Topic: New Public Multiformat Listening Test (Jan 2014) (Read 150516 times) previous topic - next topic
Reply #250
IMHO, it doesn't make sense, to tune the settings for selected samples. Determining comparable encoder settings and selecting samples should be done independant from each other. Take your whole music collection to find matching encoder settings.
Reply #251
What exactly collection - classical, pop, electronic, folk, jazz ... ? If all, in what proportion?
keeping audio clear together - soundexpert.org
Reply #252
Everything in your reach.
Reply #253
1679 lossless tracks, biased towards metal and folk. Bitrates as reported by foobar2000.
Opus libopus 1.1, --bitrate 96
Average bitrate: 100 kbps
Standard deviation: 9.7 kbps
Apple CoreAudioToolbox 7.9.8.3, TVBR 45
Average bitrate: 93 kbps
Standard deviation: 12.6 kbps
Vorbis BS; Lancer(SSE3MT) [20061110] (based on aoTuV b5 [20061024]), -q 2
Average bitrate: 92 kbps
Standard deviation: 7.4 kbps
Opus seems to use above-average bitrates on folk music with highly tonal components (e.g. accordion).
Apple drops bitrates significantly on lo-fi material (e.g. old recordings with low bandwith and/or mono only).
I hope I'm using the correct versions. Opus and Vorbis are the ones from foobar's "Free Encoder Pack 2013-12-06".
Reply #254
Robert,
What would be your suggestion which version of LAME to use in test? A stable 3.99.5, 3.100 or some of  a halb27's extensions?
Thank You.
Reply #255
Gecko,
as I've already posted here
Opus 1.1@96k has the same bitrate as Apple CVBR 96. approx. 100 kbps.
In the other hand, Apple TVBR 45 is ~94 kbps...
Opus has a few kbits higher bitrate than TVBR 45.
Can You try 92k (or some other values) for Opus?
Oh, and You use an old version of aoTuv b5.  Current version is b6.03. http://www.geocities.jp/aoyoume/aotuv/
Encoder http://www.geocities.jp/aoyoume/aotuv/binary/aoTuV_b6.03.zip
Today I will update the table of bitrate reports
Reply #256
From those listed, I guess version 3.99.5 is the one most people (especially outside from HA) have an idea about, and can be used as a reference point for interpretation.
Reply #257
Then it will be LAME 3.99.5 -V 5 unless there're some other suggestins.
Seems like most of people agree with it here.
I like the lame 3.99.5 -V5, even if the bitrate is slightly less than 128. It's the version used by many people. Or CBR 128kbps.
Also vote for -V5, looks like higher bitrates will make the test too hard for listeners. And yes, -V5 is popular.
Reply #258
I'd be happier if you have the result of Apple CVBR 96, Opus 92, 97, and Vorbis 1.99, 2, 2.4, 2.5.
Reply #259
Guys,
Kamedo2 will pick a bitrate reports of users.
Reply #260
I noticed that Opus shows "inverted" behavior - for complex and saturated music it uses less bits than for minimalistic one. For --bitrate 93:
[blockquote]Prodigy - 96.6 kbit/s
Shpongle - 101.4 kbit/s
Schnittke - 104.8 kbit/s
    [/blockquote]
Reply #261
Those who have a empty cell are recommended to report more to fill the space.
And lvqcl and halb27, how many tracks did you used? (Sorry If I had missed something)
Reply #262
Plan A:
TVBR 45
Opus 91
Vorbis q2
Plan B:
CVBR 96
Opus 94
Vorbis q2
I like the Plan B. The plan B is quite close to what's really used.
Reply #263
It will be better to report a real bitrates (filesize/duration). I see the difference is ~ 2 kbps because of  different container overheads.
Reply #264
You are using too many tracks and it is slowing down the entire process. I'd be happier if you pick 50 tracks randomly and quickly fill the blank in the table.
Reply #265
Winamp FhG V3: 105 kbps
FDK V3: 106
aotuv -q 1.99: 91.6
Opus 92, 97, aotuv 2.4 - will test later
# of tracks: 86
Reply #266
I think there is no need to include a bitrate for codecs those won't be tested.
The list of codecs to test:
1.   LAME 3.99.5 -V 5
2.   Apple AAC
3.   Opus 1.1
4.   Vorbis aoTuV
+middle-low anchor FAAC 96 kbps *1
+low anchor ...
Reply #267
OK, will do. Should I worry about stripping the tags?
Yes, aoTuV encode took 1 1/4 hours. I'm working on a reduced but representative set. However this will take some time.
Reply #268
hehe.
No, it's already hair splitting. Plus we store music with tags in real world.
Reply #269
aotuv -q 2.4: 103 kbps
opus 92: 94.7 kbps
opus 97: 99.8 kbps
Reply #270
Thank you for providing the useful data.
Reply #271
opus 94: 96.8 kbps
Reply #272
Reply #273
100 tracks
edit:
kbps as: totalsize [bytes] / duration [sec] / 1024 * 8
kbps as: totalsize [bytes] / duration [sec] / 1000 * 8
Apple CoreAudioToolbox 7.9.8.3, CVBR 96: 98.6 101.0
Apple CoreAudioToolbox 7.9.8.3, TVBR 45: 91.6 93.8 (foobar: 92; 1679 tracks: 91.4 93.6)
FhG Winamp, vbr 3: 102.8
Opus libopus 1.1, --bitrate 92: 94.4 96.6
Opus libopus 1.1, --bitrate 94: 96.3 98.6
Opus libopus 1.1, --bitrate 96: 98.3 100.7 (foobar: 101; 1679 tracks: 98.0 100.3)
Opus libopus 1.1, --bitrate 97: 99.3 101.7
Vorbis aoTuV [20110424], q1.99: 88.2 90.3
Vorbis aoTuV [20110424], q2: 94.2 96.4 (foobar: 96; 1679 tracks: 94.2 96.4)
Vorbis aoTuV [20110424], q2.4: 98.2 100.5
As you can see, the chosen sample of 100 tracks is quite faithful to the bitrates achieved over the 1679 tracks. Median and stddev should also be similar.
edit: How come foobar deviates so much? Assuming foobar is discarding container overhead, shouldn't the reported bitrates be smaller than the ones calculated from the raw filesize? Am I doing something wrong?
edit: Arg! Damn kilo issue!  I hope I didn't mess up the numbers since I had to enter everything again.
Reply #274
Well, kbps is totalsize [bytes] / duration / 1000 * 8
