Topic: Final Settings Prior To Encoding Collection (Read 20462 times) previous topic - next topic
I have an old account but I haven't posted in a long time, can't remember the email I registered with so I started this account.  Anyway, I've ripped my CD collection several times (once at 128kbps, then again at 192kbps, then again at v0) each time with Easy CD-DA Extractor.  Didn't always rip all at once, but the settings were pretty much the same till I changed so many CDs could have been ripped with different LAME versions as well.
Anyway, I'm sticking with v0 and I'm ready to re-do the entire collection at the same time with the same LAME version and settings.  I don't want to be kicking myself again in a few years so I wouldn't mind a few opinions before I do everything and realize I did something incorrectly again in a few years.
After reading this forum a lot, the Exact Audio Copy wiki, and general Google searches, this is my final:
Software: Exact Audio Copy (0.99 Prebeta 4)
LAME: 3.98.4-vc6
Command Line: -V 0 --id3v2-only --ta "%a" --tl "%g" --tn "%n" --tt "%t" --ty "%y" --tg "%m" --tc "rbm (eac secure mode)" %s %d
I'm looking for the highest quality v0, rip time doesn't matter.  From my reading this is the best command line I can get, am I missing anything?
Also, it seems like LAME 3.98.4 is highly recommended, is there a different version I should be using?
Yes, plain -V0 is the best idea for encoding VBR. Any other switches are not likely to increase quality appreciably and might even degrade it.
You could start by not using a version that’s over 3 years old! I’m not aware of any good reason to use anything but the latest version, 3.99.5. I generally presume the developers know what they’re doing and therefore that later versions are better. Otherwise they wouldn’t release them.
Also, since this is specific to LAME and not EAC, it belongs in MP3 and not CD Hardware/Software. EAC is tangential in cases like this.
Sounds good, I'll go with the newest LAME, I just read a lot, there seemed to be personal preference all over the place for a lot of older versions.  I saw 3.98.4 referenced a lot, good point though.
You're ripping your CD collection for the 4th time; why don't you rip to FLAC and be done with it?  As far as EAC is concerned, it's not any more difficult/time-consuming.  First, get the newest EAC; there's no reason to be using an old version.  You may want to use the newest FLAC encoder.  Install EAC first then copy the new FLAC.EXE over the copy in the EAC folder.
Whatever lossy formats you may need later (MP3/AAC/WMA/OGG) can easily and quickly be generated from the FLACs.
I can only say this to you because I re-ripped my entire CD collection three times before I figured this out.
I would echo the recommendation for FLAC. Its lossless, and once you have a lossless archive you can easily transcode to whatever lossy format you want.
Personally, I would recommend you check out dBpoweramp. I think its tagging features are much more robust then EAC's.
If you do use EAC, use the newest version. It has significant improvements and supports CTDB.
Rip to FLAC first, then encode with any version of LAME you'd like - including future versions in future years - and never have to re-rip in this lifetime.
As for settings, -V 0 is all you need. The -V settings have been heavily optimized and tweaked over many years. The work of figuring out how to design an encoder to use bits most efficiently, has already been done by the encoder's developers. In earlier times, with less mature (or just bad) software, there might have been advantages to forcing the encoder to abide by certain restrictions in the form of command-line arguments. LAME has been developed to such a high degree that this is unnecessary.
One thing that might be worth checking out, though, is the "functional extension" of LAME that I've seen mentioned on these very boards. I don't remember what it was called, but it made some modifications to the higher bit rate VBR mode so that it would be more liberal with handing out 320 kbs frames, which can improve how the encoder handles problematic samples. My technical description of it may be off, but perhaps someone can find the thread.
LAME 3.100k is the current version of halb27's extension, but as has been discussed before, it is inadvisable to recommend LAME offshoots to people who have yet to demonstrate through ABX tests that standard V0 fails to meet their quality requirements.
http://www.hydrogenaudio.org/forums/index....howtopic=101150
Thank you! I will add that -V0 might well be excessive too, but I can see why you used it as your reference-point in this case.
I think your understanding is roughly correct. It also offers the user the ability to set the minimal size of frame used by VBR. If you ask me, both of these are likely to lead, in the minds of users who do not fully grasp the concepts yet, to even more confusion about how VBR actually works and how relevant the bitrate is (hint: not very) in this mode.
My advice, especially to new users, it just to use standard LAME and presume wisely that its developers know fine well what they are doing, unless you have a particular psychoacoustic system that is specifically sensitive to the equally specific issues on which halb27 spends so much time and tests so many isolated samples of unusual timbres rather than representative sections of real music.
After several recommending it in this topic, I bought dbpoweramp.  I like it so far, two questions before I go further with ripping.
1) I'm going to rip everything vbr 0 (mp3 lame) ... I selected "Slow (High Quality)" and then under advanced there is an "Additional CLI" is there anything else I should add or is their default optimal?  Any options I should change that I might have missed?
2) I'm also going to rip to FLAC as several suggested, the v0 are for my iPhone, the FLAC will be backups in case I ever need to convert again.  I've never done FLAC, under the options there are Lossless 0-8 then Lossless Uncompressed.  I'm assuming I should be doing uncompressed I just wanted to verify?
Thanks for everything.
Why why why are you converting to MP3 if you have an iOS device to play the files? Convert to ALAC for archival then transcode to AAC for portable/temporary use.
No, the defaults are recommended, hence why the developers made them the defaults. Even -q should be left at its default for normal use; the supposedly higher settings are not proven to be better/worthwhile.
No, not at all. Why else would it be called lossless compression? The uncompressed variant is presumably provided for some edge cases, but almost no one uses it, because the main reason to use a lossless compressor is so that, well, your audio gets compressed. The numbered options only change the balance of compression against encoding time, not the audio at all, hence the other word, lossless.
2. Lossless is lossless so what level of compression you choose makes zero difference to quality. It does make a difference is file size and can make quite a difference to how long the process takes.
Do a couple of test runs and see what works for you. Many people here have expressed the idea that compression level 5 is a good mix for saving some disk space without too much of a time hit. YMMV
As I said I've never ventured in to FLAC before, I thought it was uncompressed so I was unsure why there were options like VBR (0-8).  That makes sense though, thank you.
I will do that, I see 5 is also the default in dbpoweramp but I'll do a few test runs.  Thanks.
FLAC -0 in uncompressed. Again, why won't you consider ALAC/AAC?
As long as your computer is moderately recent, FLAC encoding is pretty fast.  Most of the time there's little reason to use anything but level 8.
As for your plan to use LAME V0, since an iPhone has a limited, non-upgradeable, amount of space, you might want to try other V settings to maximize use of available storage.  You've probably already considered that, but I thought I'd mention it anyway while I'm posting.  heh
There is no such thing as 'uncompressed' flac. It is a lossless form of compression similar to a zip file. Level 0 is larger file size/faster encoding. -8 is smallest file size/slowest encoding. However modern cpus with more than one core will encode even -8 far faster than your cd drive can physically read the disc, which is why I always use it (Why waste space if there's no benefit?). You can expand flac back to its original wav state, burn it to audio cd and it will always be the same, no loss in sound quality, again just like a zip file.
If the space on your iphone isn't an issue, -V0 is just fine if you aren't interested in doing abx testing to identify your transparency threshold, and you simply want that 'insurance' that you aren't losing sound quality. If space becomes an issue later on, consider doing some testing.
Also, since I am unfamiliar with dbpoweramp, does it do accuraterip checking to make sure your cdrip has been, well, accurately ripped? If not I won't sick the EAC brigade on you, but simply suggest you grab the free software cuetools, and check your ripped albums to make sure there are no errors.
Mach-X, thanks for the lesson about lossless compression, now take a look at this screenshot:
...I'd actually like to know how to do that with a command and/or with foobar2000.
Regarding MP3, even V2 is "just fine". I still don't understand why he doesn't go AAC.
Any idea what commandline switch that is? Never heard of such a thing, nor is there any mention of it in the FLAC documentation.
--disable-constant-subframes --disable-fixed-subframes --max-lpc-order=0
accuraterip and dbpoweramp were both created and are maintained by the same person. http://www.hydrogenaudio.org/forums/index.php?showuser=1615
Uncompressed FLAC is a dubious extension pioneered by dBpowerAMP. You can search for it, but naturally, you will stumble across a load of crap from people who think lossless compression somehow damages sound quality, despite it putting out exactly the same bits by definition. So maybe save your energy.
We let people decide on their own, I keep an open mind. A segment of the market had a need for an uncompressed lossless codec without tagging limitations, we gave people what they were asking for.
Here is a typical reply we give about its virtues:
http://forum.dbpoweramp.com/showthread.php...ll=1#post136096
Some people are sure they can hear a difference, others are sure they cannot. Lossless is lossless, that is all the modes decode to the exact same audio, however the difference is the amount of CPU time required for each, depending on player (such as modern PC) it could be very little cpu for both, or more significant for embedded players.
Don't rip twice. Just rip to lossless (FLAC or ALAC) and then batch encode those to lossy (MP3 or AAC).
