! In the toolbar i have buttons for Open CD (rarely used, i rip with Cueripper), Convert to m4a (qaac), replaygain buttons, buttons for syncing my Sony walkman, and a button for fb2k preferences.
How can the buttons be edited/added?
Reply #579
Right click on the toolbar (buttons), Customize Buttons...
Choose from Available Commands on the right, and Add. Choose layout and icons on the left.
Reply #580
Here's mine, Have been discovering solarized & love it's muted Palette. This is my first try well other than using defaults.
A question is there a way to change the colour of the  font  for  highlighted text
https://i.imgur.com/Kp5iuIg.jpg
Reply #581
I think you want prefs>DUI>Colors + Fonts>Top text color item
DJAtrac - http://www.hydrogenaudio.org/forums/index....mp;#entry851721
Is this large display WSH?
can anyone share?
Reply #582
My current layout, simple, nothing complicated
But i came with a question and don't know where to post it so here it is:
Reply #583
Nobody knows how the set the added music folder as first folder in Library View???
Reply #585
you can add your own buttons (right click>customise buttons). then use the change icon button to browse for your own .ico files. IIRC, they must contain a 16x16 image.
Reply #586
Oh wow, you're right, I use it so plain that I completely forgot you can do that  Thanks.
Reply #587
Hotsoup, can you share this one http://www.hydrogenaud.io/forums/index.php...st&p=873324 ?
Also, how did you put these icons there?
Hi eahm, I think this is the last export of that theme: https://googledrive.com/host/0B0v92OYo7i-6Y...E/new_home5.fth
I recently made a playlist view that is tailored for classical music tags but that would be the only thing missing..
Like marc2003 said, all my custom icons range from 16px to 32px. I found them mainly through softicons and iconfinder.
Besides the very top buttons, the rest are "bottom-docked" which you have to checkmark in layout editing mode. HTH
Reply #588
Hotsoup, thanks, got most of it done, can you please list your components?
I don't even know if I can switch from my setup but I want to try to make it fully working and see how it works for few days before I can keep it. All I can say is that your setup is the best I've seen in a while.
Also, I have a ton of classical (like 400GB) and I am copying your renaming (Last name, First name (Nationality) (Year)).
Reply #589
Thanks, and you're welcome! I'll post my plugins/components when I get home from work today.
Reply #590
Current components (not all are necessarily needed for this theme)
Core (2013-12-27 11:08:12 UTC)	    foobar2000 core 1.3
foo_abx.dll (2012-02-26 22:32:36 UTC)     ABX Comparator 1.3.4
foo_albumlist.dll (2013-12-27 10:57:38 UTC)     Album List 4.5
foo_bitcompare.dll (2012-10-14 20:23:15 UTC)     Binary Comparator 1.2
foo_bpm.dll (2014-06-25 00:42:53 UTC)     BPM Analyser 0.2.4.6
foo_burninate.dll (2013-08-06 00:31:15 UTC)     Audio CD Writer 3.0.3
foo_cdda.dll (2013-12-27 10:57:10 UTC)     CD Audio Decoder 3.0
foo_converter.dll (2013-12-27 10:56:52 UTC)     Converter 1.5
foo_DeleteCurrent.dll (2012-06-13 03:55:43 UTC)     FooBar2000 Delete Current Track 1.0.0.0
foo_dsp_bs2b.dll (2011-04-27 02:04:58 UTC)     bs2b 3.1.0
foo_dsp_deemph.dll (2014-06-25 00:43:03 UTC)     De-emphasis DSP filter 0.1.0
foo_dsp_effect.dll (2014-02-12 05:09:28 UTC)     Effect DSP 0.12
foo_dsp_eq.dll (2013-12-27 10:58:06 UTC)     Equalizer 1.0
foo_dsp_resampler.dll (2011-10-19 03:39:55 UTC)     SoX Resampler 0.7.0
foo_dsp_std.dll (2013-12-27 10:57:46 UTC)     Standard DSP Array 1.3
foo_dynamic_range.dll (2012-02-29 03:30:18 UTC)     Dynamic Range Meter 1.1.1
foo_fileops.dll (2013-12-27 10:53:04 UTC)     File Operations 2.2
foo_freedb2.dll (2013-12-27 10:52:32 UTC)     Online Tagger 0.7
foo_input_dvda.dll (2013-02-10 18:49:33 UTC)     DVD-Audio Decoder and Watermark Detector 0.4.11
foo_input_monkey.dll (2014-06-25 00:42:53 UTC)     Monkey's Audio Decoder 2.1.7
foo_input_std.dll (2013-12-27 11:08:14 UTC)     Standard Input Array 1.0
foo_masstag.dll (2009-09-18 18:01:36 UTC)     Masstagger 1.8.4
foo_musical_spectrum.dll (2013-08-21 00:23:43 UTC)     Musical Spectrum 0.9.1
foo_out_wasapi.dll (2014-06-25 00:42:53 UTC)     WASAPI output support 3.2.3
foo_rgscan.dll (2013-12-27 10:55:34 UTC)     ReplayGain Scanner 2.2
foo_simplaylist.dll (2014-04-19 21:52:25 UTC)     SimPlaylist 1.0
foo_texttools.dll (2012-12-31 16:42:24 UTC)     Text Tools 1.0.5
foo_ui_std.dll (2013-12-27 11:08:12 UTC)     Default User Interface 0.9.5
foo_unpack.dll (2013-12-27 10:54:24 UTC)     ZIP/GZIP/RAR Reader 1.6
foo_upnp.dll (2014-06-25 00:42:53 UTC)     UPnP/DLNA Renderer, Server, Control Point 0.99.48
foo_verifier.dll (2014-06-25 00:42:53 UTC)     File Integrity Verifier 1.1.1
foo_vst.dll (2014-07-13 19:13:28 UTC)     VST 2.4 adapter 0.9.0.3
foo_wave_seekbar.dll (2014-04-30 23:22:15 UTC)     Waveform seekbar 0.2.45
foo_youtube.dll (2014-08-13 13:00:43 UTC)     Youtube Source 1.1
Reply #591
Thanks Hotsoup, I'll start modifying again Monday evening when I come back from a quick vacation.
Reply #592
I saw your screenshots eahm, lookin' good! I like how your default theme features the lyrics. I'm inspired now to find a way to squeeze that in..
Reply #593
Yes for the Lyrics but I like it even more how it's setup with your theme modified, in a different tab so I check it only when I care to
Reply #594
my final layout
Left side library, center for playlists, right for now playing.
I would like to neaten the now playing metadata display with Artist, Title, Album only, but I don't know how so that'll suffice.
More stars in the universe than grains of beach sand
Reply #595
Weird question, why is my theme.fth 3.83 KB and the one I modified from Hotsoup 642 KB?
...ohh, the icons maybe?
Reply #596
Once the layout editing "clicks" it's surprisingly flexible and fun to goof around with. At first it was only a variation of the quick setup album list + properties (tabbed), which was my standard for a long time. Then I totally fell down the rabbit hole....
Reply #597
Trying to switch to DUI maintaining functionality of my UI. Still WIP, but I like the result so far.
can you share?I like it very much, please ^^^^^^……………………
Reply #599
It's still work in progress, I still have to fix couple of issues here and there, but I'll put it up somewhere for download once I'm happy with it
