Topic: ABR different filesize for each execution (Read 11283 times) previous topic - next topic
all the configuration i can see in avidemux about audio encoder are these:
What makes you think the difference is in the MP3 audio portion of the video and not the DivX video encoding?
avidemux presents various output mode for both video and audio. If i do use audio: "copy" i get identical output file, but if i use audio: "lame", i get these differences
What's the audio codec used for "copy"?
You just showed us how decoded WAV files (which have not been through that encoder) have this problem too.  Therefore, it is not the encoder, but rather the decoder that is the problem.
Check and see if there are settings for the decoder.  If there aren't, either live with it or get different software.
no, wait, what i've done is to take the output converted with lame, then reconverted in wav and compared it. maybe that's is a nonsense thing.
but if I also use "output: vorbis" i get identical files, so this means that the problem is LAME related for sure
Reply #33
Isn't it much more common to use AAC for audio encoding with video? At a bitrate like 128 kbps you should get noticeably better sound quality than with LAME.
Reply #34
Yes, that is a useless thing to do, and not what I was asking about.
How are you determining that the files are identical?
Reply #35
That’s true in some cases but not really relevant here.
What output? Did you do this once for each of two identical ABR files? And how, as saratoga just asked, are you comparing it?
Have you paid attention to our warnings that file size alone is not a sufficient indicator of identity?
Or, assuming you aren’t invalidating the comparison by not properly controlling it, maybe your frontend is just doing weird stuff in the background only when LAME is selected.
Do me a favour: Take lame.exe, preferably the one from your frontend if available, use it on its own, encode the same file twice consecutively with identical settings, and tell us whether it produces actual differences in the output data (not just the file sizes) when used in isolation.
For me, the lame.exe I have here does not:
C:\Program Files (x86)\foobar2000>lame --abr 128 "C:\Program Files (x86)\foobar2
000\02-140412_1112.wav" c:\users\eprirjgsdgrjj\desktop\1.mp3
LAME 3.99.5 64bits (http://lame.sf.net)
CPU features: SSE (ASM used), SSE2 (ASM used)
Using polyphase lowpass filter, transition band: 20323 Hz - 20903 Hz
Encoding C:\Program Files (x86)\foobar2000\02-140412_1112.wav
      to c:\users\eprirjgsdgrjj\desktop\1.mp3
Encoding as 48 kHz single-ch MPEG-1 Layer III (6x) average 128 kbps qval=3
    Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
  289/289  (100%)|    0:00/    0:00|    0:00/    0:00|  46.240x|    0:00
 32 [  1] *
 40 [  0]
 48 [  0]
 56 [  0]
 64 [  0]
 80 [  0]
 96 [  0]
112 [129] ********************************************************
128 [159] *********************************************************************
160 [  0]
192 [  0]
224 [  0]
256 [  0]
320 [  0]
  kbps      mono %    long  %
  120.5      100.0      100.0
Writing LAME Tag...done
ReplayGain: +64.8dB
WARNING: ReplayGain exceeds the -51dB to +51dB range. Such a result is too
        high to be stored in the header.
000\02-140412_1112.wav" c:\users\eprirjgsdgrjj\desktop\2.mp3
      to c:\users\eprirjgsdgrjj\desktop\2.mp3
  289/289  (100%)|    0:00/    0:00|    0:00/    0:00|  63.055x|    0:00
 32 [  1] *
 40 [  0]
 48 [  0]
 56 [  0]
 64 [  0]
 80 [  0]
 96 [  0]
160 [  0]
192 [  0]
224 [  0]
256 [  0]
320 [  0]
  kbps      mono %    long  %
  120.5      100.0      100.0
ReplayGain: +64.8dB
C:\Program Files (x86)\foobar2000>cd \users\eprirjgsdgrjj\desktop
C:\Users\eprirjgsdgrjj\Desktop>fc /b 1.mp3 2.mp3
Comparing files 1.mp3 and 2.MP3
FC: no differences encountered
(The input file is a nonsensical signal, but I assume that should not make any difference.)
Reply #37
yeah, i've already considered it but something else told me that to get a good AAC I need a good encoder and FAAC and LAV which are the AAC encoders used in  avidemux are not good.
plus AAC is less compatible than MP3, maybe AAC is more used in mkv.
Reply #38
[snipping pointless full quote—db1989]
1) I've taken the video master source ed encoded 2 times with the same setting output1.avi and output2.avi using lame abr as audio encoder, then I have extracted audio track from both the output ed encoded in a wave stream, then compared them with windiff.
2) yes, I know that it's not enough that both the file are with the same size to be identical, but in some cases I could be pretty sure that they are identical (wrongly) because it's highly improbable that the encoder produce the exact size, so I do it optimistically.
3) i already done encoding two times the file directly with lame.exe with "-V 128" field but in this case both the output are identical (with windiff)
Reply #39
-V invokes VBR, not ABR.
Anyway, I still think this is an issue of, and a question for, the developer(s) of your video-converting front-end, not LAME.
Reply #40
tried with also --abr, and it's the same. I should try with libADM_ae_lame.dll which is the lame encoder that uses avidemux. Or maybe to know which parameter avidemux uses to encode the audio with lame.
Do you know how to use dithering? I can try lame.exe using it. to know if produces the same issue
Yes, but the avidemux developers are not easy to be reachable.
Reply #41
LAME cannot perform dithering. It wouldn’t make sense in that context: dither is used to mask quantisation distortion resulting from fixed-point encoding, but MP3 has no inherent bit depth.
Anyhow, dither is a standard feature of basically any audio editor, DAW, and so on. But I don’t think you need to worry about testing as it should indeed produce different output each time – because, again, it should be a completely* random* process. (*Insert huge mimed inverted commas here!)
By all signs, as far as I can tell, avidemux is doing something especially while sending audio to LAME, which is does not do for uncompressed or other lossy output.
Reply #42
If i haven't done anything wrong when decoding the files (I used VLC), there is a problem of audio offset in the videos you posted.
pr2 audio starts before than pr1 audio, and due to this, audio in pr1 is cut too soon.
After cutting and correcting offset, and verifying all things, both audio files are different. I doesn't seem a problem of dither.
Reply #43
for me they looks like identical in starting and finishing when I do play them.
Reply #44
that's ridiculous, i've encoded the file 15 times sequentially, and i got 15 different files, different are like this:
Reply #45
And what did you expect? That it would only produce a few different versions and then cycle through them, sometimes being identical in some pairs? Of course not because, yet again, whatever is causing this, it’s random. And we’ve shown that it’s not LAME.
