Topic: 6-track wav audio to six 6 wav files? (Read 3089 times) previous topic - next topic
HI.
So I have this 6-track wav file from Bjork's Surrounded 5.1 box... all I want to do is convert it to 6 different mono wav files. This seems simple enough but I have searched and searched and I just can't do it in Foobar, but I'm pretty sure it's possible.
I DO NOT have the original DVD so eac3to is NOT going to work.
thanks
I did not mean to type 6 three times in the title, oops. Now I'm cursed.
A neat little utility that will do this - you'll have to play with the options - is WaveWizard.
ok this looks cool and easy to use but I'm not seeing an option for splitting wav files from one file, do I need something else for that?
Nope.  Under Edit/Preferences, Select: Ignore size in Header, Enable Channel Mapping, Stream Manipulation/Mono Streams, Output Format/Wave PCM and you should end up with 6 mono wave files suitable labelled.
wow, I almost got it too, but when it was converting it said "file 0 of 1" so I thought I had it wrong
THANK YOU SO MUCH.
Awesome remix projects ahead
