Topic: foo_touchremote - Remote control for iPhone/iPod Touch (Read 148706 times) previous topic - next topic
Reply #125
which version of vc++10 is installed? x86 or x64? for me the solution was to install the x86-version ...
EDIT: but i've got a new problem with remote-version 2.2. clicking on the right top botton (in the remote app), no titles/playlist is visible to me - anyone the same problem?
Reply #126
Yeah, I have the latest version of VC++ 10 x86 (SP1 update). I also tried uninstalling it and going back to the pre-SP1 version linked on the plugin homepage, and I got the same error. Now I'm back to VC++ 10 SP1, which I needed for another app.
Reply #127
Nevermind, I had only the "Client Profile" for .NET 4.0. After installing the full version with the "Extended" part, it works.
This is ill. Next goal: hookup my Squeezeboxes with Whitebear and foo_upnp, iPhone becomes control for music synced throughout my home network...which is already possible with the free Squeezebox app, but using foobar for everything is much nicer, especially with autoplaylists.
Just wish I could see and set ratings. Looks like MonkeyMote allows this, funny I barely see that app mentioned anywhere in these forums, guess he was banned.
Reply #128
Well, after actually setting it up, I'm not sure the whole foo_upnp, Whitebear, Squeezeserver, iPhone controlling synced Squeezeboxes setup will integrate as expected, I'll keep trying.
Reply #129
For anyone interested, I got it to work, using the "Playback Stream Capture" mode of foo_upnp, that sends "what is currently playing" in foobar to Whitebear -> Squeezeserver -> Squeezeboxes, controlling Foobar as usual with the iPhone Remote app. The downside is this mode forces you to transcode everything to a 320kbps MP3 stream, and you lose album art display on the Squeezeboxes.
Not sure the Foobar integration for controlling my Squeezebox network trumps having full FLAC fidelity and album art display, as with just using Squeezeserver.
Reply #130
Probably not, because it is already fixed in 0.2.8.2
Reply #131
Wonder if it might be possible to hack this component so items that normally go to the "TouchRemote Selection" playlist go instead, or in addition, to foo_upnp's "UPnP Controller Playback Queue", then you would get full playlist control of Foobar with foo_touchremote along with full FLAC streaming and album art of that playlist with foo_upnp.
Reply #132
thank you! didn't recognize that there was an update available ... it just works fine again
Reply #133
Hey guys! I'm trying to connect the TouchRemote to my iPad 2. Here is what the console says:
TouchRemote: trying to pair with  "bronc’s iPad" (82b7d03725d78585701a0d1fdf60ca343d0a07af)
TouchRemote: Pairing failed: Unable to complete pairing: Unable to connect to the remote server
TouchRemote: Pairing cancelled
The only firewall I have is the Windows one and it has exceptions both for foobar2000 and Bonjour service.
Reply #134
I have noticed a weird thing tag wise.
When I have 1 album from one artist, everything is fine. When I go into the album, it displays Tracktitle, Track artist/artist and albumtitle.
But if I have more than 1 album from an artist, then when I enter the artist, go into the album, then I suddenly only have Tracktitle.
This is really annoying and a shame in an otherwise VERY well working piece of software.
I am using Iphone remote 2.2 on IOS 4, with latest foobar2000 on Windows 7.
PS - Does anyone know if the Iphone remote supports selecting queue to default playlist, when viewing tracks? It's a little annoying having to go into the playlist I want to use and the choose edit and add.
Reply #135
Unfortunately, this behavior is defined by Remote itself and cannot be changed. If you connect to iTunes, it would be the same.
Reply #136
Is this component supposed to show data (artist & title) from streaming radio? Those info are correctly shown in foobar, but I only get Unkonwn Artist and the name of the stream on my iPhone.
Alessandro
Reply #137
This component works only if both devices are connected via Wi-Fi?
last.fm | bulletproof2k
Reply #138
This would be extremely cool. I can then use Apple Remote app to send FLAC to my 4311ci.
Cheers.
Reply #139
Cheers.
Just a note, you can see the uPnP Controller Playback Queue as another playlist in the Apple Remote app when controlling Foobar, but playing a song in it just plays it in the Foobar desktop app, like any of the other playlists. So not only would you want to be able to select / filter songs into the Playback Queue using Apple Remote, you'd have to make a way to trigger the uPnP player selected in the Foobar uPuP Controller, instead of just having it play the song in the Foobar desktop app.
Reply #140
I have a problem, in the Remote app it says it cant find foobar 2000
Reply #141
agreed.. since updating Remote.app to version 2.3 on 8-March 2012 on an iPhone4 with iOS 5.0.1.
The Remote app instantly shows "Could not find foobar 2000".  Tried to reauthorize the client (removed and paired again).  The two can talk just fine.  When I turned on console logging and found this sequence happening each time I try to connect to the library:
[blockquote]HTTP 84: /server-info
HTTP 84: /login
  pairing-guid: redacted
  hasFP: 1
HTTP 84: /ctrl-int
HTTP 29: /fp-setup
  session-id: 1331461712
HTTP 29: Request is not served: /fp-setup
[/blockquote]
Reply #142
HTTP 84: /login
  hasFP: 1
HTTP 84: /ctrl-int
HTTP 29: /fp-setup
[/blockquote]
Same issue here. Same timing; same symptoms.
Rolled back to 2.2, and that fixed it for me.
Reply #143
How did you do that? How do you even find 2.2?
Reply #144
Went to my incremental backups (Time Machine in this case) to find it. Deleted 2.3 from iTunes and device. Resyncd. Added 2.2 to iTunes. Resyncd.
Warning though; no longer able to use the 'update all' feature after you do this, as you have to keep the Remote app from updating. No option to 'ignore update' for a particular app; at least I couldn't find one.
I hope that the author of this wonderful plugin will work to make it compatible with the newest Remote app, in time. Until then, this solution worked for me.
Reply #145
This.
Reply #146
Fixed for now. I hope
Reply #149
This is definitely OT, but since the developer is here, I wanted to ask if there will be any further development of foo_airplay.  It's a great component and would love to see a more robust version.
